Mortyman
Why Do Airbus Aircraft Seem To Be Kneeling?
Fri Jun 22, 2012 1:21 am
Stupid question perhaps, but ...
Why do Airbus aircraft seem to kneel in front ?
Is it because of weight ?
TWA772LR
RE: Why Do Airbus Aircraft Seem To Be Kneeling?
Fri Jun 22, 2012 1:40 am
Optical illusion? Side-note, it also looks like that on the 764ER.
"It's not getting to the land of the nonrev that's the problem, it's getting back." ~~Captain Hector Barbossa
Kermode
Fri Jun 22, 2012 1:42 am
It's funny you should say that. I always see 737's as "kneeling" so to speak.
Photo © Dejan Milinkovic - Pixstel Photography
Photo © Mats Salder
Having said that, I would agree with you on A330's, i always saw that about them. Hopefully someone know's more than we do.
mpdpilot
Fri Jun 22, 2012 1:47 am
i can't speak for the A380 pictured but the A330 does actually lean forward on the ground, it is because of this that with the A330F they had to lengthen the nose gear to level it out for freight pallets, hence the bubble under the nose to accomodate the larger landing gear.
It isn't that un common for aircraft on the ground to kneel as you say. Look at the CRJ700 and CRJ900 they kneel by almost a full 5 degrees.
One mile of highway gets you one mile, one mile of runway gets you anywhere.
cargolex
Fri Jun 22, 2012 1:52 am
I don't know the reason for the A330/A340's nose-down stance, but it is significantly more pronounced than that of the 737, and represents a MAJOR challenge for the A330 freighter conversion program, and is why the production A330-200 freighter has the modified nose (to provide a level main deck).
3DoorsDown
Fri Jun 22, 2012 2:16 am
Bowing to Boeing. What else could it be?
TWA772LR
Fri Jun 22, 2012 2:17 am
Quoting 3DoorsDown (Reply 5):
Best thing I've heard all day!
Viscount724
Fri Jun 22, 2012 2:58 am
Quoting Kermode (Reply 2):
That's only noticeable on the 737NG which, if memory correct, has slightly taller main landing gear struts than earlier 737 models.
SESGDL
Fri Jun 22, 2012 3:04 am
Quoting Viscount724 (Reply 7):
The 737-200 leans forward as well, as do many other airplane types, such as the MD-80/90.
Jeremy
gigneil
Fri Jun 22, 2012 4:16 am
The definitive nose-down aoa does in fact help the aircraft get off the ground at a lower speed, from what i've been told.
NS
CZ346
Fri Jun 22, 2012 4:46 am
Quoting TWA772LR (Reply 6):
I was going to say "It's because the suck" but bowing to Boeing is totally acceptable!
Mir
Fri Jun 22, 2012 5:06 am
Quoting cargolex (Reply 4):
IIRC, it's because they used the same (shorter) nose gear from the A300 but different (higher) main gear, presumably to compensate for larger engines on the 330. Thus, the slightly nose-down pitch on the ground.
It makes sense from an engineering perspective - why would you bother with a longer nose gear (more weight, takes up more space) just to have the cabin perfectly flat?
-Mir
Max Q
Fri Jun 22, 2012 5:09 am
Quoting gigneil (Reply 9):
Wadrs that does not make any sense.
spacecadet
Fri Jun 22, 2012 5:40 am
Gotta have something to do with the relationship between cruise attitude and ground/takeoff/landing attitude. The wing cord is fixed - wings don't move in flight, so the only way to adjust their position into the wind while on the ground is through overall attitude.
Most airplanes are designed to cruise at a 2-3 degree nose-up attitude. My guess is that to design a wing for best efficiency at cruise just required a slight nose-down attitude on the ground.
Would love to hear someone with more technical knowledge than I have, but that'd be my guess.
maxpower1954
Fri Jun 22, 2012 7:48 am
You guys - any jet transport from the 707/DC-8 on up has a slight negative attitude on the the ground to improve braking and nose wheel steering action on landing and during a rejected take-off.
