1337Delta764
RR BR715 (717) Thrust Reversers Question
Wed Jul 11, 2012 10:18 pm
I have a question about the thrust reversers on the RR BR715 engines on the 717. The BR715s on the 717 use clamshell thrust reversers, unlike most high-bypass turbofans which use cascade reversers. What is the reason for this?
I am pretty sure that on low-bypass engines, cascade reversers would not be possible, but what advantage does clamshell thrust reversers have over cascade for high-bypass engines?
Mir
RE: RR BR715 (717) Thrust Reversers Question
Wed Jul 11, 2012 10:38 pm
Clamshell reversers are more effective, since they direct the whole exhaust rather than just the bypass. But they're difficult to do when engines are mounted on the wings due to ground clearance and the presence of the wing itself.
Since the 717 has its engines mounted on the fuselage with no opportunity for disruption from the wing, clamshell reversers are the logical choice.
-Mir
Viscount724
Wed Jul 11, 2012 10:39 pm
Quoting 1337Delta764 (Thread starter):
The JT3D, a low-bypass turbofan, as used on the DC-8-50 and -61 series, had cascade reversers.
1337Delta764
Wed Jul 11, 2012 10:56 pm
Quoting Mir (Reply 1):
-Mir
The MD-90 (which has tail-mounted engines) has cascade reversers, and the 737 Jurassic (which has wing-mounted engines) has clamshell reversers. I don't see what you mean here.
NWADC9
Wed Jul 11, 2012 11:44 pm
Quoting 1337Delta764 (Reply 3):
They're the same IAE engines used on the A32X. Doubt they would engineer a different thrust reversing system for a specific aircraft type that decided to be the oddball.
The clamshell doors are aft of the wing, not under it.
I get paid to convert dead dino juice into noise.
1337Delta764
Thu Jul 12, 2012 12:12 am
Quoting NWADC9 (Reply 4):
Interesting though that CFM used target-type (flower petal) thrust reversers on the A320 family and first-gen A340, while they used cascade reversers on the 737. I'm guessing the reason for using cascade reversers on the 737 might be due to ground clearance. I wonder what will the LEAP-1A engines on the A320neo will use.
Mir
Thu Jul 12, 2012 12:23 am
The engines were already designed with cascade reversers - it's not worth redoing the design for just one aircraft type.
And that's only possible because the engine passed all the way underneath the wing, and they were able to rotate it enough to get the appropriate ground clearance. Not something you could reproduce on a modern design.
-Mir
Users browsing this forum: Afstand and 1 guest
