b6a322
757 Series Numbers
Fri Jun 15, 2012 2:52 am
All,
A few questions regarding series numbers.
It seems that on a lot of threads discussing 757's that series numbers always come up. What are these and how are/were they determined? What are the differences between series? And, are there any other lines of planes (767's, 777's, etc.) that have series numbers?
The content I post are my own thoughts, nothing more. :)
IAHFLYR
RE: 757 Series Numbers
Fri Jun 15, 2012 4:36 pm
Are you asking about the specific airline code for each airframe (B757-224) or the different models of the B757 such as the B752 or B753, with the 2 or 3 being the model of the airframe?
KELPkid
Fri Jun 15, 2012 7:51 pm
-100 series: proposed, shortened version, never built or sold.
-200 series: the "strech" version, which is what all initial operators bought
-300 series: a stretch of the -200
Pretty simple
b6a322
Sat Jun 16, 2012 12:04 am
Maybe "Series numbers" isn't the best way to describe it.
It seems (especially when discussing Delta) people will refer to, say, the 5500 series.
That's what I am curious about
Viscount724
Sat Jun 16, 2012 1:12 am
Quoting B6A322 (Reply 3):
Those are just internal codes used by DL to identify aircraft with different configurations, equipment etc. They don't originate with Boeing.
asqx
Sat Jun 16, 2012 1:20 am
Within Delta there are 8 different configurations of 757-200. They can either be broken down by their designation, i.e. 757, 75A, 75E, 75J, 75M, 75N, 75V and 75X. Or as in the case of the pre merger Northwest planes they are also offen refered to by their tail number as "5500 series" or "5600 series", basically the 5500s have tail numbers 5501 thru 5534 (though many are missing having been retired or stored) and the 5600s have tail numbers from 5635 through 5657. The 5500 series are the older Northwest planes with the smaller door exit behind the wing and the 5600 series have exit rows over the wings.
Here's a basic run down of the Delta 757-200s, though I may be off on the number of each type in service:
757 is the 24/156 configuration. Aircraft are in the 600 number range, 51 in the fleet.
75A is the 24/150 configuration (was the 16/144 NW trans atlantic config). Aircraft in the 5600 range, 8 in the fleet.
75E is the 16/158 configuration with BizElite and AVOD/PTVs. Aircraft in the 6800 range, 17 in the fleet.
75J is the 20/159 configuration used for inter-Asia flights. Aircraft in the 5600 range, 8 in the fleet.
75M is the 22/159 configuration. Aircraft in the 5600 range, 7 in the fleet.
75N is the 22/160 configuration. Aircraft in the 5500 range, 14 in the fleet.
75V is the 22/153 configuration used for Hawaii flights. Aircraft in the 6900 range, 4 in the fleet.
75X is the 26/158 configuration with LiveTV and AVOD/PTVs. Aircraft in the 600 and 6700 ranges, 48 in the fleet.
b6a322
Sat Jun 16, 2012 5:30 pm
Quoting Viscount724 (Reply 4):
Quoting asqx (Reply 5):
This is exactly what I wanted to know! Thank you so much!
Users browsing this forum: gunsontheroof, mxaxai, republican, stackelberg and 1 guest