[Edited 2012-06-22 00:54:14]
masi1157
Fri Jun 22, 2012 8:35 am
Quoting Mir (Reply 11):
The nose landing gears are definitely not the same. Compare these photos:
A330:
Photo © Didier JH Goursolas
A300:
Photo © Jin Kim
I also seem to remember that Airbus did not anticipate this nose down attitude (so it was a kind of design mistake) and that they had a lot of problems with e.g. the water/waste system.
Regards, masi1157
481 different segments on 95 airlines to 199 airports in 54 countries
LH422
Fri Jun 22, 2012 9:27 am
Quoting mpdpilot (Reply 3):
Here's a picture of that:
Photo © Stephan Kruse
Fri Jun 22, 2012 9:56 am
IIRC this is correct.
Quoting spacecadet (Reply 13):
I don't think that's it.
Faro
Fri Jun 22, 2012 10:49 am
Lower airspeed or shorter takeoff run? I'd like to have that one explained...negative AoA = less (wing and/or fuselage?) drag on acceleration to Vr?...Seems counter-intuitive...
Faro
The chalice not my son
tdscanuck
Fri Jun 22, 2012 12:08 pm
Quoting Max Q (Reply 12):
Wing incidence angle is fixed by cruise configuration. If you raise the nose in ground attitude you increase the wing AoA during the takeoff roll, which leads to more induced drag. You want minimum drag during the roll so you can get up to speed in the shortest distance, then rotate to start generating lift.
It's not so much about having a negative AoA (that would actually push the airplane down into the ground, which is also bad), it's about reducing the positive AoA during the takeoff roll.
Tim.
DarkSnowyNight
Fri Jun 22, 2012 5:02 pm
Quoting maxpower1954 (Reply 14):
Not true. The E170 has a very pronounced nose up stance. Less noticeable but still there just the same are the 757, 767-300, Dash 8 100 - 300, & CRJ-200 families. As well, many aircraft in the Tupolev and Illyusion families are oriented this way.
As well, any airbus narrowbody, but especially the 321, can actually go from one to the other depending on loading. It is a matter of routine to observe the NLG struts extend a good six - ten inches as the aircraft is de-barked and unloaded.
Quoting tdscanuck (Reply 19):
That certainly makes sense, but what are the design advantages that support the opposite tendencies in some of the aircraft I've mentioned above? While I can't guess there would be much there aerodynamically speaking, perhaps is it a manufacturing or weight benefit to build them that way at times?
Much like a GE90, I'm a huge fan of Big Twins...
tdscanuck
Fri Jun 22, 2012 6:22 pm
Quoting Darksnowynight (Reply 20):
It all depends on how the wing incidence angle plays out on the ground. If an airplane has a more nose-up design cruise attitude that would drive into a more nose-up ground attitude (for equal takeoff drag). There's also a trade between nose gear size/weight and wing drag that probably changes depending on the intended takeoff performance.
Tom.
roseflyer
Fri Jun 22, 2012 7:02 pm
When loaded, the DC10 had a nose up attitude on the ground. The DC10 also has the nose gear mounted further aft than most airplanes.
While that is true, I believe the nose down attitude is moreso important for braking distance. Less lift means more weight on wheels, which shortens RTO and brake distances. It presents a problem for the MAX.
timz
Sat Jun 23, 2012 8:20 pm
It hasn't been settled whether Boeing fuselages are pointed downward on the runway. Can we assume the cabin floor is parallel to the centerline of the fuselage? Can we assume the door sill is level with the floor? Can we assume Boeing floors don't curve upward toward the rear of the aircraft?
If so, then the 767-400 nose is a bit lower than the tail, but the 767-300 nose isn't. So maybe the -400 floor does curve?
tdscanuck
Sat Jun 23, 2012 8:36 pm
Quoting timz (Reply 23):
The standard ground attitude is listed in the maintenance manuals for every aircraft. I haven't looked up the widebodies but the 737NG is about 1.5 degrees nose-down if the gear is properly serviced and everything is normal. Exact attitude will vary with weight, CG, strut pressure, and tire pressure.
Yes, it is.
Yes, it is.
Correct, they're flat all the way back.
Tom.
