ID On Component.
Sat Aug 11, 2012 11:49 am
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash3/576189_10152031764335301_1336160076_n.jpg
What does the C/W & P/W stand for.....P/N ie part number & S/N ie serial number is understood.
B6JFKH81
RE: ID On Component.
Sat Aug 11, 2012 12:49 pm
Interesting find HAWK21M. This looked like something on a gear so I googled the p/n, is this the unit?
Part Number: 275N2059-3
Nomenclature: NLG Steering Control Spring Cartridge
Chapter: 32
OEM: Boeing
Aircraft: B757
It's interesting that the C/W number is the same as the S/N. Haven't seen this before, but who makes the NLG assembly for the 757?
tdscanuck
Sat Aug 11, 2012 6:18 pm
Quoting B6JFKH81 (Reply 1):
The part in the photo is made by Boeing.
Quoting HAWK21M (Thread starter):
I suspect the "C/W" is "Common With"...i.e. this part is part of a larger serialized assembly (probably the NLG), which has the same serial number.
"P/W" may be "Produced With"...this would tie it to the original NLG assembly it was manufactured for.
Wild guesses on my part, buyer beware.
Tom.
B6JFKH81
Sun Aug 12, 2012 12:40 am
Quoting tdscanuck (Reply 2):
UGH, the answer was in my own info
EDIT: Actually no I didn't. Boeing made the individual component, but I'm wondering who made the entire gear assembly. My bad on that, sorry.
[Edited 2012-08-11 17:55:21]
Sun Aug 12, 2012 10:56 am
It is the PPI cartridge on the B752PCF used for Steering disconnect......about the exact manufacturer of the NLG....I'd need to check it up at work.
