trex8
Lufthansa 747-8 Fuel Burn
Tue Jun 19, 2012 10:19 pm
I can't find it on line but in the June 18 paper edition of AWST, pg 46 there is an article on the first 747-8 revenue flight. Fuel burn was 0.3% less than predicted and 3% less than LH expected for a 744 flying the same mission. There was a thread a few weeks ago , which unfortunately I can't seem to find now. IIRC people were saying there were reports the 747-8 was burning 10% less fuel than a 744. Even with the anticipated 2014 improvements in weight and engine PIP etc, is it really realistic to see a 10% improvement if LH are only seeing 3% with their first plane?
Stitch
RE: Lufthansa 747-8 Fuel Burn
Tue Jun 19, 2012 10:27 pm
Quoting trex8 (Thread starter):
Projected fuel burn savings are between 10 and 15%.
The following was reported for the inaugural FRA-IAD flight (LH416) on 01 June.
378t TOW
296t LW
50t Payload (313 passengers and 20 crew)
80t Trip Fuel Burn
7h58m Trip Time
Midway through the flight, while cruising at 36,000ft, Capt Boje reported a combined fuel flow of 9.6t/h (at M0.843) from the four General Electric GEnx engines, with a ground speed of 479kt (886km/h) and a 20kt headwind.
SEPilot
Tue Jun 19, 2012 10:31 pm
Quoting Stitch (Reply 1):
Is this per trip or per seat?
vin2basketball
Tue Jun 19, 2012 10:34 pm
Fuel burn per seat can be easily 10-12% lower on 748i vs. 747-400.
Let's take nominal fuel burn as 3% less.
Then Lufthansa's 744s seat on avg ~350 seats (3 configs @ 322, 353, and 370 seats, I averaged out the 3), so that's a 10.3% advantage for the 748 in # of seats. That works out to a 12.5% advantage in fuel burn per sear for the 747-8i
LAXDESI
Tue Jun 19, 2012 10:48 pm
Quoting vin2basketball (Reply 3):
Using the 323 seat 744 configuration as a base, which is closer to 748 configuration in terms of seat pitch and , premium to economy seat distribution, 748 has about 12.4% more seats. Assuming 3% lower trip fuel burn, early LH B748 is about 15% lower fuel burn per seat than its B744.
Does anyone have cabin area numbers for 744 and 748?
Stitch
Tue Jun 19, 2012 10:50 pm
Quoting LAXDESI (Reply 4):
B747-400: 372.0 sq meters (per Widebodyphotog)
B747-8: 444.6 sq meters (per Boeing)
LAXDESI
Tue Jun 19, 2012 11:02 pm
Quoting Stitch (Reply 5):
Thanks. Going by above numbers, B748's cabin is about 19.5% larger. It seems that LH B748(362 seats) is not as densely configured as its B744(322 seats), as it has only about 12.5% more seats.
Stitch
Tue Jun 19, 2012 11:17 pm
Quoting LAXDESI (Reply 6):
Which roughly tracks with LH's fuel burn analysis of 3.8 liters per 100 passenger kilometers on the 362-seat 747-8 compared to 4.2 liters per 100 passenger kilometers for the 344-seat 747-400 - a 10% reduction.
[Edited 2012-06-19 17:02:58]
LAXDESI
Tue Jun 19, 2012 11:36 pm
Quoting Stitch (Reply 7):
The 747-8 is 386 seats: 8F / 80C / 298Y
Seatguru must be in error as it shows 8F/92J/262Y.
The closest 747-400 config would be the 322-seat version at 8F / 80C / 234Y, so the difference would be 27% more seats, all of them Economy.
Thanks. If trip fuel burn is 3% less as per OP, then the early LH B748 has 30% lower seat fuel burn than B744.
Need more confirmation on trip fuel burn.
Aviaco
Tue Jun 19, 2012 11:46 pm
8F/92J/262Y is correct.
ikramerica
Tue Jun 19, 2012 11:51 pm
While it's not out of line to think a new design can fly the same mission with 12-20% more seats and using less total fuel, it's a testament to the engineers at Boeing and GE that the 2nd major overhaul of a 40+ year old frame can achieve the same outcome.
Stitch
Tue Jun 19, 2012 11:59 pm
Quoting LAXDESI (Reply 8):
SeatGuru is correct. Wikipedia is not (until I edit the page, at least).
trex8
Wed Jun 20, 2012 12:26 am
Got it, so on a per trip basis it may be 3% but on a per seat its 10%+. Whats the per seat fuel burn for a 77W vs 744?
roseflyer
Wed Jun 20, 2012 12:31 am
I think the premium heavy configuration of the 747-8 makes it hard to compare. The 747-8 has the same number of first and business class seats as the A380 in LH configuration. That really skews the numbers in the fuel burn per seat. LH also has multiple 747-400 configurations. If comparing trip fuel burn, a good guess can be made, but it is still really hard to compare and know what the assumptions are. This is basically true whenever comparing models. In general the 747-8F and 747-8I have very similar fuel burn on a trip basis than their 747-400 counterparts, but the -8s have higher payload to make up for it.
nycdave
Wed Jun 20, 2012 1:08 am
So, in terms of fuel relative to floor space... the early 748 is doing almost an 18% improvement over the 744, meaning about that amount improvement per seat, if outfitted at the same density. Easy to see the later line numbers come out over 20%. Very impressive improvement, Boeing (and LH) should be quite happy.
