SXDFC
737 Ground Power Question
Sun Aug 05, 2012 5:38 am
Hello All:
For quite some time at work I've noticed many of our newer 737s (circa 2010+), have the ground power port in a vertical position vs the older model 737s.. Can anyone explain why this is the case?
N949WN, 2010 model 737-7H4
http://i1208.photobucket.com/albums/cc368/737-8H4/9416e139.jpg
N927WN, 2008 model 737-7H4
http://i1208.photobucket.com/albums/cc368/737-8H4/c427f8a3.jpg
yeelep
RE: 737 Ground Power Question
Sun Aug 05, 2012 10:30 am
In Boeing speak, it was done to improve "External Power Receptacle Retention and Connectivity". There have been problems with the pins breaking on the new vertical connector, so from line #3852 they went back to the previous horizontal one until changes can be made. Eventually the new vertical connector will be offerred as a retrofit for all NG's.
Yukon880
Mon Aug 06, 2012 9:43 am
And for any of those that have ever "plugged-in" in such a fashion, the reasoning behind the change is crystal.
Pratt & Whitney, In thrust we trust!
Mon Aug 06, 2012 10:20 am
To avoid the Cable + connector load bearing excessively on the plug point....A chain/cable to the lower end of the plug was used ending in a hook that used to hold the inner wall of the panel,This used to relieve the excess load.
Users browsing this forum: fortytwoeyes, Google [Bot] and 13 guests
