bellancacf
Any Interactive Airfoil Analysis Progs Showing L+D
Sun Jul 22, 2012 10:20 pm
There seem to be plenty of interactive airfoil analysis programs online that show upper and lower airfoil surface pressure profiles as a function of alpha, but I was hoping to find one that would show the vector for the force resulting from placing an airfoil into a free stream: I'd like to be able to vary alpha and the airfoil. Extra points for showing the normal to the chord line so that there's a meaningful visual reference as the incidence and the direction of the resultant change.
Is there a program out there that displays actual data obtained with physical airfoil models?
And out of curiosity -- not having searched for the answer -- how does one go about collecting such data?
tdscanuck
RE: Any Interactive Airfoil Analysis Progs Showing L+D
Sun Jul 22, 2012 11:12 pm
Quoting bellancacf (Thread starter):
I'm not sure if there's one that actually draws the force vector, but there are several that give you the Lift/Drag coefficients so you can back out what the force vector must be. NASA has a bunch of fun free stuff:
http://www.grc.nasa.gov/WWW/k-12/freesoftware_page.htm
Those would be more databases than programs. University of Illinois maintains a wonderful site that has 1500+ airfoils and links to a bunch of solvers that can give you the theoretical data (which is very good for many of them). For well established famlies like the NACA airfoils the actual physical data is also available:
http://naca.larc.nasa.gov/search.jsp...976&qs=N%3D4294868711%2B4294448803
Wind tunnels. Lots and lots of wind tunnels.
Tom.
bellancacf
Mon Jul 23, 2012 12:11 am
re tdscanuck@1: Wind tunnels. Lots and lots of wind tunnels.
Thanks for that info, Tom. Maybe I'll stumble across something in Python and, oh, Qt that someone doesn't mind sharing. That would be a good motivator to learn something about Python and graphics.
But what's been wrinkling my brow is whether it's done with levers and weights, for instance, or force transducers or what and in what geometry. I'd be lucky to come up with what the Wright brothers did in their shop if I tried to do it myself.
[Edited 2012-07-22 17:13:11]
BMI727
Mon Jul 23, 2012 12:13 am
Try XFLR5. It's really for designing model planes, but it might give you what you want.
bellancacf
Mon Jul 23, 2012 12:21 am
Quoting BMI727 (Reply 3):
Try XFLR5
Thanks for that. I've downloaded the files and will take a look. I may be able to exhume my measurements of Bellanca's airfoil for the C.F -- a strange, extraordinary, undercambered, reflexed beast -- and feed that in.
BMI727
Mon Jul 23, 2012 12:44 am
Quoting bellancacf (Reply 4):
If you know the section you can use the UIUC airfoil database to download the nondimensionalised coordinates and feed that into the program.
tdscanuck
Mon Jul 23, 2012 1:05 am
Quoting bellancacf (Reply 2):
Sorry, I didn't realize you were going for the technical details.
For 2D airfoils, you can get excellent drag data without any force measurement at all; you just run a solid airfoil all the way across the tunnel and then use a pressure rake (a big array of pitot tubes that looks like a garden rake) to measure the momentum deficit in the wake across the tunnel.
For lift and moment measurements, you use some kind of force measuring device. The device is called the "balance" in wind tunnel parlance. You mount your test specimen to the balance, fire up the tunnel, and directly measure the forces and torques. Good balances have adjustable joints so you can vary angle of attack. Modern balances are all finely calibrated multi-axis load cells. Here's an example:
http://www.mmtool.com/balances.html
There's *ton* of calibration and correction, especially on transsonic tunnels, to turn the raw balance data into actual coefficients.
Tom.
bellancacf
Mon Jul 23, 2012 1:50 am
re tdscanuck@6:
Tom, thanks a lot for taking your time to answer in such detail. That mmtool balance reminds me of instances when, to get something done in the lab, I would have to chase deeper and deeper into a corporation, finally arriving at, almost always, a single person who knew how to do it and in fact usually had pretty much done it all by himself. (Males in the cases I remember, but over in electron microscopy, there was a good chance it'd be one devoted, skilled woman.) I used to wander out into the office saying, "Technology is so d**ned THIN! Wherever you look, it comes down to just one person." So blasted fragile, too, and so hard to re-establish or reinvent once the chain is broken.
jetmech
Mon Jul 23, 2012 1:55 am
A program that seems to be used a lot for calculating static pressure distributions and force coefficients for airfoil sections is X-foil;
http://web.mit.edu/drela/Public/web/xfoil/
It's free and once you get it to work, it appears to provide answers that are good enough for inclusion in research papers.
Quoting tdscanuck (Reply 6):
Just to add to Tom's post. You can also get lift, pressure drag and moment coefficients by measuring the static pressure distribution about the airfoil and integrating the results with respect to the chord (for lift) and "height" (for pressure drag) of the airfoil. This method does not capture the skin friction component of drag. To get the total drag of a 2D airfoil (pressure and skin friction) you need to use a wake rake as mentioned by Tom.
The benefit of the static pressure method is that you can actually see the shape of the pressure distribution about the airfoil, and pick out such features as the location of separation. A balance once setup however, is generally much quicker if you are just after the force coefficients.
A whole science in itself!
Regards, JetMech
Mon Jul 23, 2012 1:59 am
I would suggest eppler or xfoil. Xfoil from what I have seen is available on unix, windows, and Mac.
Guess it depend on what you mean by interactive. If you have matlab you will find code on the net that also does it on that.
tdscanuck
Mon Jul 23, 2012 2:03 am
Quoting jetmech (Reply 8):
A few months ago I found a book on clearance at the MIT bookstore that was a collection of NACA papers on transsonic wind tunnel design, with an introduction by Von Karman (yes, *that* Von Karman). My head nearly exploded.
