EBGflyer
What 737 Does UA Use On EWR-LAX?
Wed Jul 25, 2012 7:52 am
Will be flying from EWR to LAX with UA next month and wondering what equipment they will be using. FlightAware shows a mix between 735, 738 and 739. As I cannot see what version of the 738 and the 739 they are using, I was wondering where I can look up historical registration data. AFAIK I cannot see this in Flightaware. Or can I?
Future flights: CPH-BOS; CPH-SVG; CPH-PVG-HKG-MNL-DVO; CPH-CDG; CPH-NRT; CPH-MIA; CPH-PVG
IAHFLYR
RE: What 737 Does UA Use On EWR-LAX?
Wed Jul 25, 2012 10:39 am
Flightaware from time to time has incorrect aircraft types, your best bet is to look at the United website for the day of travel and see what you find for the aircraft shown at this time.
LHRBFSTrident
Wed Jul 25, 2012 7:07 pm
Quoting IAHFLYR (Reply 1):
I agree - the UA website is usually reliable when it comes to the a/c type.
I doubt the 737-500 is accurate! It appears to be 738s and 739s on EWR-LAX depending on the flight: the seat map for your flight is usually the definitive way to verify the planned a/c type.
For historical information, you can check the flight status page at UA.com and plug in your flight number (assuming it's currently in use operating the same service) to check what's currently flying that service, +/- a day or two: one of the best features is that it displays the tail number so you can verify the actual ship used/planned.
KELPkid
Wed Jul 25, 2012 8:15 pm
Quoting EBGflyer (Thread starter):
The 737-500 doesn't have the range to do this without a tech stop or an extremely limited load
roseflyer
Wed Jul 25, 2012 9:32 pm
For UA, flightaware typically shows all flights as being operated by 735s until actual departure time and then it switches. It is an easy mistake.
AA737-823
Sat Aug 11, 2012 11:01 am
Have you checked your reservation? United isn't cryptic about what aircraft you're booked on... it's plainly listed in your reservation....
onebadlt123
Mon Aug 13, 2012 3:18 pm
You will never be on a 735 from EWR-LAX. It's impossible for the aircraft to make it.
9 times out of 10 it will be a 738 or a high number 739. Once a while, you may get the random 752 but not likley
Users browsing this forum: flymia, MPadhi, mwalker89, retiredmx, Starlionblue and 3 guests
