justloveplanes
Bubble Antenna On UA 737 Fuselage
Wed Aug 01, 2012 2:51 pm
I noticed on UA/PMCO 737's there is what appears to be an antenna or radome about 3/4's of the way back on the top fuselage. Looks about 6 feet in diameter
Is this the Direct TV antenna, and if so, what kind of aero penalty does this impart?
AirframeAS
RE: Bubble Antenna On UA 737 Fuselage
Wed Aug 01, 2012 4:13 pm
It's a LiveTV satellite. The same equipment atop the F9 Airbuses.
B6JFKH81
Wed Aug 01, 2012 8:59 pm
Quoting AirframeAS (Reply 1):
I thought the LiveTV setup was a little (not much) different on the B737's than the A320s? Last time I was down in MCO at the LiveTV warehouse, I was surprised at how large the LiveTV radome was compared to the ones on our aircraft. I think the CO birds have the same one as the Virgin Blue and WestJet planes:
Photo © Martin Eadie
Photo © Darren Wilson
Sat Aug 04, 2012 10:13 am
Whats the load penalty post installation of the antenna?.
AirframeAS
Sun Aug 05, 2012 3:21 am
Quoting B6JFKH81 (Reply 2):
The only thing that is different is the brace that is used to attach all the fittings to the fuselage given that the outside diameter between the 737's and the A320's are quite different.
Quoting HAWK21M (Reply 3):
No clue, but I do know that there is some fuel penalty involved no matter what. I am assuming it is not much.
aeroweanie
Sun Aug 05, 2012 6:02 am
JetBlue, WestJet and Continental (United) aircraft all have the same LiveTV dome installed. On Australia's east coast, they have trouble "seeing" the LiveTV satellites, so the Vifgin Blue aircraft have the "high-gain" antenna which requires a bigger dome.
Mon Aug 06, 2012 10:26 am
Quoting AirframeAS (Reply 4):
Considering the area covered & location,it would be quite some penalty.
Users browsing this forum: PSAjet17 and 19 guests