Tom.
bellancacf
Mon Jul 23, 2012 2:29 am
re JetMech@8: You can also get lift, pressure drag and moment coefficients by measuring the static pressure distribution about the airfoil and integrating the results with respect to the chord (for lift) and "height" (for pressure drag) of the airfoil.
I'd been wondering about that. I realized I didn't know whether I had to integrate over the chord length (a lot of identical delta-lengths) or take the slope of the airfoil surface into account (secant(slope-sub-i) * delta-length). How does that work? And the drag calculation? Is this, at each station, the height above and normal to the chord line of the airfoil surface regardless of alpha?
Sorry to ask this kind of question, but it's this or get lost in stuff I'm almost certain not to understand . . . :-]
tdscanuck
Mon Jul 23, 2012 10:33 am
Quoting bellancacf (Reply 11):
You do need to take the slope of the surface into account, although you can do that at two different places.
If you're going for lift directly, you can just take the delta length at each station projected onto the line parallel to the free-stream; that will give you the component of pressure force normal to the freestream (definition of lift). Adding up all those little components will give you lift. You can do the same thing for drag by projecting the delta length onto a line normal to the free stream.
However, you can be more general and just stay in vectors. The pressure force on each delta length acts normal to the surface at that point. That gives you a bunch of tiny little vectors that you can just directly add to get the total force on the airfoil, at which point you can resolve that force into lift/drag or any other axis you want.
Height above will matter for moment calculations but not for drag; drag just cares about normal to the freestream (not the same as normal to the chordline). The chordline is often used as the reference zero for alpha measurement but it doesn't have to be. You need to know alpha to get the transformation from airfoil coordinates (what the pressure probes are measuring) to freestream coordinates.
Tom.
jetmech
Mon Jul 23, 2012 10:52 am
Lift is calculated by plotting the non-dimensional static pressure (Cp) vs. the non-dimensional chordwise location (x/c) of the pressure tapping as below. This distance is non-dimensionalised by the chord length, so it varies from 0 to 1
http://i94.photobucket.com/albums/l118/Jet-Mech/Cd2.jpg
The area inside the curve, which is found by integration, is the normal force coefficient (Cn), the normal force being that perpendicular to the chord line regardless of angle of attack. Pressure drag is calculated by plotting the non-dimensional static pressure (Cp) vs. the non-dimensional location above or below the chord line (y/c) of the pressure tapping as below. This distance is non-dimensionalised by the chord length, so it varies from 0 to some positive and negative non zero number depending on the section thickness
http://i94.photobucket.com/albums/l118/Jet-Mech/cd-1.jpg
The area inside the curve, which is found by integration, is the tangential force coefficient (Ct), the tangential force being that parallel to the chord line regardless of angle of attack. My integration gives Cn as 0.4006 and Ct as -0.02732.
Once you have Cn and Ct, you resolve trigonometrically using the angle of attack (a) to get the lift (Cl) and pressure drag (Cdp) coefficients as below.
Cl = Cn cos(a) - Ct sin(a)
Cdp = Cn sin(a) + Ct cos(a)
The pressure distributions shown were taken at an angle of attack of 4 degrees, thus using the above; I get Cl as 0.402 and Cdp as 0.001.
Anytime the pressure coefficient curve crosses over itself, such as the Cp vs. y/c example above, the alternate closed areas will make positive and negative contributions to either the normal or tangential force coefficient. Such crossing over occurs much more frequently for the Cp vs. y/c curve.
Regards, JetMech
bellancacf
Mon Jul 23, 2012 3:53 pm
re Tom and JetMech:
Thanks!! Now I have something to think about! This is a real treat!
jetmech
Wed Jul 25, 2012 1:46 am
Quoting tdscanuck (Reply 10):
I thought it was an important subject! Do you know if it is possible to use adaptive wall wind tunnels for transonic testing? I get the felling it may be tricky achieving transonic velocities with the added complexity of the divergent / convergent shape of an adaptive wall.
Regards, JetMech
tdscanuck
Wed Jul 25, 2012 12:11 pm
Quoting jetmech (Reply 15):
Anything's possible but I think you'd need a really cool control system to keep the tunnel stable. And I don't even have the foggiest clue as to how to approach figuring out the tunnel corrections for a dynamically moving wall.
Tom.
Wed Jul 25, 2012 1:04 pm
That sort of work has been done, the application is in the engine intake design of many military aircraft.
jetmech
Wed Jul 25, 2012 11:46 pm
Quoting zeke (Reply 17):
No doubt. I think there are differences however.
From what I understand, the inlets of many supersonic aircraft are designed to provide subsonic air to the face of the engine in the most efficient manner possible. The focus is thus on efficient deceleration. Concorde uses oblique shocks to slow down and compress the air prior to entering the engine. The trick is the fine adjustment of the intake ramps to achieve the desired shock pattern.
Adaptive wall wind tunnels - for 2 dimensional airfoil testing at least - is all about capturing a given streamline, and is focussed much less on acceleration or deceleration of the air velocity. The problem is, for a fixed angle of attack, adjustment of the walls to capture the desired streamline will as a side effect, change the velocity of the air as well, which then may go on to change the streamline pattern.
This may present additional problems for transonic testing; as changes in the adaptive wall could also change the locations where the flow field transitions from sub to supersonic and vice versa. Achieving and maintaining a desired test-point may involve much time consuming iteration.
Regards, JetMech
Users browsing this forum: Acey, Google Adsense [Bot] and 22 guests
