Viscount724
KLM 737 Window Question
Thu Aug 16, 2012 12:40 am
Just curious if anyone knows why the 2nd window from the front is plugged on the left side of KLM 737s. Photos of -700 below.
Photo © Monica P - Sunny
Photo © Jason Wood
I had never noticed this before but was on two KL 737-700s this past weekend and noticed the blank wall panel adjacent to row 1 on the left side only. Since the first row has almost 3 windows it's not a problem but just couldn't think of a reason for blanking out the 2nd window on one side only. It's a normal window directly opposite on the right side. I've checked photos of KL 737-800s and -900s and it's the same.
zippyjet
RE: KLM 737 Window Question
Thu Aug 16, 2012 12:54 am
It could be the placement of a lavatory though the forward lav's on our FL/WN 737's is right behind the cockpit ahead of the L1 door. Or, maybe for a special partician between first/business class and coach. Just my guesses.
I'm Zippyjet & I approve of this message!
Viscount724
Thu Aug 16, 2012 1:01 am
Quoting zippyjet (Reply 1):
The forward lav on KL 737s is also right behind the cockpit forward of the door. And KL 737s only have a movable curtain divider since the European type of business class on almost all carriers uses a variable number of Y class rows according to demand, with the middle seat left empty. Rows foward of the overwing exits on KL 737s also have about 2 more inches of pitch (33 vs. 31 inches I believe) but all the seats are identical 3-3 Y class seats.
Thu Aug 16, 2012 7:22 am
Probably a Lavatory/galley location.
76er
Thu Aug 16, 2012 7:33 am
AFAIK it's where the coatroom is. Which are in the process of being removed to make room for another row of seats, by the way.
Leej
Thu Aug 16, 2012 7:42 am
A quick look on the KLM seat plans reveals
Top
Leej
Thu Aug 16, 2012 7:44 am
Not sure what happened there. KLM website seatplan for the 737 700 indeed shows the coatroom!
Viscount724
Fri Aug 17, 2012 7:18 pm
Quoting Leej (Reply 6):
I found a related thread on Flyertalk. The coatrooms on all KL 737s are being removed. They began removing them last April. I've been on about 6 KL 737-700s in the past couple of months and none had coatrooms. I note the KL 738 seat map on their website shows the new configuration without the coatrooms. Maybe they've completed the job on the 738s but not yet on the 73Gs and 739s.
What I now don't understand is why the first window wasn't also plugged when the coatrooms were installed, as both the first and second windows would have been blocked by the coatroom. See no reason why the first window was needed as the coatroom butted against the bulkhead behind the galley (the bulkhead that's now in front of 1-A/B/C).
Sat Aug 18, 2012 5:13 pm
why do they call it the coatroom,why not the coatcupboard.
Users browsing this forum: aerolimani, pallvidar and 1 guest