LAXDESI
Wed Jun 20, 2012 3:37 am
Quoting nycdave (Reply 14):
The LH 748 is actually doing 22.5% better than 744 on fuel per cabin space metric(19.5% +3%). Impressive.
A "mature" B748 should be able to achieve 25%+ lower fuel burn per seat, if the 3% lower trip fuel number in OP is correct.
The spec. MTOW of 748 is about 13% higher than that of 744. A 3% lower trip fuel burn for 748 seems plausible.
seabosdca
Wed Jun 20, 2012 4:31 am
Quoting LAXDESI (Reply 15):
And yet it still can't compete with the A380. We've come a long way in 20 years!
LAXDESI
Wed Jun 20, 2012 5:39 am
Quoting seabosdca (Reply 16):
Quoting LAXDESI (Reply 15):A "mature" B748 should be able to achieve 25%+ lower fuel burn per seat, if the 3% lower trip fuel number in OP is correct.
On many routes, where A380 is too much capacity, B748 is likely to be more profitable as it has 20 % lower trip fuel burn on a 6,000 nm mission(see example below). LH has stated that it sees a role for both B748 and A380, and one is more profitable than the other depending on the route..
An old thread where I compared the A388 to B748.
A388 Versus B748 Economic Analysis (by LAXDESI Jul 26 2008 in Tech Ops)
Quoting LAXDESI (Reply 18):
For a 6,000 nm trip,
A388 burns 53,007 gallons, carries 90,469 lbs. cargo, GSM .0168, GTM 0.0968
B748 burns 42,397 gallons, carries 84,050 lbs. cargo, GSM .0174, GTM 0.0919
A388 burns additional 10,610 gallons at a cost of $42,000
A388 earns additional $84,000 (120 seats X 70% LF X $1,000) in seat revenues.
A388 earns additional $5,000 (6,419 lbs. X 50% LF X $1.5) in cargo revenue.
The net trip advantage to A388 is $47,000--about $17 million annually.
sweair
Wed Jun 20, 2012 8:31 am
in 2014 LH said they will get the mature frame, how much weight will be taken out and will the MTOW stay as it is? The engines should be near spec with the PIP as well.
I think the 748 will be a very good aircraft if you have the need for belly cargo and not 100% filled cabin. The freighter is said to fly 134t as far as the 744 freighter can fly 124t?
nomadd22
Wed Jun 20, 2012 3:28 pm
Quoting LAXDESI (Reply 17):
I'm not sure what that's suppose to prove. It's just saying that more passengers and more cargo make you more money. That would be true no matter what planes you were comparing. As far as fuel use, the 748 is a clear winner in fuel used per cargo and about even per passenger.
Anon
WingedMigrator
Wed Jun 20, 2012 3:57 pm
Careful with percentages! If the 748 is 1.195 times bigger and uses 0.97 times the fuel, then the 744 has 1.232 - 1.0 = 23% higher fuel burn per seat than the 748, but the 748 has 1.0 - (1/1.232) = 1.0 - 0.812 = 18.8% lower fuel burn per seat than the 744. So the LH 748 is doing 18.8% better, not 22.5% better than the 744.
Linear approximations are only valid for small percentages, which I suppose is a testament to the step change in performance that the 748 brings.
Stitch
Wed Jun 20, 2012 4:01 pm
It would be a sad commentary on Airbus if the A380-800 wasn't better than the 747-8 considering they started clean-sheet and with a larger airframe.
Quoting sweair (Reply 18):
Estimates are Boeing is working to remove around 2.5 metric tons of weight (so about 5000 pounds). Once the plane is at design weight, fuel burn should improve between 0.5 and 1.0 percent.
LAXDESI
Wed Jun 20, 2012 5:46 pm
Quoting WingedMigrator (Reply 20):
You are right, it is 18.8% better. Thanks for catching my mistake. Hopefully, a mature B748 delivers about 20% lower seat fuel burn.
Quoting nomadd22 (Reply 19):
One is better over the other depending on the route.
A380 is better than B748 where A380 is not too much capacity. LH is deploying B748 to IAD, which suggests that currently A380 may be too much capacity for IAD.
sweair
Wed Jun 20, 2012 8:17 pm
If Boeing manages to get weight out of the frame and keep the MTOW this is all "free" payload right? 3-4tons more payload cant be that bad? If the current 748 can take on 4t more fuel, what will that do for range?
