B777UA
Extra Door On 737-900
Fri Aug 03, 2012 5:06 pm
Hi all, I just returned from a trip on which I flew United, on a 737-900, and my question is, there is an extra door, after the over wing exits, but before the rear exit door. From the inside, it does not show, any means how to operate that door, nor is there an example on the safey card, does this door really exist?
as I was walking down the aisle to my seat, there was an Exit sign showing but no diagrams on how to open that door.
thanks for any help on this matter
1337Delta764
RE: Extra Door On 737-900
Fri Aug 03, 2012 5:17 pm
Quoting B777UA (Thread starter):
CO specified the extra doors aft of the wings on the 739ER to be replaced by non-openable plugs, since the extra doors are unnecessary in the two-class configuration that they operate them in. Replacing the doors with non-openable plugs saves weight.
817Dreamliiner
Fri Aug 03, 2012 5:18 pm
Yes on the 737-900ER they have an extra exit behind the wing, but on the united aircraft its blocked off due to the amount of seats on the aircraft, then it wouldnt require the extra exit. United aircraft has about 173 seat on the ER if I remember correctly which is less than the required limit of 189, with the extra exits the capacity of the 900ER increases to 215 seats.
with exits blocked off:
Photo © Andrew Compolo
With exits:
Photo © Jens Breuer
I'll wake from the dream, To keep and relive, Now life it is a dream, And dream's on a... BREAK!
yeelep
Fri Aug 03, 2012 5:21 pm
You flew on a 737-900ER not a 900. The extra door is in fact a plug on United 900ER's. The purpose of the doors are to allow for more seats in a single class seating arrangement, with two class seating the extra doors are unnecessary. A simple way to differentiate between the two is a small circular window is in a door while a plug will have a standard window.
roseflyer
Fri Aug 03, 2012 7:48 pm
I hope there was not an exit sign, since the door is a plug and is covered by a sidewall panel. There should not be an exit sign pointing to a non serviceable exit.
Viscount724
Sat Aug 04, 2012 2:45 am
Quoting yeelep (Reply 3):
The rear emergency exits on KE and TK -900ERs are also deactivated as they have fewer than the 190 limit where doors are needed, although in KE's case only 2 seats less (8J/180Y). According to their website seat map, TK has a very spacious layout on their -900ERs, 16J/135Y, total 151. That's even fewer seats than on any of their -800s which have 4 different configurations with a total of 155/165/177/189 seats per their website.
If the exits were activated they would have a painted outline around them like the overwing exits.
Photo © Andras Kisgergely
Photo © Branko Cesljas
Sat Aug 04, 2012 10:04 am
Quoting Roseflyer (Reply 4):
exactly what I was thinking....looks like if the door was deactivated its important that the Exit sign was removed too.
DL_Mech
Sat Aug 04, 2012 3:06 pm
Newer Boeings often have exit signs in the aisle with no exits nearby.
Photo © Nicholas Young
Photo © Jarek Dabrowski [epwa_spotters]
[Edited 2012-08-04 08:13:26]
This plane is built to withstand anything... except a bad pilot.
B777UA
Sat Aug 04, 2012 3:27 pm
Yes there was an exit sign, in the place where that door would have been, but iy was only on the left side of the plane,
CRJ900
Sun Aug 05, 2012 4:09 pm
Quoting DL_Mech (Reply 7):
I think around 20 or so of our B737-800 aircraft have an EXIT sign 3/4 down the cabin, between the overwing exits and aft doors - never understood why. On newer aircraft that exit sign is gone.
Come, fly the prevailing winds with me
Mon Aug 06, 2012 10:25 am
The concerned company should get it corrected,if the door is INOP,the Sign should NOT be there.
DL_Mech
Mon Aug 06, 2012 12:30 pm
Quoting HAWK21M (Reply 10):
Someone contact the Ethiopian Authorities!
Photo © Johnny von Borstel
Users browsing this forum: rjsampson and 11 guests
