smartt1982
Flight Crew On O2 In Normal Ops
Thu Jun 14, 2012 9:09 pm
Does it still happen in airlines were if the other crew member needs to leave the Flight Deck for whatever reason the other crew member will don the O2 Mask if they are above FL250 just in case something happens?
I was told and again I do not know if it was true but on Concorde, because of the high levels they operated that one crew member would always have a mask around his neck just in case. I have watched a Concorde Cockpit DVD and did not see this at all.
Any ideas?
Bellerophon
RE: Flight Crew On O2 In Normal Ops
Thu Jun 14, 2012 10:42 pm
smartt1982
...I was told and again I do not know if it was true but on Concorde, because of the high levels they operated that one crew member would always have a mask around his neck just in case...
It wasn't true.
...I have watched a Concorde Cockpit DVD and did not see this at all...
I'm not surprised - it wasn't required and didn't happen!
Best Regards
Bellerophon
longhauler
Thu Jun 14, 2012 10:44 pm
Quoting smartt1982 (Thread starter):
This used to be the law in Canada. It is no longer required.
KAUSpilot
Fri Jun 15, 2012 6:19 am
It's true, above FL250 one pilot is supposed to don their O2 mask if the other pilot leaves the flight deck for any reason. Also, above FL410 one pilot is supposed to don their O2 mask and wear it at all times the aircraft is that high. That would explain why concorde pilots always had one guy on O2....they typically cruised well above FL410.
Concorde retired before I even started flying professionally, so I can't speak to whether or not they were exempt from these requirements.
The above apply to the FAA certificated carriers I've worked for; obviously, rules may be different elsewhere.
[Edited 2012-06-14 23:24:32]
Fri Jun 15, 2012 7:01 am
If there is a cabin crew in the flight deck,when a flt crew is out of the flight deck,does the 2nd flying member need to be wearing the O2 mask or have quick access to it.
KAUSpilot
Fri Jun 15, 2012 7:05 am
Quoting HAWK21M (Reply 4):
They are still required to don(wear) the O2 mask even if a cabin crewmember is accompanying them on the flight deck.
The thought process behind the rule is that if the one pilot on the flight deck does not don his mask quickly enough during a rapid depressurization, the flight may be doomed because the remaining pilot(s) are now locked out of the flight deck or stuck in a place in the cabin where they are connected to O2.
Got2fly
Fri Jun 15, 2012 9:21 am
We have no requirement to don O2 masks at my carrier. If one pilot needs to leave the flight deck during the flight the other just makes sure their seatbelt is fastened and if comms are on loud speaker they put their headset back on.
smartt1982
Fri Jun 15, 2012 9:28 am
Quoting KAUSpilot (Reply 3):
This is were I came across it, it was mentioned in the performance manual when it talked about the min amount of O2 for dispatch and the allowances for when this happened.
Is this still in the FAA Regs, I cannot seem to find it in EU OPs or CS25
Quoting KAUSpilot (Reply 5):
Would this still be the case if the cabin crew had been trained in the use of the Flight Deck O2? Is that not the reason that airlines have a cabin crew sit up front when a pilot has to step out? I guss it would cover both security as well as this safety issue with O2.
Bellerophon
Fri Jun 15, 2012 10:31 am
KAUSpilot
...That would explain why concorde pilots always had one guy on O2....
They did not.
As posted earlier, there was no such requirement on Concorde.
Those who operate under FAA regulations should be careful, when answering questions, not to inadvertently imply that FAA regulations apply to all aircraft and carriers, especially when the original poster is from the UK not the USA.
Many carriers operate under other regulatory bodies, with different requirements in many areas, and the O2 regulations are a good example of the sort of differences that exist.
Individual airlines are free to impose extra requirements should they wish, but under EU-OPS, provided a quick access mask is available, there is no requirement to don an O2 mask just because another pilot is leaving the flight deck, and neither is there an EU-OPS requirement for a cabin crew member to come to the flight deck whilst this happens.
Best Regards
Bellerophon
ThrottleHold
Fri Jun 15, 2012 1:00 pm
Only if a quick donning type O2 mask is not available.
longhauler
Fri Jun 15, 2012 2:06 pm
Quoting Bellerophon (Reply 11):
Many apologies for the multiple posting...I can't edit or remove them.
