PHX787
Higher/lower Altitudes And Fuel Burn
Wed Jun 27, 2012 6:43 am
Simple question: when it comes to fuel efficiency, is it preferred to be at a higher altitude (FL37+) or a lower altitude (FL32-) to have better fuel efficiency, or in between?
Does anybody have any stats for ULH planes (747, 777, A340, A380) and their fuel burn in comparison to altitude?
Thanks, Z
AF1624
RE: Higher/lower Altitudes And Fuel Burn
Wed Jun 27, 2012 7:14 am
It strictly depends on gross weight, CG, temperature and winds.
The FMC (on aircraft equipped with it) will work out an optimum altitude depending on these factors + some others.
As a rule of thumb, higher altitude = thinner air + lower temperature = lower fuel burn
BUT
If the aircraft is too heavy, higher altitude = thinner air = higher angle of attack to keep level flight = higher fuel burn
AND of course winds play a big part in it.
That's pretty much how it works.
Usually, an airliner will do step climbs. i.e. start cruising at FL350, and then as fuel levels diminish weight decreases so 370, then 390, then 410.
CosmicCruiser
Wed Jun 27, 2012 1:11 pm
Our dispatchers also plot say 4 routes and altitudes and choose route/altitude based on the best for time and or fuel burn depending on what's most important for that flight.
Mir
Wed Jun 27, 2012 11:53 pm
It is, in general, better to be higher. However, if you're too heavy for a certain altitude, then you'll burn more fuel than you would if you stayed lower down until you became light enough to climb up. Aircraft will have an optimum altitude for a particular weight, and and significant deviation from that will result in higher fuel burn. The optimum altitude will increase over the course of the flight as the aircraft burns off fuel and becomes lighter.
-Mir
Users browsing this forum: XAMTO and 2 guests
