History Of The RB211-535E4-C
Fri Jul 06, 2012 11:23 am
Anyone having data on the history of the RB211-535E4 -C.
747classic
RE: History Of The RB211-535E4-C
Mon Jul 09, 2012 9:22 am
The -535E4-C-37 engine is similar to the -535E4-B-37, but it incorporates various modifications to
permit a takeoff "bump" rating at a range of ambient conditions at an altitude of 620 ft., for better T/O performance, especially at low level conditions. The -535E4-C-37 was added to TCDS on June 22, 2001.
To be specific :
RB211-535E4-B-37 Max T/O thrust :
ISA+10o at sea level, linear
variation between ISA+10oC and ISA+13.9oC between sea level and
4,000 ft, ISA +13.9ºC between 4,000ft and 10,000ft, linear variation
between ISA +13.9ºC and 20ºC between 10,000ft and 12,500ft.
RB211-535E4-C-37 Max T/O thrust :
ISA +12.5ºC at sea level, linear variation between ISA +12.5ºC and
ISA +16.2ºC between sea level and 420ft, ISA + 16.2ºC between
420ft and 820ft, linear variation between ISA +16.2ºC and ISA
+12.9ºC between 820ft and 1,200ft, linear variation between ISA
+12.9ºC and ISA +13.9ºC between 1,200ft and 4,000ft, ISA
+13.9ºC between 4,000ft and 10,000ft, linear variation between ISA
+13.9ºC and ISA +20ºC between 10,000ft and 12,500ft, ISA +20ºC
between 12,500ft and 15,000ft.
See RB211 TCDS : http://rgl.faa.gov/Regulatory_and_Gu...076b73f/$FILE/E12EU%20Rev%2025.pdf
[Edited 2012-07-09 02:52:22]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Mon Jul 09, 2012 10:12 am
Educational......Any idea on what type was the -E4-C used on.......Im aware of the B752s with RB211-535C AND RB211-535E4.
747classic
Mon Jul 09, 2012 11:00 am
According the latest 757 TCDS (rev. 30) the RB211-535E4-C37 is only certified on the 757-300 series.
See page 1- 4/10 : http://rgl.faa.gov/Regulatory_and_Gu...006a2097/$FILE/A2NM%20Rev%2030.pdf
Mon Jul 09, 2012 6:45 pm
Anyone aware of the practical use of this type ie -E4C on the B753....was it ever used....I've heard of the -E4B being used though.....
747400sp
Tue Jul 10, 2012 12:17 am
I believe, this was a 43000 lb version, of the Rolls Royce RB211-535.
TZTriStar500
Tue Jul 10, 2012 3:04 am
The -535E4C was developed for ATA-American Trans Air and used exclusively on their then 12 757-33Ns that started being delivered in August 2001. Greater performance was needed to optimally operate the 757-300 out of Chicago Midway airport MDW. Once ATA filed bankruptcy in October 2004 and the remaining 757-300s started being used for charter only, I believe they were derated and intermixed with E4Bs. Now that UA (CO) has taken over all 12 -33Ns, I believe the E4Cs are no longer maintained or used on these aircraft at all as the extra performance is not needed.
35 years of American Trans Air/ATA Airlines, 1973-2008. A great little airline that will not be soon forgotten.
Wed Jul 11, 2012 8:16 am
Quoting TZTriStar500 (Reply 6):
Then why did RR stop at the E4c & not upgrade further to maybe an E4D....was there no requirement.
TZTriStar500
Thu Jul 12, 2012 2:58 am
Quoting HAWK21M (Reply 7):
I think you answered your question...there is basically no need for a further performance upgrade as the E4C was a special case in itself. Also, with the 757 out of production, there is no market.
Users browsing this forum: Starlionblue and 2 guests
