PHX787
787 Thrust Reverser Question
Thu Jul 12, 2012 1:05 am
Hi all, ran a search, couldn't find much on it
Photo © Charles Cunliffe - ReaperPhotography
How does that thrust reverser work? It looks almost seamless. Does the entire cowling move back when the thrust reverser is activated?
Thanks, Z
817Dreamliiner
RE: 787 Thrust Reverser Question
Thu Jul 12, 2012 1:30 am
Im not sure how much plane spotting youve done, but to answer your question, other aircraft have similar thrust reverse systems so its not really new:
Photo © Gianni Deligny
It works by diverting the air being drawn in by the fan outside the core, out through that opening when the cowling slides back. Also yes the back part of the cowling slides back entirely.
This should help give a basic idea if you dont understand:
http://en.wikipedia.org/wiki/Thrust_reversal
[Edited 2012-07-11 18:33:20]
yeelep
Thu Jul 12, 2012 2:40 am
Its a translating sleeve/cascade type T/R, very common. When the sleeve translates aft there are blocker doors that move into the fan bypass airflow to redirect it through the cascades ( the black parts you can see in the OP pict.).
jetmech
Thu Jul 12, 2012 3:19 am
Quoting PHX787 (Thread starter):
Quoting yeelep (Reply 2):
It works as illustrated in the following diagram.
This arrangement is very similar to that I've seen on many CF6's. Some of the earlier RB211's had a slightly different design where the blocker doors were actuated by pushrods instead.
http://www.youtube.com/watch?v=bvpj1BV-sCk
http://www.youtube.com/watch?v=dZ-wh8Kuh1M
Regards, JetMech
PHX787
Sat Jul 14, 2012 6:50 pm
Quoting 817Dreamliiner (Reply 1):
Not much where I'm up and close to the planes
Quoting jetmech (Reply 3):
That's what I was looking for. Thanks!
I've seen thrust reversers operate on the A343 and the A320 for example which the cowling opens outward and that diverts the thrust but i wasn't sure how this one worked.
817Dreamliiner
Sat Jul 14, 2012 10:36 pm
Quoting PHX787 (Reply 4):
Have you tried using the search function or even google? This answer would have been there.
AA737-823
Tue Jul 17, 2012 1:47 am
Those are called pivot-doors. They're lighter weight than the translating cowl, because there are far fewer parts, and also fewer actuators. A CFM-56 on a 737 has six actuators, three for each cowl half, while the CFM on an A320 has just four, one for each pivot door.
Quoting 817Dreamliiner (Reply 5):
You're quite the rude snob today, aren't you? If you don't have anything nice to say..... as the saying goes.
For reference, all in-production Boeing aircraft use this design. Many Airbus do as well, though the Rolls on the 333, and the CFM on the 320 use the pivot doors.
817Dreamliiner
Tue Jul 17, 2012 2:03 am
Quoting AA737-823 (Reply 6):
I didnt say anything mean, I was only suggesting that he should have done a search before asking such a question. The forums here has a good amount of information regarding different aspects of aviation, in this case the tech/ops forum would have something related to thrust reversers that has been previously discussed. Even if he didnt find anything here, he could have used a search engine like google to find what he needed. If you didnt like how I answered then thats just your problem. Theres nothing wrong with telling someone to do a google search.
Polot
Tue Jul 17, 2012 3:02 am
What is the disadvantage with them then? If they are lighter and perform equally I would figure that all new designs would have this type of reverse thrust design. It can't be just a patent issue in Boeing's case, Airbus used the cowl type for the A380 on both engine types.
BoeEngr
Tue Jul 17, 2012 3:07 am
If a Tech/Ops forum on an aviation site is not the place to ask technical questions about aviation, we're all in trouble...
bikerthai
Tue Jul 17, 2012 1:30 pm
Quoting 817Dreamliiner (Reply 7):
Often times, it is easier and faster to ask the guys who know then try to find it on the web.
Quoting poLOT (Reply 8):
The disadvantage is that the doors are not as efficient in diverting the flow. The cascades provide more control in where you want to direct the reversed flow.
The picture that jetmech showed did not show the different angles to which the cascade direct the flow. Along the circumference of the nacelles, the cascades direct the flow in different direction. In one or two area, the cascades are actually blocked off to prevent the flow from impinging on the aircraft (body or wheels) or blow air in front of the airplane where FOD may get ingested back into the engines.
Also, I am not sure if the pivoting doors close out as much fan air as the cascade type doors. If someone have an axial view of a pivoting door compared to translating cowl doors deployed, it may be useful.
bt
tdscanuck
Tue Jul 17, 2012 5:09 pm
Cascade reversers provide better reverse thrust performance and scale up better. If you use petal reversers (aka pivot reversers) and you want to go up to 777 size you're pretty much screwed. Using cascade reversers across the board means you're just working with one design (this may be a legacy from Boeing having a centralized nacelle design group for all models for a long time).
