JSpos
Expense Calculations For Airline Startup
Thu Aug 02, 2012 7:06 pm
Hello,
I'm doing research for an Airline Startup concept I have. I am an Entrepreneur in the Memphis area, and the airline would be based in Memphis TN.
I'm presently seeking candidates for an advisory board to test the feasibility of my business plan and I'm also looking for some general advice for formulas and rules of thumb.
1. I would like to plan around a single airframe - any advice about lease cost vs. efficiency vs. availability. (More than just "stay away from MD-80s" or "there are plenty of inexpensive A319s available" but more details, like X plane is less expensive to lease but more expensive to run, and harder to maintain - but Y plane will save you over the long run.")
I"m looking for a 125-175 single class cabin.
2. Is there a formula to expense maintenance over the life of a plane? (i.e. "Expect X cost per 1000 cycles")
3. What is the minimum crew per plane on a single route? Right now I'm figuring 2 pilots, 2 attendants, 2 gate, 4 baggage, 4 line, and 4 cleaners (ground crew listed represents each end of the run. Of course, at the hub I would think I'd be able to economize on the ground crew per plane - having each ground crew take care of more than one plane.)
4. If I have an 8 planes on 8 runs, can I get away with 1 alternate (always in the shop, on standby) or is there a formula for that too?
What am I missing, what am I forgetting? I don't plan on having ticket agents - more on that later.
Again, I know there are a thousand picayune details that may make my model unworkable, right now I'm looking for big stumbling blocks - hidden huge expenses that I'm not considering.
Thanks for your time, looking forward to your responses.
JRadier
RE: Expense Calculations For Airline Startup
Thu Aug 02, 2012 7:15 pm
Quoting JSpos (Thread starter):
Basic knowledge in the industry? Not trying to scare you off, but this is fairly basic stuff and a lot will depend on your actual plans and require some proper calculation. I think Aircraft Commerce would be a good start to get some of the data (and no, it's not openly available)
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
JSpos
Thu Aug 02, 2012 7:29 pm
Thanks Jurgen, Aircraft Commerce looks like a good source for a lot of that data, I will subscribe. Everyone, please understand that I know I will need expert help in this - positive help would be encouraging.
Jurgen, are you an airline executive or operating officer? Just curious - given your response.
JRadier
Thu Aug 02, 2012 7:39 pm
Quoting JSpos (Reply 2):
Jim, hoping to get there, but currently MSc student with work experience in the field. More info on my linkedin
mandala499
Thu Aug 02, 2012 7:45 pm
I'd love to help more, but... as the saying goes... no money no honey... (although that advisory board looks nice... if paid...  &nbsp
Well these kinds of questions, I do based on the planned weights for the route, dig into the flight performance manual for the aircraft, and figure out which one would be cheaper in terms of fuel...
Then, I add maintenance using all in power by the hour (including for heavy checks).
If fuel price ain't a problem, grab some 737 classics... they're available for less than US$100,000 a month (some of the older ones are half that). If fuel price is a big problem, then get some fuel misers (eg: 737NGs or A320x family with the CFM56-5B or IAE V2500-A5s... the old engines are guzzlers)
For 737NGs and A320x, it depends on your average hours per cycle... if it's below 1H15, stay with old planes!
If those prices are off, well, I haven't checked the lease prices lately. (don't forget the deposits required for the lease...)
Errr... try X USD per hour...
Power by the hour... ALL IN (including heavy checks)...
Crew? 2 pilots, and 1 FA per 50 passengers... that's per FAA rules.
You must also note their maximum duty and flight hours permitted per day, 7 days, calendar month, and annual. (where I am it's 9, 24, 110, 1050 for flight crew flight hours, FAs are 12hr duty time (flight hours not counted).
In the end, my calculations usually require 3 - 4 crew sets aircraft, but that always depends on the route network configuration... on some of the previous projects, the route network structured required 5 crew sets per aircraft...
Well, you can mix and match routes etc... just make sure you get enough hours out of the aircraft. I usually aim for 300hrs of flying a month per aircraft.
Back in the days when I used to do a lot of these stuff... the hard part is always cross checking and verifying the assumptions and variables.
Mandala499
JSpos
Thu Aug 02, 2012 8:18 pm
Thank you Mandala - that's a huge help. The advisory board doesn't pay yet, but I completely understand - and you've been most generous. I need enough information so I can make sure my model works before pitching investors.
I'll check the FARs for crew requirements - that may be my model's downfall (or it may make me rethink my model.) 24 Flight Hours a week sounds low...will have to think on that.
BMI727
Thu Aug 02, 2012 8:46 pm
Generally the shorter your flights, the less the total cost is based on fuel. If you're flying a long way, a larger fraction of the cost is fuel, so plan the fleet accordingly. I would think that 737 Classics are a good place to start: cheap to buy, less thirsty than MD-80s, plenty still in service to keep a large maintenance pool, and can reach both coasts from Memphis.
You'd almost certainly want contracted ground handling at each destination to take care of that.
That's going to depend almost entirely on the route system and schedules. Allegiant, for example, serves 71 cities and 8 hubs with a fleet of about 45 planes. Obviously, they are atypical, but you get the idea.