LAXDESI
Thu Jun 21, 2012 4:31 am
LH configuration for B748 and A388:
B748................8F/92J/262Y
A388................8F/98J/420Y
A388 has an additional 6J and 158Y seats over B748, for a total of 164 seats, which is a lot more than 120 seats that I assumed in my example in reply # 17.
Using additional 164 seats(and not 120) in that example should change the annual operating advantage of A388 over B748 to nearly $28 million(from $17 million).
Does anyone have cabin area numbers for A388?
Thu Jun 21, 2012 9:50 am
Keep in mind the age of the 744 and 748, a brand new 744 would probably do over 3% better than a 15 year old 744 airframe.
That has been the industry trend for some time, more space to premium products, and the inclusion of premium economy products.
Quoting LAXDESI (Reply 22):
I believe from August 1, IAD will be a LH A380 route.
wilco737
Thu Jun 21, 2012 11:41 am
Quoting zeke (Reply 25):
Almost, it is IAH, Houston which starts August 1st with A388.
wilco737
Stitch
Thu Jun 21, 2012 3:09 pm
Quoting LAXDESI (Reply 24):
600m2 per Airbus
WingedMigrator
Thu Jun 21, 2012 3:39 pm
Quoting Stitch (Reply 27):
600m2 per Airbus
I have 552 m2 of usable floor area, a figure that I think originally came from widebodyphotog. I was able to verify this to within a couple of percent using the ACAP dimensions.
LAXDESI
Thu Jun 21, 2012 4:53 pm
Quoting LAXDESI (Reply 24):Does anyone have cabin area numbers for A388?
600m2 per Airbus
Going by the above numbers, A388 has 35% more cabin area.
Quoting WingedMigrator (Reply 28):
Widebody has 427 sq meter for B748.
Going by the above numbers, A388 has 29% more usable area.
LH A388 has 45% more seats than B748, but B748 is, proportionally speaking, premium heavy. LH B748, with 20% premium seats as LH A388, should end up with:
B748................8F/74J/322Y for a total of 404 seats.
As LH A388(526 seats) is wider than B748, it loses some of the cabin area to wider seats/aisles, and ends up with 30% more seats in comparable LH configuration.
[Edited 2012-06-21 10:00:44]
sunrisevalley
Fri Jun 22, 2012 1:31 am
The 499k airspeed, is this typical cruise speed?
I find this thing about fuel burn per seat mile to be rather incomplete . I much prefer fuel burn per unit of payload which contributes to calculating the fuel cost toward the total cost per available unit of payload.
in this instance 80t of fuel for 50t of payload is 1.6t fuel per tonne of payload. Of interest is comparing this specific flight to an A380 with the same payload and flight time. From PIANO-X for a 292t OEW A380 with a 50t payload and 8hrs flight time the fuel burn would have been 96t , just on 20% more . Certainly a 50t payload appears to be a sweet spot for the 748i. It would be interesting to interpolate this higher to see about where the 748i and A380 get close to converging.
Fri Jun 22, 2012 1:56 am
Quoting sunrisevalley (Reply 30):
M0.843 at FL360 is a TAS of 484 kt, something does not look right with the numbers. 499 kts at FL360 is M0.87, the quoted speeds make more sense for FL300.
sweair
Fri Jun 22, 2012 9:15 am
What would 5000 pounds less structural weight do for range? If that would be fuel loaded?
Fri Jun 22, 2012 9:32 am
Quoting sweair (Reply 32):
I would guess around 100 nm.
sunrisevalley
Fri Jun 22, 2012 3:26 pm
The following was reported for the inaugural FRA-IAD flight (LH416) on 01 June.378t TOW296t LW50t Payload (313 passengers and 20 crew)80t Trip Fuel Burn7h58m Trip Time
Checking this back from TOW, assuming the burn was ~87% of the fuel load ( this is what it was for the A380 example in reply 30) then fuel load was 92t , then deduct the payload of 50t (378-92-50) gives a DOW of 236t.If the spread between OEW and DOW is about 8t , then the OEW is about 228t. considerably more than the about 216t shown on the Dec 2011 General Characteristics sheets in the ACAP documents. Something is not making sense.
Stitch
Fri Jun 22, 2012 3:49 pm
Quoting sunrisevalley (Reply 34):
LH's premium cabin product should be significantly heavier than what Boeing uses in their OEM configuration so even with 90 less Economy seats, I would expect the OEW of LH's birds to be significantly higher than 216t.
sunrisevalley
Fri Jun 22, 2012 7:22 pm
Quoting Stitch (Reply 35):
This seems likely. Compared to the A380 OEW spread from 292 to 299t and assuming LH is at the high end of the spread , then add ~7t , then add weight to get to DOW so 228t seems possible.
Users browsing this forum: GoSteelers, TZTriStar500, WPvsMW, YaCy [Bot] and 2 guests
