dennys
Q.VARIG 747-341s And 747-441s Engines Design.
Sat May 05, 2012 8:08 pm
Hi guys , can you help me .
Had the 747-341s the same engines design as the 747-441s?
They really seem to be closed one to the other .
The same case was on the Air India's 743s and 744s .
Many thanks your help
kind regards
dennys
jetmech
RE: Q.VARIG 747-341s And 747-441s Engines Design.
Sun May 06, 2012 12:51 am
According to these links;
http://www.planespotters.net/Product...7,TF-ATI-Air-Atlanta-Icelandic.php
http://jetphotos.net/census/aircraft2.php?msnid=747-24956
The 341 is powered by the CF6-80CB1, whilst the 441 is powered by the CF6-80C2B1F. GE aviation lists the primary difference as a higher pressure ratio and thrust for the B1F;
http://www.geaviation.com/engines/commercial/comparison_turbofan.html
I suspect another difference may be in the engine control. The B1 may have a hydro-mechanical fuel control, whilst the B1F may be FADEC. The Boeing 747-337M is powered by the CF6-80C2B1, with the 437 powered by the PW-4056.
http://www.planespotters.net/Product...ing/747/24159,VT-EPW-Air-India.php
http://www.planespotters.net/Product...ing/747/28094,VT-EVA-Air-India.php
Regards, JetMech
[Edited 2012-05-05 18:00:35]
Jetlagged
Sun May 06, 2012 1:13 am
Some late production 747-300s had GE CF6-80C2B1 engines, the same type as installed on many 747-400s. The last three Varig 747-341s had them as did two Air India 747-337s. Varig 747-441s had the same engine, but with FADEC (CF6-80C2B1F). Air India's 747-437s have a different engine, the PW4056.
edit: JetMech beat me to it! AFAIK, the only physical difference between B1 and B1F is FADEC. The B1F has a slightly higher thrust rating.
[Edited 2012-05-05 18:22:17]
dennys
Sun May 06, 2012 4:34 am
Many Many thanks ! You are brllient passionnated people .
dennys
Max Q
Sun May 06, 2012 5:44 am
Quoting Jetlagged (Reply 2):
Are these the same engines installed on Air Force One ?
I know 'any aircraft carrying the President bla, bla, bla'
Sun May 06, 2012 10:50 am
Quoting Max Q (Reply 4):
The VC-25A (bla, bla bla) have the CF6-80C2B1F.
747classic
Sun May 06, 2012 11:24 am
The following B743/CF6-80C2B1 are delivered by Boeing :
747-3D7------ MSN 23721 - L/N 681 Thai
747-3D7------ MSN 23732 - L/N 688 Thai
747-341-------MSN 24106 - L/N 701 Varig
747-341-------MSN 24107 - L/N 702 Varig
747-341-------MSN 24108 - L/N 703 Varig
747-337M---- MSN 24159 - L/N 711 Air India
747-337M---- MSN 24160 - L/N 719 Air India
Also two B742/CF6-80C2B1 are delivered :
747-2G4B-----MSN 23824 - L/N 679 USAF
747-2G4B-----MSN 23825 - L/N 685 USAF
All CF6-80C2 versions without -F are mechanical controlled with a main engine control (MEC) and a Power Management Control (PMC), a digital supervisory controller, jointly acting as the engine controlling system.
Mechanically controlled engines can have their thrust rating changed by replacing the MEC and the PMC.
The CF6-80C2B1F (as installed on the 744) introduced the first FADEC system on the CF6 family. Such electronically controlled engines have additional sensors installed on the engine, allowing a more precise control of systems, thereby decreasing fuel consumption (TSFC). On such engines the MEC and PMC are substituted by the Electronic Engine Control (EEC) . Engine thrust rating can be changed by only replacing the rating plug at the EEC.
MEC/PMC controlled CF6-80C2 engines cannot be modified to FADEC standard.
[Edited 2012-05-06 05:00:06]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Users browsing this forum: Bing [Bot], hobbsieoz, planecane, Starlionblue and 1 guest