JRadier
Thu Aug 02, 2012 8:54 pm
Quoting mandala499 (Reply 4):
Depending on aircraft utilization that seems pretty reasonable, for a LCC style operation I wouldn't be surprised if it goes more towards 5 or maybe even over.
simairlinenet
Mon Aug 06, 2012 4:50 pm
It helps to look at real data! See the tables at http://www.transtats.bts.gov/Tables....ort_Name=Air%20Carrier%20Financial
bond007
Mon Aug 06, 2012 5:08 pm
I know Mandala knows it, but just to be sure you do, it's 1 FA per 50 passenger seats, so even if you only had 5 pax on board a 110 seat aircraft, you'd need 3 FAs.
Just my personal opinion, but if you have to ask these questions here, then you probably shouldn't be considering anything like this.
Jimbo
mandala499
Mon Aug 06, 2012 6:07 pm
Quoting bond007 (Reply 9):
Or he can just shove 19 seats and not have an FA at all!
On the non techops side...
Make sure you got the GDS costs (per pax basis), expected yield management model (basic n generic) so you can model the revenue... yield factor and load factor growth, etc....
Quoting JSpos (Reply 5):
Download FAR 121 for those requirements...
JSpos
Wed Aug 15, 2012 9:29 pm
Thanks Jimbo - I appreciate the advice, but I don't agree with your last statement. I'm looking at all avenues of information gathering. Business is business and it starts with research, I can hire experts when the time comes. I'm more of a synthesist. and hopefully NOT being an industry insider makes me able to think differently about the industry and ultimately allow me to be disruptive.
This small thread has already yielded some good connections.
TWA772LR
Wed Aug 29, 2012 10:27 pm
I'm not a pilot but I know some pilots and my mom used to work with them and keeps in contact with some, so here is my shot.
Max Pilot hours:
8 flight hrs/day
100 hrs/month
16 hr "duty day" which means working (sitting at airport, route planning, etc...) but not sure if includes flight time.
24 hr rest (75% sure) but I don't know when pilots take those
The ratio is one FA to 50 pax, so if you want just 2 FA's, it sounds like you should go with an EJet or CRJ-700 or a 735 or 736 or A318. Depending on the routes you would like to fly, I'm sure there are some cheap, older ATR 72's lying around somewhere
Keep in mind I am only 19 years old and this is all just off the top of my head. I would also like any input and/or corrections to my info from anyone who would know more and have a better understanding of this stuff than I do. I just like to learn  . I also want to start my own airline, or run a current one, someday so I am having this thread starred.
And for my next miracle, I'm gonna turn water into funk!
mandala499
Thu Aug 30, 2012 12:57 am
Quoting TWA772LR (Reply 12):
8 flight hrs/day
100 hrs/month
You should have a look at FAR121... it covers these things.
The 16hr duty day is for FAs, that includes the flying.
For pilots I think it's 12hr duty day, includes max 9 hrs of flying.
24hr rest is mandatory at least 1x in every 7 day period... that is 24hr rest free from working / office duty for the airline.
Don't forget there's also a 7 day flight hour limit, and an annual one for pilots. (FAs only got duty limits).
Mandala499
TWA772LR
Thu Aug 30, 2012 1:43 am
Quoting mandala499 (Reply 13):
Thanks mandala!
zkojq
Sat Sep 01, 2012 8:07 am
Startup-Boeing has a lot of handy resources.
Have a look here: http://www.boeing.com/commercial/startup/
Good Luck
First to fly the 787-9 (ZK-NZE, NZ103, 2014-10-09)
bueb0g
Sat Sep 01, 2012 9:59 pm
Not sure how it is with the FAA, but many authorities that I know require at least 2 aircraft to issue an air operating certificate.
For one plane, you'll likely need 10 pilots. If you want to go long haul, the rule of thumb (at least over here) is 10 Captains and 15 FO's.
Roger roger, what's our vector, victor?
XJetflyer
Sun Sep 02, 2012 12:36 am
So can a person have two Embraer ERJ145's and start an airline? I know a lot of airlines and people on here say 50 seat aircraft make no sense, but if you had the right markets and really worked hard I can see it being a good thing.
I think start up cost and and a solid advertisement fund is where most companies lose out fast. Years ago I did have a group ask me to join them as an investor in a startup airline. After careful thinking and reviewing, I decided against it. The company never happened.
I would not mind starting a small cargo plane company. I would think the profit is better in cargo, I may be wrong.
Fabo
Sun Sep 02, 2012 4:34 pm
Quoting XJetflyer (Reply 17):
Technicaly... yes.
The right markets... Problem is, are there any? The RJs heyday was when fuel was cheap and time was not. Nowadays, it makes more sense to use a turboprop. An ATR will use much less fuel on the same route than ERJ, time difference is not always enormous, and although comfort (mainly noise) is better in a jet, not much people will pay the extra.
It can work though, provided you find those 50 people...
I dunno. It is said that airlines make big money of airfreight, but the catch is, if you want to send cargo with Delta, or Atlas, they have a network...
Charter cargo is all about getting the job, if you can do that, then yes, it can work.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Users browsing this forum: codc10, CRJ900, kalvado, Scinfaxi, StereoTechque and 26 guests
