eaa3
Questionable B737MAX Field Performance
Thu Aug 23, 2012 4:15 am
According to Air Insight the B737-8 and 9 will really struggle with field performance given the increased weight of the aircraft without increased thrust. This will cause the -8 but especially -9 to require well over 10,000 ft. of runway to takeoff at MTOW and therefore the aircraft won't be able to take of at MTOW from such airports as Minneapolis and Boston.
From Air Insight:
"As an example, according to Boeing, a B737-8MAX will be unable to take off from Minneapolis at MTOW. Minneapolis is at 800 ft but its longest runway is 11,000 ft. This makes you wonder about the -9MAX. Will it need 11-12,000+ ft at sea level? The -900ER already needs almost 10,000ft at sea level on a standard day.”"
http://airinsight.com/2012/08/22/assessing-the-max-story/
Also does anyone know what the field performance will be for the A320NEO and A321NEO.
RE: Questionable B737MAX Field Performance
Thu Aug 23, 2012 7:53 am
I have raised this before and it was stated it was possible by those who claim to be in the know.
Time will tell, most of the improvements seem to already available on existing 737s with options like the performance kit and carbon brakes.
CM
Thu Aug 23, 2012 3:18 pm
The problem with the Air Insight analysis is in the absence of data from the OEM, they have assumed the MAX will operate at the same thrusts as the NG. Boeing and CFM have not yet announced the engine thrust offerings for the 737 MAX, which could have a huge impact on the analysis in the Air Insight article. A very minor thrust bump (let's say 500 lbs on the 737-8) is equivalent to 20% more thrust than what is available today on the 737-800. This would more than erase any field length impact of an added 5000 lbs (which is less than 3% MTOW growth from the NG). Also, assuming the new winglets offer the same benefits to the MAX that the blended winglets offered to the NG (albeit in a smaller increment), then this change also should help with takeoff field length.
I would not put much stock in the "data" Air Insight has provided until you know how much thrust the MAX airplanes will have.
roseflyer
Thu Aug 23, 2012 4:30 pm
Takeoff and landing performance on the MAX is likely to get worse. They are increasing weights, which lengthens the takeoff roll. The higher weights also increase braking distance, which is made worse by the taller nose gear which translates to less weight on the main tires when the nose touches down on landing.
For airlines wanting short field performance, the MAX-7 will be the airplane. For those wanting lower CASM and higher capacity, there is the -8 and -9. You can’t get the best performance and the lowest CASM at the same time. Boeing and Airbus trying to optimize the family of airplanes to suit what each airline needs.
The same is true for the NEO and Airbus is facing the same problems of increased TOW. The 737-800 can operate out of shorter runways than the A320 can when it has the optional short field performance package that was created for GOL in 2005 so that the 738 could land at SDU whereas previously only the 73G & A319 could use SDU. That likely means that Boeing can give up a bit more on the MAX and remain competitive with the NEO.
ha763
Thu Aug 23, 2012 5:03 pm
Has Boeing mentioned or published takeoff performance numbers? The article didn't provide a link to a source.
Boeing shows the increase in MTOW for the -7 as 5000 lbs and for the -8/-9 as 7000 lbs. This is roughly a 3% increase for the -7 and 4% for the -8/-9 over the NGs.
http://boeing.mediaroom.com/index.php?s=43&item=2327
CFM gives a range for the LEAP-1B of 20000-28000 lbs of thrust compared to 18500-27300 lbs of thrust for the CFM56-7B. This is an increase of 8% on the low end and 3% on the top end.
http://www.cfmaeroengines.com/engines/leap
http://www.cfmaeroengines.com/engines/cfm56-7b
Add in the new winglet and other aerodynamic tweaks, I'd say we really need to wait until the 737MAX design is firmed up more.
CM
Thu Aug 23, 2012 5:08 pm
Quoting Roseflyer (Reply 3):
This is one area which does impact minimum takeoff field length, regardless of any thrust changes Boeing decides on. Even if the winglet performance could negate any change in Vref (unlikely), the added average operating weight from any increase in OEW will impact how much remaining runway you need to perform an RTO. This, of course, assumes Boeing is not doing other things to the MAX which improve low speed and braking performance.
mandala499
Thu Aug 23, 2012 9:11 pm
This doesn't look good... but, for the 900ER...
that MTOW of 85Tons or so, if you fill it up to MZFW (67.7 tons), and plan to land at MLW (71.3 tons), you can still carry 14 tons of fuel, that gives... err... 2200NM trip range... and on dry runway, 14C, sea level, on a flap 5 you need 10,000ft, not 11,000ft (that's for 30C)...
