FlyBTV
Range Limit Of A320 From MCO/FLL
Tue Aug 21, 2012 12:41 pm
I'm interested in the range limitations of an A320 flying out of MCO or FLL, particularly it's ability to reach LIM. Essentially, I've been holding out hopes that B6 might open up a route into LIM, but I'm unsure if that's possible with their current equipment. NK flies FLL-LIM on a 319. And doing a quick check of the distance, FLL-LIM is essentially the same as BOS-SFO, a flight B6 currently operates.
However, in an article today, Barger notes that B6 is at it's current geographic range limit, but would not rule out widebodies in the future (but I don't see that happening anytime soon):
http://www.bloomberg.com/news/2012-0...-more-airport-access-correct-.html
My question is - what makes FLL-LIM different than BOS-SFO, as there is a negligible difference in distance? Does the issue involve the lack of suitable alternate airports, requiring a greater fuel reserve? Is there some other issue I'm not thinking of?
Would this situation change with the introduction of A320neos?
Any thoughts would be appreciated.
chimborazo
RE: Range Limit Of A320 From MCO/FLL
Tue Aug 21, 2012 9:59 pm
Range quoted in Wiki for an A319 is 3600nm versus A320 at 3200nm. Both routes are approx 2700 statute. I guess once alternate and reserve fuel is taken into account the 32 doesn't have the legs.
Essentially, I don't think it's any thing to do with the route, rather the lower range of the bigger jet.
Neo: assUming the above is the reason, depends on the extra legs of the 320 Neo.
FlyBTV
Tue Aug 21, 2012 10:31 pm
Thanks for the response.
My confusion is that FLL-LIM is 2283 nm and BOS-SFO is 2350 nm. So they 320 can obviously make the flight, but there's obviously something inherently different about the two routes. I would assume that the issue is, as you mentioned, the requirements for the alternate reserve. Generally, what are the requirements for an alternate airport (assuming it meets the obvious criteria of runway length, etc)? Does the fact this is an international flight make a difference?
mandala499
Wed Aug 22, 2012 11:58 am
MCO-LIM via the airways would be just under 2500NM.
You can do this BUT, you'd be pushing it with very little margin... but you'd need the 77 tons or 78 tons MTOW version for the IAE V2500-A5 engines.... and you can't carry cargo... you'd be limited to the pax and bags only.
For the 319, no sweat, even with the squashy 156 seat config... the plane can do it, would the pax?
Quoting flyBTV (Reply 2):
That would be my guess too. In the US, heaps of alternates... down there? Well, am not familiar with the area so...
LAXintl
Wed Aug 22, 2012 2:55 pm
Quoting flyBTV (Thread starter):
Jetstream.
A SFO-BOS flight can easily be hit with the equivalent of another 400-500miles+ due to headwinds.
FlyBTV
Wed Aug 22, 2012 4:45 pm
Quoting mandala499 (Reply 3):
That's a good point, I didn't consider the additional distance needed to fly the airways. FLL-LIM would be shorter and B6 does a few South/Latin America routes out of FLL.
Quoting LAXintl (Reply 4):
Jetstream.
Sure. But that only underscores my original point. If B6 can fly SFO-BOS against the jetstream with their 320s, why can they not fly FLL-LIM? Unless Barger was speaking very, very generally about geography, he made it pretty clear Colombia is the southernmost point that they can reach with their current fleet. There's obviously something different about FLL-LIM and the only thing I can conclude is it's an alternate issue. I'm just not familiar enough with what the requirements are for alternates, especially since this is an international flight. There are other international airports in the country, and in the vicinity of LIM, but nothing that's anywhere near the scale of LIM.
From what it sounds like, this issue is the aircraft not having enough range to reach a suitable alternate, and I'm just not sure what the requirements for such an alternate would be.
roseflyer
Wed Aug 22, 2012 6:17 pm
I wouldn't take that comment so literally. Lima and Caracas are both within reach of FLL on the A320. Because of elevation Quito probably isn't.