Tom.
PHX787
Wed Jul 18, 2012 7:08 pm
Montserrat? How is it?
Quoting bikerthai (Reply 10):
That might explain why the AF343 that was landing at CVG used the entire runway, but the DL777 at CVG used about half of it, while landing (back when both of those planes operated at CVG) I get it. Thanks!
bikerthai
Wed Jul 18, 2012 9:59 pm
Quoting PHX787 (Reply 12):
There may be more issue involved with the example you gave (Landing weight of aircraft, 4 smaller engines vs 2 larger engines, how good were the brakes etc.) .
bt
DocLightning
Wed Jul 18, 2012 11:48 pm
Quoting tdscanuck (Reply 11):
The A330 Trent 700s (which aren't *that* much smaller than on the 777) use them. I wonder why?
-Doc Lightning-
-Carl Sagan
Thu Jul 19, 2012 12:37 am
Probably not due to reversers. Brakes and landing weight have a far bigger effect.
tdscanuck
Thu Jul 19, 2012 3:00 am
Quoting DocLightning (Reply 14):
RR has a long history of doing their own nacelles, unlike the other two engine makers. Did they do the A330 nacelle? That may be a contributor but I don't know why they would have chosen that trade.
Tom.
DocLightning
Thu Jul 19, 2012 6:22 am
Quoting tdscanuck (Reply 16):
The Trent 700 nacelle is of a classic Trent design with the the bypass duct running the full length of the engine.
Photo © Alexander K.
This shows the general arrangement with the clamshell doors clearly visible. I can't find one with them deployed.
-Doc Lightning-
-Carl Sagan
bikerthai
Thu Jul 19, 2012 1:53 pm
Aren't some of the A380 T/R the doors type also? And they also only have two engines with reverser.
As we all know, the TR are not essential for certification of the aircraft.
So, basically you are trading the cost/efficiency of the doors vs the wear and tear on the brakes. Someone would have to dig up the brake replacement cycle of a door T/R aircraft vs a cascades TR aircraft and work out the various cost involved . . . along with the weight delta, fuel burn impact, maintenance etc . . .
bt
DocLightning
Thu Jul 19, 2012 3:26 pm
Quoting bikerthai (Reply 18):
AFAIK, both RR and EA engines on the A380 are the petal-type.
Photo © Mark McGrath
Photo © Olmo Müller
RR on the left, EA on the right
-Doc Lightning-
-Carl Sagan
bikerthai
Thu Jul 19, 2012 3:48 pm
Quoting DocLightning (Reply 19):
Hum, if you are right, then there may be something about the cascades type being more efficient if it was used exclusively on the A380 (because the outboard engines do not have T/R).
bt
DocLightning
Thu Jul 19, 2012 4:01 pm
Quoting bikerthai (Reply 20):
Not sure that's the reason. I suspect ground clearance is a bigger issue.
-Doc Lightning-
-Carl Sagan
Gatorman96
Thu Jul 19, 2012 4:40 pm
bt
BT,
I believe the A380 doesn't have outboard T/R's because the engines hang over the width of the runway in many cases. If they did, they could kick up FOD into the inboard engines and wings.
bikerthai
Thu Jul 19, 2012 6:46 pm
Quoting Gatorman96 (Reply 22):
Understood. My inference is because it doesn't have the outboard T/R, it then have to go to a more efficient design for the inboard T/R to make up some of the difference.
Quoting DocLightning (Reply 21):
Could be . . .
But from this angle on a different airplane, its seems that you can design a door that will open and not extend beyond the lower part of the nacelle.
http://en.wikipedia.org/wiki/File:Easyjet_thrust_reversers_arp.jpg
Then again, you lose efficiency.
This is a great shot of how a cascade type door, blocks the whole fan duct.
http://www.flickr.com/photos/wbaiv/2736667356/
I can't seem to find a comparable picture of one for the door type.
bt
tdscanuck
Thu Jul 19, 2012 9:03 pm
The pictures in your post clearly show cascade reversers, not petal reversers.
Tom.
jetmech
Fri Jul 20, 2012 3:07 am
Quoting DocLightning (Reply 17):
Quoting bikerthai (Reply 23):
There actually appears to be quite a few gaps with the deployed petal type TR.
Photo © Brandon Archer
Regards, JetMech
bikerthai
Fri Jul 20, 2012 1:44 pm
Quoting jetmech (Reply 25):
Good picture.
That's what I'm thinking. Although they may be able to optimize the coverage by locating the gap at the struts support and cutting the internal blocking skin to fit.
Would like to see inside the duct itself to be sure.
bt
DocLightning
Fri Jul 20, 2012 8:06 pm
Quoting tdscanuck (Reply 24):
Sorry! I meant to say "cascade."
-Doc Lightning-
-Carl Sagan
Users browsing this forum: qf789, TOGA10 and 14 guests