The question is, are you going to need to fill it up to MTOW often? The guys here flying it fills it to MZFW often in 30C conditions... and you can count the number of 3000m runways here with both hands....
So, MTOW for a narrowbody needing 10000ft over sounds bad... but look at the MTOW growth over the past 30 years for the 737!
Anyways, that article is aimed at "disappointing runway performance as a 757 replacement"... yeah, well, fuel burn and engine maintenance costs anyone? You get what you paid for, and pax wants cheap cheap cheap...
Sure the A321 gives better runway performance, but again, the fuel burn ain't so rosy comparing with the rest of the family, and comparing it with the 737-900ER, it's dismal.
We'll see what the MAX and NEO can come up with the runway performance numbers and certified for use fuel burn numbers... it'll surely be interesting...
But if it ends up as sacrificing runway performance for trip fuel burn... won't be surprised either.
roseflyer
Thu Aug 23, 2012 10:26 pm
Quoting mandala499 (Reply 6):
The vast majority of airlines are not flying the existing 737NG or A320 at MTOW or even near it. For the majority of operators, it does not matter what a MTOW 737-MAX9 requires for takeoff, because they want to see how it is used in normal operations. Normal operations is not US - Hawaii or transcon in the winter or LHR-IKA. Normal operations is a flight of 800-900 miles with quick turns and 7-9,000ft runways.
Fri Aug 24, 2012 1:34 am
Quoting CM (Reply 2):
Did you mean 2% ? or 5000 lb ?
FlyASAGuy2005
Fri Aug 24, 2012 4:09 am
Quoting Roseflyer (Reply 7):
I do have a question, maybe someone can answer. MTOW takes into consideration that you're operating in a 1-class configuration, correct?
What gets measured gets done.
CM
Fri Aug 24, 2012 4:49 am
Quoting zeke (Reply 8):
Did you mean 2%
Yes. Sorry for the confusion.
Quoting FlyASAGuy2005 (Reply 9):
MTOW simply is the maximum certified weight for takeoff... it is an all-inclusive weight (airplane, passengers, bags, fuel, etc) and does vary with the cabin configuration of the airplane.
FlyASAGuy2005
Fri Aug 24, 2012 5:31 am
Quoting CM (Reply 10):
Well that's really where i'm getting at. The assumed pax weight is going to be whatever the certified limit is, correct? (as far as the MTOW is concerned).
The point i'm getting at is most airlines will save quite a bit of weight due to the fact that most a/c are operating in a 2-class config. So DL would have a max of 160 pax (minus crew) on a 738 but the gross seating for the 738 is certified to 189 (or whatever it is). For MTOW purposes, i'm assuming that's taking into account 189 pax. Is my thinking correct here?
mandala499
Fri Aug 24, 2012 6:37 am
Quoting FlyASAGuy2005 (Reply 11):
Aircraft, crew, food, pax, bags, cargo, and fuel!
MTOW, and MZFW do not take consideration the configuration. Your TOW and ZFW yes, but not the limits.
Exactly my point ! Most of the time, these aircraft will be operating on routes less than 1500NM... so they won't be anywhere near the highest MTOW... The 737-900ER for example rarely operate at its MTOW of 85tons... for 1500NM, they operate at the 72 to 75 ton range (75 ton being the lower MTOW version), which need only 8600ft runway...
The Max-9 will suffer from "bad runway performance numbers" for MTOW, but the majority of the market won't need to use that MTOW. But most of the market would want good fuel burn numbers instead of the TO Field Length Requirement at MTOW.
sweair
Fri Aug 24, 2012 9:40 am
IMO the MAX would need more thrust than the NG, but as I see it will have the exact same thrust engines. The 739ER has a lousy field performance.
FlyASAGuy2005
Fri Aug 24, 2012 4:11 pm
Quoting mandala499 (Reply 12):
I think my wording is being lost some how. I get that the configuration can be different. That's pretty obvious. The MTOW will not change because an airline chooses to fly it in an all busines class config.
To my original point, for WARM BODIES (excluding crew) what # does Boeing go off of to come up with their "people weight" so to speak in the MTOW calculations. I can only assume it's whatever the certified limit is, correct (plus crew/babies, etc.).
roseflyer
Fri Aug 24, 2012 7:12 pm
Quoting FlyASAGuy2005 (Reply 14):
These are the weights used for analysis and loads: 190lbs for summer or 195lbs for winter per passenger including carry on luggage and 30lbs for each checked bag.
