Shiny
Maximum Applicable Temperature On The Skin Of B737
Tue May 29, 2012 10:34 am
Good morning/afternoon/evening gentlemen,
while being a rookie here, I start with a concrete question:
I am currently working on some instructions for removal of advertising decals (3M film) from the tail of a B737. The normal removal procedure includes either a hot gun or steaming unit (to soften the film and make pulling it off possible).
I have hard time finding the maximum temperature that can be applied to the skin (without affecting surface integrity, paint etc.)?
Thank you in advance!
Tristarsteve
RE: Maximum Applicable Temperature On The Skin Of B737
Tue May 29, 2012 11:55 am
Well this is from the depths of my memory, so please check,
but Concorde had an aluminium body. In supersonic cruise the skin was heated by friction. There were temp sensors on the leading edge of the wing, and at 121 deg C they slowed the aircraft down to stop it getting hotter.
No idea where 121 deg came from, just something I recall (probably wrongly).
Shiny
Tue May 29, 2012 2:49 pm
Well, this is a good starting point, but does anyone have more accurate information specifically in reference to B737 or general public aircrafts? I failed finding one in the official 737 manuals I have (either don't have the right one or am being blind)...
n901wa
Tue May 29, 2012 4:42 pm
I am not 100% sure. But I think you might have to go to Boeing and get a EA to use that type of removal. I am not sure how Big the Ad will be on the Tail, or what type of 737, but if they go over Composite panels or on thr Rudder Heat might become a issue. I know on the Fues the 3M Decals I have seen are just applied and edge sealed. And when removed can just be carefully pulled off. I bet there is a Boeing Finishing Manual that is not covered in the AMM or Line Manuals. You might also want to check with 3M and see if they have a aproved process that Boeing have already bought of on for the product. HTH, and Good luck.
Shiny
Tue May 29, 2012 9:38 pm
I am actually creating the EO for removal in this particular case   3M refers to the aircraft manufacturer (of course... since the film is universal and can be applied on different aircrafts) for more information about maximum acceptable skin temperature.
I on the other hand fail to find this information from Boeing... I have a rough idea about what should be considered "acceptable" temperature, but since this is an official document, it should not be based on assumptions.
Other than that - 3M suggest using hot gun or steaming machine to soften the film before removal...
Chemicals can be used too but I am trying to avoid that. It is also less time efficient.
How is edge-sealing removed though, any idea?
Thanks to all!
tdscanuck
Wed May 30, 2012 1:59 am
Quoting Shiny (Reply 2):
A starting point would be the SRM; you definitely don't want to go over the cure temperature for the composite that you're working over. That's an upper bound though...the OEM may recommend a much lower threshold.
Quoting Shiny (Reply 4):
We use plastic scrapers.
Tom.
Shiny
Wed May 30, 2012 5:33 am
Yes of course.
I actually managed to find it (finally!)
The recommended temperature to heat up to is 120 F (~50°C)!
Thank you for your replies however!! Much appreciated!
Users browsing this forum: Bing [Bot] and 1 guest
