bikerthai
How Would Food Taste On The 787?
Fri Apr 27, 2012 6:53 pm
I got this link from another topic about Airline Peanuts Cost.
http://www.nytimes.com/2012/03/11/bu...n-flight-meals.html?pagewanted=all
"Even before a plane takes off, the atmosphere inside the cabin dries out the nose. As the plane ascends, the change in air pressure numbs about a third of the taste buds"
Well, with the 787 cabin pressure and humidity will be higher. Would this make airline food taste better or worse?
AADC10
RE: How Would Food Taste On The 787?
Fri Apr 27, 2012 7:09 pm
It may not be as much better as they might think. Much of taste is actually linked to the texture which is often poor on airplanes because the food is pre-cooked and re-heated. While the 787 cabin pressure and humidity is higher, most reviews have not shown a night and day difference due to the atmosphere. The pressure is approimately equivalent to 6,000 feet (vs. 8,000 for a conventional aircraft) so it is still quite different than sea level.
rwessel
Fri Apr 27, 2012 7:18 pm
It would make it taste a bit more like it would at sea level. Whether that would be better or worse is a different issue.
rampart
Fri Apr 27, 2012 7:50 pm
In my fare class, I doubt humidity and air pressure will make much difference on the pack of Cheezits and can of Coke.
-Rampart
par13del
Fri Apr 27, 2012 8:08 pm
Quoting rampart (Reply 3):
Nuff said
bohica
Fri Apr 27, 2012 8:23 pm
The food will taste the same as it does on any other airplane: Bad.
Stitch
Sat Apr 28, 2012 12:25 am
I haven't noticed an appreciable difference when dining on the A380, which I believe has a similar cabin pressure and humidity level to the 787.
Sat Apr 28, 2012 9:09 am
Food never tastes upto what it should be on the ground,mainly because its not freshly cooked but rather reheated.
Looking for excellent food on an aircraft is rare unless its freshly prepared.
Ratypus
Thu May 03, 2012 11:29 am
In any event, airline food generally contains more salt/sugar/flavouring than "terrestrial" food, precisely to compensate for the diminished sense of taste in the cabin environment. If the 787's cabin environment does, in fact, diminish that sense of taste less....you can probably expect your meal to taste more salty/sweet than you're used to!
Eugh.
sturmovik
Mon May 07, 2012 11:43 am
Off topic perhaps, but I was recently at a business meeting at DXB premises, and the refreshments served were from EK catering. I could've sworn it tasted better on the ground than on the flights I took into and out of DXB.
'What's it doing now?'
Western727
Mon May 07, 2012 5:03 pm
Quoting Stitch (Reply 6):
I thought the 380 does NOT have a composite fuselage...and thus has similar cruise pressure/humidity levels as, say, a 330 or 777?
Jack @ AUS
U2380
Mon May 07, 2012 5:31 pm
Quoting western727 (Reply 10):
Approximately 25% of the A380 is made from composite materials. GLARE is used in the upper fuselage and CFRP in the rear pressure bulkhead, centre wing box and wing ribs among other area. In fact, I think I'm right in saying that the A380 uses more composite materials (by measure of sheer weight) than the 787.
However, the point in hand. The A380 does have similar pressure/humidity levels to the 787. Increased corrosion is the main issue when you decrease the cabin humidity (due to the higher level of moisture in the air). CFRP is more resistant to corrosion when compared to aluminium. This enables the 787, with its increased use of composites, to utilise a higher cabin humidity.
I presume the A380 uses extra corrosion protection when compared to previous aircraft to achieve the desired corrosion resistance. I'm not entirely sure on the specifics though (I think it may be achieved using humidifiers).
One last point I would make, however, is that 50% of the 787 is not built using composite materials. Those areas of the aircraft are vulnerable to the increased corrosion so I'm sure similar methods of protection are also used on the 787.
[Edited 2012-05-07 10:34:20]
Users browsing this forum: dmmatt, Horstroad and 2 guests