Fabo
Sat Aug 25, 2012 12:19 am
What the market wants, I suppose. It is not that easy to see in narrowbodies, but quite easy in widebodies - you can either have so much payload for full fuel or so much fuel for full payload, or somewhere in between... and they try and find the sweet spot for the airlines.
What could be more interesting for you in narrowbodies would be MZFM maybe. e.g. how much load will Boeing let airlines to cram into a 737. In widebodies, cargo is a concern, in narrowbodies, I suppose less so. (And once you have MZFM, you tweak MTOW to get as much fuel in as you want there)
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Max Q
Sat Aug 25, 2012 8:25 am
This is the Achilles heel of Boeing's minimum change philosophy for the 'Max'
A large part of the poor field performance on the long body NG's and even more so on the Max is the geometry limits of the short main landing gear which Boeing is not changing for the new Aircraft.
The Aircraft is geometrically limited for rotation because of this and it has to run up the take off speeds artificially to ensure adequate tail clearance at the higher weights.
Boeing recognized this as a problem when they stretched the 767 from the -300 to the -400 model. But they extended the landing gear 18 inches, added winglets and more power. Even then the take off and landing speeds had to be raised but it's field performance is acceptable.
It's time for Boeing to bite the bullet and extend the main landing gear. The performance potential of the Aircraft would be vastly increased. In fact they could increase the gross weight further, in combination with a more powerful engine and finally get that transatlantic performance some operators want.
Fabo
Sat Aug 25, 2012 2:39 pm
Quoting Max Q (Reply 17):
Some would say it is time for Boeing to bite the bullet and go for all-new narrowbody, and I agree, with MAX EIS in 2017, it is about time to start something serious regarding all-new narrowbody.
catdaddy63
Sat Aug 25, 2012 7:50 pm
Quoting Fabo (Reply 18):
Barring a huge leap in engine technology, Boeing wont replace the MAX family before 2025. The order book is already pretty strong for the MAX, and it will only get better. With the 787-10 and the 777 upgrades that haven't even been formally offered yet the all new narrowbody will take a back seat for now.
roseflyer
Sun Aug 26, 2012 4:58 pm
I don't disagree with your point. However I do disagree that there is evidence that Boeing should extend the landing gear.
There are a few airlines that would benefit from a 738 or 739 with increased payload. However the majority of airlines would not benefit. The majority of flights do not push the takeoff performance of the airplane. It's only a few select airlines that operate the 737NG near MTOW on a regular basis.
The majority of the flights are shorter in duration than 5-6 hour MTOW flights. The average flight of a 737NG is less than 2 hours. By not changing the main landing gear, the OEW does not go up as much for the MAX which means more efficiency. Airlines are crying for any point of fuel burn improvement that they can get. That's what is selling this airplane. Increase performance is not.
Keeping costs and maintenance low is also desirable. Minimum change keeps the price of the airplane and potential program delays in check. It also reduces maintenance costs since the same spares inventory can be kept
For airlines that want better performance, they can go down in size as the 73G has great short field performance and with engine options can have the same or better takeoff performance as a 757. It also has more range. The consequence is CASM.
Another factor to keep weight down, is that Boeing is seeing competition from below. The E195, C-Series and other projects are going to eat away at the bottom end of the 737 market. By continuously increasing TOW, the airplane becomes less efficient at operating short segments and airlines are more likely to consider the smaller alternatives. On the other hand there is no competition above the 739 & A321. Airlines are cross shopping the 739 with the A321 or the 788. With the 788 being such a huge jump up, airlines are forced to take some compromises.
So while I agree that Boeing could get more performance out of taller gear, I can fully understand the reason not to do it. Launch customers like Southwest will be screaming to keep OEW down down down. The result is slightly worse takeoff performance, which is a compromise that airlines are willing to take with today's fuel prices.
Max Q
Sun Aug 26, 2012 10:41 pm
Quoting Roseflyer (Reply 20):
I disagree.
Boeing is limiting the potential of the Aircraft for no good reason.
Stitch
Sun Aug 26, 2012 10:46 pm
Quoting Max Q (Reply 21):
So making the plane heavier so it will burn more fuel for some 95% of it's missions is a "good reason"?
Max Q
Mon Aug 27, 2012 12:55 am
Quoting Stitch (Reply 22):
Talk about a leading question !
