TWA772LR
763: Blended Winglets Vs. Raked Wingtips
Thu Jun 28, 2012 1:37 am
The 763 is certified for blended winglets, but not raked wingtips. I know winglets are more efficient below 10,000 feet on things such as take off and approach as they decrease wingtip vortexes. Wingtips are better at cruise altitudes, which is why the 77L, 77W, 764, and 787 have them. If a 763 flies similar missions (long haul) as the previous stated aircraft, then why dont they have raked wingtips installed instead? Can you not retrofit those? Or do more 763s operate shorter missions that would constitute blended winglets instead? I have heard on a.net that these winglets weigh in the ballpark of 400 lbs. and have caused strain on the wings and wingboxes of some 763s.
"It's not getting to the land of the nonrev that's the problem, it's getting back." ~~Captain Hector Barbossa
The thoughts and opinions shared under this username are mine and don't necessarily reflect those of my employer.
817Dreamliiner
RE: 763: Blended Winglets Vs. Raked Wingtips
Thu Jun 28, 2012 1:59 am
Quoting TWA772LR (Thread starter):
The raked wingtips cant be retrofitted. The aircraft you mention were all designed with the raked wingtips onto the wing, including the P-8, the 763 is an older design which came before the raked wingtip design came about on the 764. The raked wingtips would require significant reinforcement of the wing due to increase in bending force from the increased span, therefore adding weight onto the wing. the strain on the wing from winglets is mitigated by these additional strengthening at the tip, but it wouldnt add as much weight.
I'll wake from the dream, To keep and relive, Now life it is a dream, And dream's on a... BREAK!
TWA772LR
Thu Jun 28, 2012 2:03 am
Quoting 817Dreamliiner (Reply 1):
That's what I was thinking but I wasn't entirely sure. I would never have thought that raked wingtips cause the wing to bend as much as you are making it sound, but you learn something new everyday. Thanks for the info!
tdscanuck
Thu Jun 28, 2012 11:09 am
Raked tips do the same thing. They're different mechanical means of achieving the same aerodynamic end.
Those aircraft have raked tips because they don't operated in span-restricted gates or hangers; raked wingtips are always better aerodynamically if you can fit them.
Tips are much harder to retrofit.
You can, but not without significant extra work beyond what a winglet would require.
Tom.
bikerthai
Thu Jun 28, 2012 4:40 pm
Quoting TWA772LR (Reply 2):
This is because with the wing tip, the load is in the vertical direction and you have a large moment arm with the length of the wing causing large bending moments. I.E. P X L = M. Where P is small but L = large. You can push/pull up/down on the tip of the wing and get the wing to bend up and down.
With the winglet the load is sideways, so the moment at the wing root is smaller. P is small and H is small.
You can do the experiment yourself with a 2X4 and put a L bracket on one end.
bt
sweair
Fri Jun 29, 2012 10:57 am
cargo planes should not be as limited for wing clearance? Will the AF tankers get the raked tips?
tdscanuck
Fri Jun 29, 2012 4:39 pm
Quoting sweair (Reply 5):
That's generally true but it's been a looooooong time since anyone designed a large commercial cargo plane from scratch...they're almost always derivatives of passenger models.
It all depends if they're getting a structurally tweaked wing or not. With the original 767-200/300 wing, I doubt it. With the -400ER wing, maybe.
Tom.
flyboy80
Thu Jul 05, 2012 10:40 pm
Ive always been under the assumption the 400 shares the same wing as the 200/300 with the addition of the raked wingtips- could someone clarify please?
Viscount724
Fri Jul 06, 2012 11:27 am
Quoting flyboy80 (Reply 7):
I've always been under the assumption the 400 shares the same wing as the 200/300 with the addition of the raked wingtips- could someone clarify please?
Correct. Excerpt from Boeing document with detailed description of the -400 and changes from previous models:
Raked (swept-back) wingtips have been added to improve the overall aerodynamic efficiency of the wing. They help reduce takeoff field length, increase climb performance, and reduce fuel burn. The new tips are 7 ft 8 in (2.34 m) long and are an all-composite structure, with an aluminum leading edge for erosion protection. Dispatch with the raked tips removed will be allowed in accordance with the configuration deviation list. The raked tips require the addition of new position lights on the aft end of section 48.
SXDFC
Wed Jul 11, 2012 5:34 am
Quoting Viscount724 (Reply 8):
So could a customer order a BRAND NEW 767-300ER from the factory with raked wingtips?
Although a bit off topic, lets say WN or any other 737 customer wanted to buy a 737 with raked wingtips ( since its already on the 737-800 ( P-8 Poseidon ) airframe, could they be able to do so as well?
817Dreamliiner
Wed Jul 11, 2012 10:36 pm
Quoting SXDFC (Reply 9):
Nope, It would need to be certified fr the 300 series.
Nope, same as above. Boeing would need to certify a passenger version of the P-8.
Users browsing this forum: akiss20, cerealspiller and 11 guests
