Qantas747300
CX Fleet And Engine Data.
Wed Mar 21, 2012 12:57 am
Research has failed to answer a few questions regarding the CX fleet.
1. With reference to the CX 330 fleet, what does the 'X' or 'E' represent? Eg. A330-343X/A330-343E.
2. I can't seem to find consistency when it comes to what engines are installed on what aeroplanes. The following lists the most accurate data I have to date:
*B747-467 are powered by RB211-524HT;
*B747-467ERF are powered by PW4062;
*B747-412 (ex. SQ) are powered by PW4056;
*B777-267 are powered by the Trent 877;
*B777-367 are powered by theTrent 895;
*B777-367ER are powered by GE90-115B;
*A330 are all powered by the Trent 772; and
*A340 are all powered by the CFM56-504.
I would sincerely appreciate any corrections.
Stitch
RE: CX Fleet And Engine Data.
Wed Mar 21, 2012 1:26 am
From an old a.net thread in TechOps:
The A330-300X is the longer-range version of the -300 with a higher MTOW of 230t-233t and a center fuel tankIt also has a larger vertical stabilizer and stronger wings than the -300s.
The A330-300E is structurally the same as -300X and can be had with MTOWs up to 235t. It has advanced systems and avionics and updated cabin fittings.The A330-300E is structurally the same as -300X and can be had with MTOWs up to 235t. It has advanced systems and avionics and updated cabin fittings.
Qantas747300
Wed Mar 21, 2012 1:57 am
Thank you Stitch. I can't seem to find the old thread and I am curious as to the technical advancements that have been made with reference to the 'E'. Do you recall?
Your help is sincerely appreciated.
zkojq
Wed Mar 21, 2012 12:05 pm
Quoting Qantas747300 (Thread starter):
  Actually its not that simple. Cathay Pacific is (probably) the only airline to have engines from all of the big three manufacturers on their 747s - but the different engines are split over several different versions of the 747 that are currently in their fleet. Here is my (rather lengthy) correction:
Boeing 747 passenger aircraft:
The 747-400s that Cathay Pacific ordered new are powered by Rolls Royce engines. EG B-HOV
The 747-400s that Cathay Pacific bought second hand from Singapore Airlines are powered by Pratt & Whitney engines. EG B-HKE
Boeing 747 freighter aircraft:
The 747-400Fs that Cathay Pacific ordered new are powered by Rolls Royce engines. EG B-HUQ
The 747-400 BCFs (the ones that started out carrying passengers before being converted) are powered by either Rolls Royce and Pratt & Whitney engines. EG B-HKX has Pratt & Whitneys, while B-HOZ has Rolls Royce.
The 747-400 ERFs that Cathay Pacific ordered new are powered by Pratt & Whitney engines. EG B-LIA. There is no Rolls Royce engine option for 747-400 ERFs, so Cathay Pacific had to choose between Pratt & Whitney and General Electric. They chose Pratt & Whitney because the ex Singapore Airlines 747s also had those engines.
The 747-8Fs have General Electric engines. EG B-LJA. General Electric engines are the only engines that power the 747-8.
Most recent planes I've been in: A318 F-GUGQ, A319 F-GRHR, A320ceo D-AIZH, A320neo D-AINE, A330-300 VH-QPD, A350-900 B-LRA, A380-800 D-AIMH, B737-600 LN-RPA, B737-700 OY-JTY, B737-800 LN-NGA, B767-300 ZK-NCI, B777-200 ZK-OKD, B787-9 ZK-NZH, CS100 HB-JBG
CXB77L
Wed Mar 21, 2012 2:11 pm
Quoting zkojq (Reply 3):
That depends if it's a 747-467 BCF or a 747-412 BCF. B-HO* and B-HU* are -467s, while B-HK* are -412s with the PW engines. That applies to pax aircraft as well: B-HO* and B-HU* are RR powered -467s, while B-HK* are ex-SQ -412s with PW engines.
Boeing 777 fanboy
imiakhtar
Wed Mar 21, 2012 3:53 pm
There is at least one other airline that has operated a 747 fleet with the three engine types at the same time - PK.