While I am certain it was in error, the multiple posting did hammer home a point I often have to make;
And that is, each governing body has different rules, and what applies to FAA, may not apply to other countries, regardless of where they fly.
AirlineCritic
Fri Jun 15, 2012 8:23 pm
There are a couple of very high airports. I wonder if landing in La Paz, Bolivia, the pilots have to be on oxygen. Here's a picture just before landing, still in air, cabin altitude being at almost four kilometers:
TupolevTu154
Fri Jun 15, 2012 8:53 pm
Quoting got2fly (Reply 6):
I suspect we work for the same airline
In the UK, there is no requirement for the remaining pilot to wear an oxygen mask when the other is outside the flight deck, nor is a member of the cabin crew required to be in the flight deck when there is only one pilot in there. As for this...
...in the UK, if the other pilot is locked out of the flight deck there are procedures in place to re-gain access (even if the pilot flying is incapacitated). They won't be "stuck" in a place in the cabin where there is oxygen, portable oxygen bottles are available for moving around the cabin.
In some cases one pilot will have to wear an oxygen mask for the cruise if it's above FL4something. I remember seeing a video with a captain of a global express (who is/was a member on the site?) explaining "coffin corner" (IIRC) at FL510, and the FO was on oxygen the whole time. Correct any of that if it's wrong but I'm pretty sure I remember seeing that video!
Actually here's the video: http://youtu.be/sQXJdacySRg
CosmicCruiser
Fri Jun 15, 2012 10:07 pm
Quoting ThrottleHold (Reply 9):
We are still required to put the mask on if the other pilot leaves his/her seat.
smartt1982
Fri Jun 15, 2012 10:13 pm
Quoting CosmicCruiser (Reply 13):
So this is an FAA reg?
Do guys/girls actually do this i.e. is it sticly adhered to or not?
CosmicCruiser
Sat Jun 16, 2012 2:09 am
Am I getting a check ride??
KAUSpilot
Sat Jun 16, 2012 3:34 am
Quoting Bellerophon (Reply 8):
Did you not see the disclaimer I put in my message? I explicitly said I don't know the rules for Concorde. Excuse me for trying to answer the rest of the question. Quite rude.
KAUSpilot
Sat Jun 16, 2012 3:36 am
Not true for the airlines I have worked for.
Quoting smartt1982 (Reply 7):
It does not matter how the flight attendants have been trained.
Sat Jun 16, 2012 10:02 am
Quoting longhauler (Reply 10):
Very true.....Differences exist.....
If Concorde is flying at Supersonic speed & there is a depressurization in the aft,shouldn't donning an O2 mask by crew at this phase of flight help.
Bellerophon
Sat Jun 16, 2012 7:37 pm
KAUSpilot
...I explicitly said I don't know the rules for Concorde. Excuse me for trying to answer the rest of the question. Quite rude...
In my first comment I was trying (politely) to point out that sometimes on this forum posters (not just you) respond to general technical questions from a purely USA/FAA point of view, which can sometimes mislead questioners who live in other parts of the world.
I included the word inadvertently in my post to make it clear I wasn't suggesting this was done deliberately or carelessly, but I did wonder whether you had noticed that the original poster came from the UK.
I also commented on your erroneous remark:
I was a little surprised that a professional pilot - who by their own admission has no experience of the Concorde operation or knowledge of the CAA regime she operated under - would feel able to post such a misleading remark on a topic they know little about, so I (again) made a comment that no such 02 mask procedure existed.
It is a matter of regret that you felt my comments were rude - I assure you that was not my intention - but I see nothing rude in either of them.
Best Regards
Bellerophon
airportugal310
Sat Jun 16, 2012 7:45 pm
Quoting Bellerophon (Reply 19):
From what I recall reading on here, you actually flew that airplane, right?
I sell airplanes and airplane accessories
Mon Jun 18, 2012 12:22 pm
All commercial aircraft would be using Quick donning type masks....
avioniker
Fri Jun 29, 2012 12:31 am
In case you werern't confused enough:
In the US
§ 121.333 Supplemental oxygen for emergency descent and for first aid; turbine engine powered airplanes with pressurized cabins.
(a) General. When operating a turbine engine powered airplane with a pressurized cabin, the certificate holder shall furnish oxygen and dispensing equipment to comply with paragraphs (b) through (e) of this section in the event of cabin pressurization failure.
