smartt1982
50Ft Screen Height?
Fri Jun 15, 2012 10:00 pm
Can I just confirm, in relation to a 50FT screen height, this relates to the height of the main wheels above the threshold and not a 50ft eye height above the threshold?
In theory this should mean that Min Eye height above threshold (MEHT) for a PAPI should be able to accommodate the must crucial aircraft ie 747,A380 (where the pilots are much higher above the main gear) and still bring the aircrafts main gear 50ft above the threshold?
RE: 50Ft Screen Height?
Sat Jun 16, 2012 4:01 am
I would think it is 50ft on the altimeter. I think the altimeter is calibrated as equivalent to the height of fuselage somewhere but not sure.
Sat Jun 16, 2012 5:42 am
Quoting smartt1982 (Thread starter):
Actually it is neither, and a very messy complicated subject. It is actually known as the ILS reference datum for Facility Performance Categories II and III ILSs. For an aircraft, this datum is in reference to the receiver antenna. ICAO make the assumption that the difference between path of the aircraft glide path antenna and the path of the lowest part of the wheels at the threshold is assumed to be a maximum of of 5.8 m (19ft).
It gets messy as contrary to popular belief, glideslopes are not straight, they are normally slightly curved, and the ILS reference datum is based upon a obstacle clearance assessment of this curved glideslope after flight testing. It is the glideslode shape, and terrain from around 6000-1000 from from the runway that will determine the TCH.
A lot of work goes into this, as for a CAT 2 approach, the DH might be 50ft, and the aircraft needs to have the correct obstacle clearance.
tdscanuck
Sat Jun 16, 2012 3:31 pm
Quoting Starlionblue (Reply 1):
The radio altimeter is generally calibrated to be pretty close to wheel height above the ground at typical touchdown attitude...in other words, RA=0 should be when the wheels hit in a normal landing.
Tom.
Users browsing this forum: AAairplane, jownes, Stitch, Yahoo [Bot] and 2 guests