I think they were referring to going farther south into Brazil.
Lima has the benefit of being due south of Florida which helps because there are no jetstream winds to contend with. All they need is overwater equipped A320s (no ETOPS required) and Jetblue already has those.
FlyBTV
Wed Aug 22, 2012 8:12 pm
Quoting Roseflyer (Reply 6):
Thanks. That clears up my confusion - it is possible. I don't see Caracas on the horizon as a B6 destination (though perhaps I'm wrong), but I certainly see a fit with their brand with LIM.
mandala499
Thu Aug 23, 2012 1:00 am
Quoting flyBTV (Reply 5):
Well, they will look for the routing to avoid or minimize the headwinds. At LRC, for 2500NM, a headwind of 50kt would add 300NM to the distance... at 100kt headwind, that goes to 3200NM, and at 150kts, it shoots up to 3700NM... the good news is, change the routing to avoid the worst of the headwind, add another 100NM or so, and your net air distance can go up by less than 200NM if you do it right...
So, the case with FLL/MCO-LIM is:
1. Route Reserve Fuel. (Trip + Res + Hold +Alternate... domestic, doesn't require the "Res"... this is 10% of Trip I think).
2. Less numbers of near alternates, and less further alternates... the airfield density per area is significantly less outside the USA.
FLL being 150NM nearer makes LIM a heck of a lot more accessible... at the far end of the endurance charts, any distance savings can make a lot of difference.
Why would it not work? Quito is 900NM shorter from FLL/MCO... the TOW required is significantly less, and the only problem is, can it take off within UIO's runway for that TOW...
roseflyer
Thu Aug 23, 2012 1:29 am
Quoting mandala499 (Reply 8):
I doubt the A320 can takeoff with enough payload from Quito's elevation.
mandala499
Thu Aug 23, 2012 6:23 pm
Quoting Roseflyer (Reply 9):
If the runway is long enough, from 9000ft altitude, TOW is limited to about 70 tons.
But, 3000m runway there, you're limited to below 65 tons or so....
65 tons means you're limited to 150 - 165 seats filled for that route.
Add another 1000 meters of runway length at Quito and you can fly out with 180 seats filled to FLL... *wish wish wish*
Yeah, we can cross UIO off the list then... (TACA I think does the longest 320 from UIO? But to San Salvador from Quito is a lot shorter too!)
brains
Wed Aug 29, 2012 9:38 am
The NK FLL-LIM flight is limited to 130 pax +/- a few. Its limited even more if LIM requires an alternate...just cant carry enough fuel.
Brains
mandala499
Wed Aug 29, 2012 3:24 pm
Quoting brains (Reply 11):
What MTOW are you using and engine type? 74.5 tons and CFM56-5B?
ROSWELL41
Thu Aug 30, 2012 8:57 pm
As someone who has flown FLL-LIM in an A319, I can tell you that takeoff performance can be a factor depending on the temperature. Also, distance to alternates can be an issue on that route thus requiring even more fuel. B6 could do it with an A320, but they will have to block a large number of seats on a regular basis. That may make the route unprofitable I would think.
brains
Fri Aug 31, 2012 3:03 am
With a departure fuel of 39,000lbs on average plus a full a/c (max zero fuel weight of 129,000lbs +/- ) you've exceeded max t/o weight (call it 166,000lbs) it more than likely will be even further restricted by the rwy in FLL as Roswell said. You cant carry full paylod and a full load of gas. The more weight you carry the more fuel you need...its a fine line carrying the max pyld with the fuel required to get you to where you're going.
Max T/O weight is the most limiting of several different weights/limits. Being structurally limited (exceeding manufacturers max TOW) happens very infrequently.
They are A319-132s with V2524-A5s
Brains
Users browsing this forum: Apprentice and 1 guest
