mawingho
Isogonic Lines
Mon Aug 06, 2012 4:33 pm
From Wikipedia http://en.wikipedia.org/wiki/Magnetic_variation
"Magnetic declination is the angle between magnetic north (the direction the north end of a compass needle points) and true north. The declination is positive when the magnetic north is east of true north. The term magnetic variation is a synonym, and is more often used in navigation. Isogonic lines are where the declination has the same value, and the lines where the declination is zero are called agonic lines."
I still do not quite understand the last sentence about Isogonic Lines, anyone knows?
vikkyvik
RE: Isogonic Lines
Mon Aug 06, 2012 4:49 pm
Quoting mawingho (Thread starter):
Sounds like isogonic lines are the set of continuous points where the magnetic variation stays constant.
So if you start somewhere with a magnetic variation of, say, +5 degrees, then the line you follow to maintain a magnetic variation of +5 degrees is an isogonic line.
bond007
RE: Isogonic Lines
Mon Aug 06, 2012 4:52 pm
Agonic lines are simply joining points where the declination is zero ... i.e. no difference between true and magnetic.
A compass will point to true North on this line.
Jimbo
[Edited 2012-08-06 09:54:07]
Mir
RE: Isogonic Lines
Mon Aug 06, 2012 10:50 pm
If you're familiar with contour lines on a map, isogonic lines use the same principle. Just like every point on a contour line has the same altitude, every point on an isogonic line has the same magnetic variation.
-Mir
bond007
RE: Isogonic Lines
Mon Aug 06, 2012 11:46 pm
Quoting Mir (Reply 3):
... or weather of course, showing the pressure with isobars ... iso meaning 'equal'
Jimbo
SlamClick
RE: Isogonic Lines
Tue Aug 07, 2012 12:04 am
isotherms
isotachs
isopleths
RE: Isogonic Lines
Tue Aug 07, 2012 12:25 am
Here's an example of isogonic lines in the United States. As mentioned magnetic variation is the same along the lines.
Quoting SlamClick (Reply 5):
isotherms
isotachs
isopleths
isohyets.
Rara
RE: Isogonic Lines
Wed Aug 08, 2012 8:33 am
Quoting Starlionblue (Reply 6):
isohyets
isobronts
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
SlamClick
RE: Isogonic Lines
Wed Aug 08, 2012 1:23 pm
Quoting Rara (Reply 7):
isobronts
isocubes: Line connecting points in a chilled beverage where freezing temperatures occur.
KELPkid
RE: Isogonic Lines
Wed Aug 08, 2012 8:20 pm
Quoting SlamClick (Reply 8):
isobronts
isolate    (myself from this thread!)
vikkyvik
RE: Isogonic Lines
Wed Aug 08, 2012 8:53 pm
isohorny.
i managed to make myself laugh and grimace at the same time with that one.
