mawingho
Normal Tail Down Force
Sat Aug 18, 2012 4:18 pm
I tried to find out why there is a normal tail-down force.
I searching around and read http://www.groundinstructor.com/mod/page/view.php?id=906
but it didn't say why there is a normal tail-down force.
Most materials on the web only said the up elevator can make the increase the tail-down force which make the nose-up.
But anyone can explain to me how to normal tail-down force formed?
Hope someone can help! =] Thanks in advance.
RE: Normal Tail Down Force
Sat Aug 18, 2012 5:02 pm
Quoting mawingho (Thread starter):
Because in most aircraft the 4 forces do not act through one point, they are slightly offset. When the forces are offset they cause a couple, the tail produces another couple (a down force by a moment arm to the CG) to equalize the moments.
This is a simple diagram I found on the web
http://antoine.glasson1.free.fr/singappof/Lesson12/res/tailplanes_equilibrium.png
from http://antoine.glasson1.free.fr/sing...0horizontal%20steady%20flight.html
It is just an upside down wing, or a symmetrical airfoil with a slight negative incidence on other aircraft. On other aircraft they might put fuel in the tail which also produces a force via additional weight.
Mir
Sat Aug 18, 2012 5:06 pm
The horizontal stabilizer is just a wing that produces lift in the downward direction relative to the airplane (aerodynamically, it's basically a wing that's attached to the airplane upside-down. So as you're flying along, it generates force downward.
-Mir
roseflyer
Sat Aug 18, 2012 5:07 pm
It changes throughout a flight. It's really a spectrum. Giving a specific force is very hard, so I'll just give an angle. Typical horizontal stabilizer is trimmed at 1 to 4 degrees trailing edge up relative to the fuselage (please not that this is not the same as units of stabilizer trim).
KPWMSpotter
Sat Aug 18, 2012 5:09 pm
On a perfect ideal airplane there won't necessarily be any tail downforce.
The elevator and the horizontal stabilizer exist to counteract any un-balanced moments created by the aircraft's aerodynamics and loading. If the CG and the center of pressure are at the same location, no additional downforce is required to balance the aircraft. Since this ideal case almost never happens, the horizontal stab and elevator create down (or up) force as needed.
On most light aircraft the horizontal stabilizer is attached at an angle of incidence relative to the airstream, this angle is determined so that minimal elevator deflection is required to trim the aircraft at the expected cruise condition. Larger aircraft have the ability to adjust this angle as needed to suit the flight conditions (see Mach trim). Other aircraft may have a cambered horizontal stab, which uses an airfoil to generate the required downforce. Other simple aircraft only rely on the elevator and trim tab, using the control surfaces to effectively camber the horizontal stabilizer. This is especially apparent on the Cessna 182, where the rudder horn is bent to reflect the normal trimmed position of the elevator (ie, not aligned straight with the stabilizer.)
Down force itself is created in the same way a wing generates lift; the camber or AoA of the stabilizer produces an aerodynamic force. The only thing that makes downforce different than lift is the fact that it is facing down...
I reject your reality and substitute my own...
Users browsing this forum: AF322 and 1 guest
