jetskipper
B-747 Vs A-380 Flight Deck Placement
Mon May 14, 2012 9:42 pm
What was Boeings reason for putting the flight deck of the 747 on the second deck? Airbus positioned the flight deck of the A-380 on the first deck which seems to give the pilots a vantage point that they are more accustomed.
Viscount724
RE: B-747 Vs A-380 Flight Deck Placement
Mon May 14, 2012 9:51 pm
Because the 747F has a flip-up nose door. Don't think it would be very practical for the flight deck to be part of the cargo door.
Photo © Tim de Groot - AirTeamImages
warden145
Mon May 14, 2012 10:02 pm
Boeing put the flight deck on the second deck (and, for that matter, created the second deck hump in the first place) for cargo...so that the nose could swing open to allow full access to the main deck without interfering with the flight control linkage.
Photo © AirNikon Collection-Pima Air and Space Museum
Photo © Allan Rossmore
Photo © Greg Yates
Photo © Bernd Sturm
For comparison, the Aero Spacelines Guppy (Boeing 377 conversion) had a setup where the entire front of the airplane swung open...and, I've heard that the flight control linkages had to be re-adjusted every time the front was opened up.
IIRC even when they were still actively planning the A380F, Airbus wasn't planning to have an opening nose, so they decided it wasn't necessary to put the flight deck on the second deck...and, in the days of fly-by-wire, I imagine that it wouldn't make a difference on a modern aircraft anyways since you don't have to deal with adjusting control cables and linkages and whatnot. With that said, from an aesthetics standpoint, I think the flight deck on the A380 looks like it's lower than it should be and is the single biggest thing that makes the plane look ugly IMHO. It still looks better than the 777 does, though
ETOPS = Engine Turns Off, Passengers Swim
Stitch
Mon May 14, 2012 10:04 pm
Quoting jetskipper (Thread starter):
Boeing designed the 747 to be able to load cargo through the nose and that required the cockpit to be located above the main deck for clearance.
Boeing's early dual-deck 747 concepts had the cockpit on the upper deck, as well.
They did have a single-deck concept called "the anteater" where the cockpit extended out from the main fuselage to allow it to hang lower and offer better visibility for ground operations and landing.
http://www.socialwelfareagency.org/Public/Graphics/Aviation/Boeing_747_Anteater.jpg
gigneil
Mon May 14, 2012 10:59 pm
Hey, did Boeing design the 747 to be able to load cargo through the nose?
NS
brilondon
Mon May 14, 2012 11:08 pm
Quoting gigneil (Reply 4):
I thought they were designing the 747 to be a military freighter transport to transport tanks and troops and made the cockpit where it is to be able to load large items through the nose for quick deployment in the battle theatre.
[Edited 2012-05-14 16:10:47]
Rush for ever; Yankees all the way!!
aloges
Mon May 14, 2012 11:12 pm
The legend goes that the common belief during the design stage of the 747 was that most future intercontinental passenger transport would be supersonic. So the 747 was designed to be able to load cargo through the nose, IIRC it was even considered to convert pax aircraft with fixed noses to open-nose freighters after the switch to SSTs.
I hope my memory isn't too rusty...
cargolex
Mon May 14, 2012 11:23 pm
Yup.
The "SCD" portion of what you commonly see at the end of a 747 freighter's build code is for "Side Cargo Door" - The very first 747-200 freighters actually had the side cargo door as an option rather than a standard feature. I believe that the first 747-200 freighter, for Lufthansa, only had the nose door at first, and had the SCD added later. I don't think any other 747F's were delivered that way.
A small number of 747s with windows - the 747 Convertibles - were delivered with the nose door. In the above photos, you can see one of them. They were meant to be convertible between both full freighter and full pax, but in practice, this was not as practical for a 747 as it was for a 727 or 737 (the other convertible models in Boeing's lineup at that time).
That same aircraft as it appeared in 1974:
Photo © Juhani Sipilä
It too, looks like it doesn't have the SCD.