B747-200 Combi (GE)
B747-200 pax (Former CP and TAP - PW)
B747-300 pax (ex Cathay RR)
Whatever happened to Leon Trotsky?
trex8
Thu Mar 22, 2012 2:17 am
Quoting Stitch (Reply 1):
Others have pointed out that there are no A333 with a center wing tank.
Stitch
Thu Mar 22, 2012 4:28 am
Quoting trex8 (Reply 6):
Fair enough. The higher TOWs would allow more fuel to be loaded in the existing tanks for greater range.
CX711
Thu Mar 22, 2012 4:50 am
Does that mean that the latest A330s that CX has ordered and are taking delivery are the A330-300Es? I had the impression that all the latest versions of A330-300 have longer range and higher MTOW? Do airlines still order the A330-300X?
Stitch
Thu Mar 22, 2012 2:46 pm
Quoting CX711 (Reply 8):
According to airfleets.net, CX is taking a mix of A330-330s, A330-343Xs and A330-343Es.
B-LAK is shown as an A330-343E
B-LAL and B-LAM are both shown as A330-343X
B-LAN is shown as an A330-343
This is the thread on the A330-300E and A330-300X - Can Someone Explain The A330/A340 E's And X's (by AviationAddict Jan 14 2008 in Civil Aviation). My initial post's information came from seabosdca's post, but Tom_EDDF posted a corrected version.
I have found a number of sites that reference a center tank for the A330-300X - was this maybe something Airbus was considering offering?
[Edited 2012-03-22 07:48:36]
trex8
Thu Mar 22, 2012 5:09 pm
Quoting Stitch (Reply 9):
per the Jan 2012 Airbus acaps all A333 have 97530l fuel capacity and all A332 139090l so maybe they considered it but never did it
http://www.airbus.com/fileadmin/medi...h_data/AC/Airbus-AC_A330_Dec11.pdf
zeke and someone else explained the X quite well once, it had to do IIRC with the max loading in the cargo holds.
I would think you couldn't get a non E version today, why would they want to build them with CRT displays and all the "old " avionics and cabin systems and not have a common product. One other thing I have noticed is that all GE powered ones never seem to be designated E, even recently delivered ones, which doesn't make sense.
Then there is the confusion with the A343E, the higher TOW A343s eg SQs ones were called E initially but then A changed that to X. But the A343E has nothing to do with the E imporvements on the A330s!
Stitch
Thu Mar 22, 2012 5:51 pm
Quoting trex8 (Reply 10):
I agree. seabosdca noted in the other thread (from 2008) that Airbus only offered the A330-300E and A340-300E.
As such, Airfleets.net might have bad data. I am sure one of the CX crew on this forum can confirm what they're taking delivery of if they come across this thread.
I can find very little on it, but what I can find implies it is more powerful engines and higher TOWs to give the plane "X"tra range.
Per Tom_EDDF in the other TechOps thread, the A340-300E(nhanced) is an A340-300X that has the CFM56-5C4 engines and a cockpit and certain systems similar to the A340-500/-600 (these systems are evidently also found on the A330-300E).
trex8
Fri Mar 23, 2012 12:50 am
Quoting Stitch (Reply 11):
This is true from about ?2006 but in the late 90s when the first 275K MTOW A343 came off the line they were called then Es also ! But then this got changed to X fairly quickly.
zkojq
Tue Apr 03, 2012 1:31 am
Quoting CXB77L (Reply 4):
Thanks for pointing that out, CXB77L. I spent 15mins looking at a spreadsheet with all the sub-types, registrations, delivery dates, engines and serial numbers of CX 747s yet failed to make that connection.
Qantas747300
Tue Apr 03, 2012 3:04 am
Would someone be able to send me in the correct direction for CX engine data? I have a relatively 'non-uniformal' compilation of data that seems to be increasing in accuracies at a rate faster than I am correcting it'.
I have learnt a lot so far. Thank you everyone!
Users browsing this forum: RetiredWeasel and 22 guests