Viscount724
Sat Jun 23, 2012 9:48 pm
764 has a completely new main landing gear 18 inches taller than the 763, while the nose gear is basically the same. That's why the 764 sits slightly nose-down. Following excerpt from a document on the Boeing website describing the 764.
The stretched fuselage significantly reduced the rotation attitude of the airplane during takeoff and landing. The reduced body angles resulted in undesirable effects on takeoff field length and approach speeds.
Boeing resolved this situation by incorporating an all-new landing gear that is 18 in (46 cm) taller than the existing gear. The wheels, tires, and brakes are identical to those on the 777. The new gear features 50-in (127-cm) radial tires, compared to 46-in (117-cm) diameter bias ply tires on the 767-300ER. Fitting this larger rolling stock into the existing wheel well caused relocation of most of the hydraulic lines and a shift in the wing-mounted trunnion of 10 in (25 cm) outboard and 4 in (10 cm) downward. The nose landing gear is basically unchanged except for strengthening to accommodate the increased gross weight of the 767-400ER.
nomadd22
Sun Jun 24, 2012 12:26 am
Quoting tdscanuck (Reply 24):
After about 30 seconds of highly questionable math done in my head after looking at a photo of a 738 and guessing at the distance involved, I'm getting about half that 1.5 degrees disappearing because of the longer nose gear on the Max.
Anon
my235
Mon Jun 25, 2012 3:21 pm
Airbuses also seem to be trimmed back more (nose up pitch) when on short final.
okees
Tue Jun 26, 2012 1:29 pm
I seem to remember a discussion similar to this on here a few years ago, and someone said it had to do with landing, apparently the slight slant helps "plant" the aircraft firmly on the ground when it lands, something to do with the angle providing sufficient air pressure on top of the wings to push the air frame downwards a bit. I could be way off, but this is what I remember.
mobs jakis
roseflyer
Tue Jun 26, 2012 6:52 pm
Quoting okees (Reply 28):
That is correct. When all wheels are on the ground a nose down attitude decreases lift from the wing, which increases force of the tires on the pavement and improves braking. Ground spoilers significantly reduce lift, but any addition lift removed from the wing will shorten the braking distance.
bikerthai
Tue Jun 26, 2012 7:11 pm
As Tom pointed out, the 737 NG is nose down. The angle of incident depends on the length of the aircraft. The -500 would have the most nose down angle.
Yes, but I think you really meant fuselage water line.
At the small negative angle involved, the wing still provides lift. Specially if you deploy the flaps at takeoff and landing. You don't really pushes the air downward, rather you remove lift from the wing . . . which is the purpose of the spoilers.
Of all the reason noted above, I see weight is the only logical reason for the length of the nose gear, and cruise efficiency determines the fuselage to wing angle. And the two don't necessary coincide. That is why some plane may nose down on the ground an nose up at cruise.
bt
roseflyer
Tue Jun 26, 2012 9:56 pm
Quoting bikerthai (Reply 30):
There are more reasons that determine nose and main gear length. Engine clearance height and cargo door loading height are important. One look at the 777-300ER versus 777-300 nose landing gear will show how different the height and design can be based on takeoff weight. Under low loading conditions, the 777-300ER nose gear extends 10 inches, to maintain rear cargo bin height and a level floor.
amccann
Wed Jun 27, 2012 4:18 am
I'd imagine it is safe to say that Airbus did not change the wing incidence angle for the A330F but did however change the positioning of the nose landing gear. This new nose landing gear position drives the takeoff roll AOA and landing rollout AOA of the A330F (freighter) to values higher than that of the A330 (passenger). I'd love to know how this has effected takeoff and landing distances of the freighter. Of course to answer the question we would have to have some sort of controlled environment including similarly loaded airplanes (weight and cg) and similar operating environments.
What one person receives without working for, another person must work for without receiving. - Ronald Reagan
speedygonzales
Wed Jun 27, 2012 8:45 am
Quoting amccann (Reply 32):
Airbus shows the same take-off and landing performance for all three A330 variants, so the differences should be quite small.
http://www.airbus.com/fileadmin/medi...h_data/AC/Airbus-AC_A330_Dec11.pdf
Ignorance kills. :tombstone:
Users browsing this forum: Afstand, sharles and 3 guests