[Edited 2012-05-14 16:27:04]
srbmod
Mon May 14, 2012 11:52 pm
Quoting brilondon (Reply 5):
The 747 design can be traced back to Boeing's failed bid for what eventually became the C-5. Lockheed, Douglas and Boeing were the three finalists for the CX-HLS project (Other manufacturers that submitted designs were General Dynamics and Martin Marietta.). The only reason why Lockheed won the contract was that their design had the lowest cost while the USAF preferred Boeing's design. You can definitely see elements of what became the 747 in Boeing's CX-HLS design:
http://www.alternatehistory.com/discussion/attachment.php?attachmentid=114238&stc=1&d=1285608482
Another thing to remember is that at the time the 747 entered service, conventional wisdom was that the SST (Concorde and B-2707) was the way passenger a/c would move towards and traditional jet a/c would be relegated to a cargo role. As we all know, this failed to happen.
ABpositive
Tue May 15, 2012 12:26 am
Quoting srbmod (Reply 8):
With most airlines treating their passengers like cargo, there is some truth in it.
Jetlagged
Thu May 17, 2012 10:21 pm
The A380 flightdeck is actually between the lower and upper deck. So it's still higher than would normally be the case in a wide body.
Fri May 18, 2012 12:10 am
Quoting Jetlagged (Reply 10):
It's up there to make space for the landing gear I think. The nose gear is further forward than on the 747, and the lower deck is lower in the fuselage. In any case it needs to be back a bit to make space for the radar.
ssteve
Fri May 18, 2012 3:15 am
It's amusing for me to see that -200C with windows in the nose door. Didn't realize that was possible!
tdscanuck
Fri May 18, 2012 4:41 am
The 747 was never designed for the miliary. It was designed to be a freighter since it was being developed concurrently with the 2707, which was widely assumed to be about to steal all the passenger traffic.
Quoting aloges (Reply 6):
Not just legend; the original 747 chief engineer came right out and said it, on the record.
Not really. They share engines and the 2nd deck flight deck location and that's about it. The same 747 chief engineer vehemently denies this repeated rumour that the 747 was just a "commercialized" version of Boeing's failed military airlifter.
Tom.
Fri May 18, 2012 4:59 am
Quoting tdscanuck (Reply 13):
Perhaps. But the section and fin look very 747.
tdscanuck
Fri May 18, 2012 8:18 am
Quoting Starlionblue (Reply 14):
Well, unless you're a T-tail, a fin is basically a fin but I agree they look similar.
The section I don't follow...the nose on the military model is clearly a different section than the 747 and the mid-cabin is high-wing rather than low-wing.
Tom.
Fri May 18, 2012 8:31 am
Quoting tdscanuck (Reply 15):
I'm sorry. That should have read "tail section". The TAIL section and fin look very 747.
sweair
Fri May 18, 2012 9:11 am
Yeah the tail looks very much 747, but the front looks a lot wider.
Jetlagged
Fri May 18, 2012 9:41 am
Quoting Starlionblue (Reply 11):
The nosegear retracts into the lower lobe, so it doesn't force the cockpit to be higher. The radar doesn't necessitate it to be any higher than a 777 flightdeck, for example. Main deck and upper deck height of the A380 is comparable to the 747, but the A380 decks are slightly higher in fact.
747 Main deck 4.74m - 5.18m, Upper deck 7.53m-7.91m
A380 Main deck 5.07m-5.34m, Upper deck 7.57m-8.36m
The A380 flightdeck window sill is 7.14m-7.42m above ground level. 747 flightdeck window sill height is around 8.3m-8.7m.
http://www.boeing.com/commercial/airports/acaps/7474sec2.pdf
http://www.airbus.com/fileadmin/medi...ata/AC/Airbus-AC-A380-20111101.pdf
http://www.boeing.com/commercial/airports/acaps/7772sec2.pdf
CALTECH
Sat May 19, 2012 3:04 pm
Quoting warden145 (Reply 2):
The 777 is just a bloated fat 767.
767 versus 777
Photo © Jeff Miller
Photo © Globalpics
Photo © Erwin van Dijck
Photo © Gabe Pfeiffer
747 versus 380, IMO the 747 looks more regal.
Photo © Julian Whitelaw
Photo © Paul Markman
Photo © Ian Lim
Photo © Karl Nixon
No way, no how.
777 versus 380
Photo © Kay Hansen
Photo © Globalpics
Photo © Karl Nixon
The gun is a precious Symbol of Freedom
Criminals are the deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence of tyrants who disarm their citizens
Viscount724
Mon May 21, 2012 2:10 am
Quoting SSTeve (Reply 12):
Boeing built 13 -200C Convertibles -- 3 each for Iraqi Airways, Transamerica Airlines and World Airways, and 2 each for El Al and Martinair.
