Faro
GTF Variable-Area Nozzle: Why So Late?
Wed Apr 18, 2012 11:51 am
Why is the PW GTF the first engine to be equipped with variable area nozzles?
Given the fuel savings, why wasn't this technology adopted a long time ago? After all, it does not -a priori- seem like a very high tech innovation for a civil engine: military variable area nozzle have been around since the J79 IIRC. What's so challenging about a civil variable-area nozzle application?
Faro
The chalice not my son
Fabo
RE: GTF Variable-Area Nozzle: Why So Late?
Wed Apr 18, 2012 12:49 pm
Well my best guess it was not cost effective until now... the technology costs less and less with time, and fuel was not so unbeliavably expensive until recently...
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
tdscanuck
Wed Apr 18, 2012 1:40 pm
Quoting faro (Thread starter):
It's heavy, expensive, and complicated (=unreliable). The fuel savings needed to climb high enough in dollar terms to "pay for" all the problems that come with it.
Tom.
lightsaber
Crew
Thu Apr 19, 2012 10:51 pm
The variable nozzle requires a variable cycle engine concept. In other words, it costs in test and software programming time. Before the compressor stator mapping couple be a function of outside temperature (well... density too), fuel flow, engine RPM, and a few 'tweaking variables' that were relatively easy to map.
Now with the variable nozzle, the engine must adadpt to the fan nozzle as the fan nozzle is adapting to either maximize thrust for a given fuel burn. In other words, it requires a FADEC that has significantly more computational power with alternate mappings for the compressor stators in case the nozzle fails full open, full closed, or anywhere in between.
In 2000, the best FADECs were single core PowerPC 630s. Not exactly a barn burning chip. I forget the clock rates, but they were heavily reduced in oder to survive being glued to the motherboard (worse thermal conductivity) and the variable thermal environment of a jet engine.
Also recall that for safety critical flight control (which the engine should be part of), the CPU is usually loaded to 25% of capability as one is required to stay under 50% cycle loading.
Then the software testing....
The I/O data, I take from this link, is 25% to 30% greater with the PW1000G and doing quite a bit more decision making with that software. I can only begin to imagine the size of the FADEC team for the PW1000G and all the variants:
http://www.aviationtoday.com/av/issu...over/Engine-Indications_27100.html
Lightsaber
CM
Fri Apr 20, 2012 1:55 am
The GTF requires the VFN to achieve acceptable stall margin for the fan. It's the baggage that comes with a very large, slow turning fan. If PW could solve the fan stall challenge without it, you would not see it on the GTF.
