dlramp4life
747 Towbar Question...
Thu Aug 02, 2012 12:24 am
I came across this picture from DEN.. While looking at the picture I got confused because the towbar looks to long and skinny for a 747, looks a 757 towbar...
Every 747 towbar I have seen is short and fat like this one
http://www.aerogse.com/product_images/l/15F2342-Aircraft-Towbar-B747-1.jpg
How can this towbar push a 747? I thought every widebody towbar what short in length and wide in width to help with the narrow turn radius... Any thoughts?
SEA Ramp, wettest place on earth
tdscanuck
RE: 747 Towbar Question...
Thu Aug 02, 2012 3:01 am
Quoting dlramp4life (Thread starter):
F=ma. As long as the towbar hooks up and the tug driver doesn't bust the shear fitting, you push almost anything with anything.
There are short fat ones and long skinny ones; the major meaningful difference between towbars is the shear fitting. You can always use a weaker towbar (e.g. 757 towbar on a 747) as long as the tug driver knows what they're doing and the discrepancy isn't too large. You can go the other way (e.g. 747 towbar on a 757) but you run a non-trivial risk of damaging the landing gear if you do that.
Tom.
ak907
Thu Aug 02, 2012 5:38 am
That picture of the yellow tow bar is the same one we have at work. Great model btw. A longer tow bar makes it easier to keep the nose wheel straight, because of the further distance between the two points. Also, in your example, the 747 uses a different connector than other planes. Most planes, from I know including the 757, 767, 777, MD10 and MD11, use a bar and clamp type system, while the 747 uses a two hole and two pin type system. The two are not interchangeable. Shear pins are just regular bolts designed to break at a specific force. Most tow bars have two shear bolts. Attached is a picture of the same towbar. http://www.airliners.net/uf/163172/phpmgWCXp.jpeg
Sat Aug 04, 2012 10:14 am
Thats an optional towbar...As long as its approved for the type & loads encountered , it should work fine.
AA737-823
Sat Aug 11, 2012 11:00 am
The one we used to push 747F's was much longer than even the top one you've pictured.
Built like a tank, too.... made things nice n easy, and visible.
The shorter the towbar, the closer you are to the skin of the 747 nose, which reduces visibility.
Sat Aug 11, 2012 11:15 am
Quoting AA737-823 (Reply 4):
Also gets the fuselage nearer the Tow truck,can be critical in case of smaller Aircraft like A320/B737s.
dlramp4life
Sat Aug 11, 2012 7:27 pm
But the turning radius of a widebody is not that big, you really don't have to turn the plane far before "redline" the nose gear. A smaller towbar on a widebody gives the driver better control of the aircraft.
Sun Aug 12, 2012 11:00 am
Quoting dlramp4life (Reply 6):
In comparison.....the TBL is the best as long as the Brakes are not jammed during pushback,then the Towbar is preffered
AA737-823
Sun Aug 12, 2012 11:50 am
Having pushed both 747s and 737s, I disagree. A short towbar doesn't do anything for me.
Maybe it's just personal preference.
DC8FriendShip
Tue Aug 14, 2012 5:03 pm
The lencth of the towbar makes a negligable difference on an aircraft that size. Try towing a Cessna with a towbar longer than the wheelbase, Thats a Challenge!
BTW the 747 can be towed from either fwd or aft sides of the nose gear.
Come fly the Friendly Skies of United
CALTECH
Fri Aug 17, 2012 5:51 pm
B-52 towbars were some of the longest IIRC, about 47 feet long or so.
UNITED Would Be Nice
Sat Aug 18, 2012 5:13 pm
Quoting CALTECH (Reply 10):
mes:
Remember the AN124 tow bar....in two pieces.
CALTECH
Sat Aug 18, 2012 6:00 pm
Quoting HAWK21M (Reply 11):
Oh yeah. Another monster towbar.
Tue Aug 21, 2012 10:23 am
The AN124 folks need a team to assemble.....Pushback .....Disconnect....Disassemble....Reload back into the Aircraft ....close the Aft ramp door & taxi out......
The Towbar is carried on board.....
Users browsing this forum: jakubz and 9 guests
