novice
What Is Omega
Thu Aug 09, 2012 6:02 pm
"Omega is a long-range global navigation system that uses ground-based beacons and operates in the very low frequency (VLF, 3 to 30 kHz) band using surface-wave propagation"
Can anyone explain what surface-wave propagation is as trusty is of no avail
tdscanuck
RE: What Is Omega
Thu Aug 09, 2012 7:38 pm
Quoting novice (Thread starter):
Everything you could ever care to know about Omega:
http://www.jproc.ca/hyperbolic/omega.html
With respect to surface-wave propagation, Omega works because, at its frequencies, the radio waves "see" the space between the earth surface and the ionosphere as a waveguide and propagate with very little loss or distortion over very large distances. Basically, Omega was tuned to use match the radio-transmission characteristics of the atmosphere so the waves would be contained between the surface and the ionosphere and propagate following the curvature of the earth.
Tom.
novice
RE: What Is Omega
Thu Aug 09, 2012 9:39 pm
Thanks Tom for that explaination
Users browsing this forum: AleksW and 1 guest