Martinair -200C below while in use as a freighter and in all-passenger configuration.
Photo © Thomas Millard
Photo © John Kelley
There were two missing windows where the nose door met the rest of the fuselage. Second photo of the nose section interior while in use as a freighter, showing some of the passenger fittings including the forward bulkhead and window frames etc.
Photo © acinorev
Photo © Gerardo Wals
WingedMigrator
Mon May 21, 2012 3:23 am
A380 nose arrangement
vikkyvik
Mon May 21, 2012 3:42 am
Quoting WingedMigrator (Reply 21):
I was wondering when someone was going to point that out! The A380 cockpit is technically on a mid-deck, slightly above the lower deck.
Don't worry Neil, I laughed.
rwessel
Mon May 21, 2012 5:22 am
The tire (a 1270x455 on the A380 nosegear, IIRC) seems far out of proportion with the pilot in that illustration.
KELPkid
Mon May 21, 2012 10:57 pm
Quoting CALTECH (Reply 19):
767 versus 777
You know, they do share the same Boeing section 41 (cockpit section)   The 777 just has an adaptor section behind it to allow the 767 cockpit to mate to the 777 fuselage...
DocLightning
Mon May 21, 2012 11:13 pm
Quoting KELPkid (Reply 24):
A Boeing engineer came on this site and said that this is not the case. They share cockpit windows only. They couldn't make the 767 Section 41 work aerodynamically with the 777 fuselage.
-Doc Lightning-
-Carl Sagan
Jetlagged
Tue May 22, 2012 2:02 am
Quoting vikkyvik (Reply 22):
I pointed it out a while ago:
but wingedmigrator's diagram shows the layout very clearly.
bond007
Tue May 22, 2012 2:17 am
Me too...
Jimbo
vikkyvik
Tue May 22, 2012 3:18 am
Quoting Jetlagged (Reply 26):
Ah, my apologies - I missed that!
tdscanuck
Tue May 22, 2012 3:43 am
Quoting DocLightning (Reply 25):
Which one?
As far as I know, it's common (aerodynamically) back to at least the end of the windows. Structurally it's probably different but that makes no difference to looks or flight deck placement.
Tom.
DocLightning
Tue May 22, 2012 5:15 am
Quoting tdscanuck (Reply 29):
Which one?
I forget his name now. This was about five years ago.
-Doc Lightning-
-Carl Sagan
KELPkid
Tue May 22, 2012 6:14 pm
Tom.
IIRC, the radome is interchangeable between a '67 and a T7, too...someone correct me if I'm wrong
OldAeroGuy
Tue May 22, 2012 7:23 pm
Both of you are correct.
bigjku
Wed May 23, 2012 6:28 pm
Yeah, the A380 looks like it has a bloated head from the front. It is not the planes fault, form over function after all, but it is not a pretty thing to look at.
Euclid
Fri May 25, 2012 7:43 pm
Those pictures in Viscount724's post does raise a question. The last picture of the interior of the convertible 747 shows it in cargo config with a crew ladder for accessing the upper deck. I therefore assume that when configured for passengers, the upper deck was not used for passenger seating.
First of all, I'm sure no airline would allow passengers to climb a ladder to reach their seats, or did the conversion process somehow include a removable set of regular stairs?
Secondly, the upper deck on freighters are usually configured for the crew, galley, toilet, some seats, rest bunks and so forth, and I'm sure this was not converted to accommodate fare paying passengers each time the plane was converted from freighter to passenger.
So, in short, am I right in saying that the upper deck was not used for passengers even in passenger carrying config? Anyone?
Viscount724
Sat May 26, 2012 12:32 am
Quoting Euclid (Reply 34):
No, the normal stairway to the upper deck was installed when it was in all-passenger configuration and was removed (like the galleys, lavatories etc.) when converted to all-cargo configuration. That conversion was a pretty big job.
Euclid
Sat May 26, 2012 7:12 am
Many thanks for the answer. Absolutely amazing how clever these things were designed to make provision for both the ladder access in cargo config and stair access in passenger config.
CALTECH
Sat May 26, 2012 2:28 pm
That's correct. The 777 was the 767-X, until Boeing decided enough was changed that it deserved a new designation.
Quoting KELPkid (Reply 31):
Many things are interchangeable between the two, including at least the main gear tires of the 767-400 and 777-200.
Users browsing this forum: Armadillo1, Bing [Bot], Legs, Planesoul and 8 guests