(b) Crewmembers. When operating at flight altitudes above 10,000 feet, the certificate holder shall supply enough oxygen to comply with §121.329, but not less than a two-hour supply for each flight crewmember on flight deck duty. The required two hours supply is that quantity of oxygen necessary for a constant rate of descent from the airplane's maximum certificated operating altitude to 10,000 feet in ten minutes and followed by 110 minutes at 10,000 feet. The oxygen required in the event of cabin pressurization failure by §121.337 may be included in determining the supply required for flight crewmembers on flight deck duty.
(c) Use of oxygen masks by flight crewmembers. (1) When operating at flight altitudes above flight level 250, each flight crewmember on flight deck duty must be provided with an oxygen mask so designed that it can be rapidly placed on his face from its ready position, properly secured, sealed, and supplying oxygen upon demand; and so designed that after being placed on the face it does not prevent immediate communication between the flight crewmember and other crewmembers over the airplane intercommunication system. When it is not being used at flight altitudes above flight level 250, the oxygen mask must be kept in condition for ready use and located so as to be within the immediate reach of the flight crewmember while at his duty station.
(2) When operating at flight altitudes above flight level 250, one pilot at the controls of the airplane shall at all times wear and use an oxygen mask secured, sealed, and supplying oxygen, in accordance with the following:
(i) The one pilot need not wear and use an oxygen mask at or below the following flight levels if each flight crewmember on flight deck duty has a quick-donning type of oxygen mask that the certificate holder has shown can be placed on the face from its ready position, properly secured, sealed, and supplying oxygen upon demand, with one hand and within five seconds:
(A) For airplanes having a passenger seat configuration of more than 30 seats, excluding any required crewmember seat, or a payload capacity of more than 7,500 pounds, at or below flight level 410.
(B) For airplanes having a passenger seat configuration of less than 31 seats, excluding any required crewmember seat, and a payload capacity of 7,500 pounds or less, at or below flight level 350.
(ii) Whenever a quick-donning type of oxygen mask is to be used under this section, the certificate holder shall also show that the mask can be put on without disturbing eye glasses and without delaying the flight crewmember from proceeding with his assigned emergency duties. The oxygen mask after being put on must not prevent immediate communication between the flight crewmember and other crewmembers over the airplane intercommunication system.
(3) Notwithstanding paragraph (c)(2) of this section, if for any reason at any time it is necessary for one pilot to leave his station at the controls of the airplane when operating at flight altitudes above flight level 250, the remaining pilot at the controls shall put on and use his oxygen mask until the other pilot has returned to his duty station.
(4) Before the takeoff of a flight, each flight crewmember shall personally preflight his oxygen equipment to insure that the oxygen mask is functioning, fitted properly, and connected to appropriate supply terminals, and that the oxygen supply and pressure are adequate for use.
pilotpip
Tue Jul 03, 2012 5:13 pm
Quoting smartt1982 (Reply 14):
Yep
I do. It's a good wake up.
DMI
Tue Jul 03, 2012 5:20 pm
What about the FA in the Flight deck with the single pilot while the 2nd pilot is out of the cockpit....Will the mask be donned by both.
longhauler
Tue Jul 03, 2012 7:15 pm
Quoting HAWK21M (Reply 24):
For airlines that do that, no, normally the F/A does not wear an O2 mask. (Not every airline has an F/A in the cockpit when the pilot is alone.)
When it was required, we always did it. It was a rule that "made sense", you are alone in the cockpit, and if there is a rapid depressurization, its one less thing to worry about.
Seriously, I never really understood why that rule no longer existed.
Wed Jul 04, 2012 6:52 pm
Quoting longhauler (Reply 25):
Which regulatory are you reffering to.....
longhauler
Thu Jul 05, 2012 3:11 pm
Quoting HAWK21M (Reply 26):
I wasn't referring to any. Just stating that not every country's regulations require that a F/A be in the cockpit, when a pilot is alone. For example, in Canada, CARs so not require it.
Fri Jul 06, 2012 11:32 am
Quoting longhauler (Reply 27):
The requirement was for a safety reason.Any idea why Canada regulatory does not see its need.
longhauler
Fri Jul 06, 2012 1:38 pm
Quoting HAWK21M (Reply 28):
Safety, and security.
I agree with Transport Canada that the need no longer exists, and unfortunately as it goes into security issues I can not discuss them publicly. I can only say that not every airline has this exemption, and certain requirements must be met.