Ridiculous assertion anyway. A taller landing gear would not only allow better field performance but it would also enable Boeing to put a larger fan on the Max, easily negating any weight penalty.
ContnlEliteCMH
Mon Aug 27, 2012 2:29 am
Quoting Max Q (Reply 23):
Since it is a good assumption that you are not presenting a tradeoff that Boeing has not studied in detail, where do you think they have erred?
Christianity. Islam. Hinduism. Anthropogenic Global Warming. All are matters of faith!
tdscanuck
Mon Aug 27, 2012 3:32 am
Limiting the potential on certain factors so you can gain on others *that the customers tell you they want you to do* is a good reason.
Taller gear means more gear weight and a redesigned (heavier) wing. That's hard to come back from (the A320 has never managed to get its weight down to the 737's). Bigger fan means bigger, heavier engine, bigger/heavier nacelle, and bigger/heavier strut.
All of this is, naturally, countered by other things that get better but *none* of them are weight.
Tom.
mandala499
Mon Aug 27, 2012 4:18 am
Raising the landing gear would improve field performance due to larger fan.
Raising the landing gear would also affect the aircraft in other ways:
1. Increased complexity of the landing gear or one needs to move the engines further outboard... this would add costs and reduce commonality... and most likely a redesigned wing... that adds a lot of costs.
2. Increased cargo hold floor height, which means that the bags can no longer be hand-loaded, and need the conveyor loader. Whilst this may not be a problem for most of the major airports, it would mean a capital investment for the airlines.. be... Someone ordered a lot of Max in February with this in mind... "no need or conveyor loader".
Whilst I think the Max is disappointing, but I can understand the reasons behind the minimum changes... and it's selling...
Mandala499
astuteman
Mon Sep 03, 2012 8:23 am
IIRC, the NEO MTOW's will be going up a whole 1 tonne from the CEO A320's, and it too is receiving winglet (sharklet) treatment.
The sharklet treatment, by the way, is said (I believe) to add 3 tonnes to the MTOW allowable for a particular field length, so I'm expecting the NEOs to have better field performance than todays A32X's, if not necessarily as good as next years sharkletted A320's
Limiting the potential in one sense, in order to maximise it in others. These things are always trade-offs, and Boeing WILL have traded it off
Quoting tdscanuck (Reply 25):
Quoting mandala499 (Reply 26):
Bottom line
BreninTW
Mon Sep 03, 2012 9:36 am
Discussing the landing gear length, I recall reading on here the observation that the current MLG allows Boeing to certify the overwing exits without slides.
That would also be a major concern. If my memory is as good as it should be, the person making that statement also said that the wing height is within one inch of the maximum height that allows certification without the slides.
Is this so?
If so, then extending the MLG to allow a bigger fan would necessitate some substantial redesign of the overwing exits.
ferpe
Mon Sep 03, 2012 5:04 pm
Quoting Brenintw (Reply 28):
It would mean a substantial redesign of the whole aircraft, IIRC the MLG are meeting at the center of the aircraft right now, make them longer and you need to relocate their attachment, meaning you need to relocate the engines, meaning you need to relocate the .....  Wow!
Non French in France
packsonflight
Wed Sep 05, 2012 9:00 am
The problem with messing with the MLG is certification I think. If they start to change the wing MLG attachment points and modifying the center wing box, they could face loosing the grandfather certification from the old 737-100
A fresh certification would not only result in more costly design and tests, the new parts could end up a bit heavier which is certainly not what the MAX needs....
tdscanuck
Wed Sep 05, 2012 2:16 pm
Quoting packsonflight (Reply 30):
It's unlikely to break the original certification; the wing and gear got changed for the 737NG without that problem. However, it would greatly expand the scope of required testing and cost.
A fresh certification (i.e. a new type) would probably destroy the business case for the 737MAX.
Tom.
ferpe
Wed Sep 05, 2012 4:22 pm
Just to illustrate the problematic of the 737-8MAX start case, here how the drag of the frame looks at it's V2 (stable climb point at 15ft with OEI ) :
- total drag, some 17500 lbf
-- thereof drag from lift (induced drag) 15000 lbf
-- thereof parasitic drag 2500 lbf.
Now the absolute drag level might be off some % (my model is not dialed in completely for these new SA frames yet) but what I want to show is the scope of the drag components. If we go to Vr things gets even worse. To this you need to add some 3500lbf of climb power to reach your min OEI thrust of more then 21klbf or thereabouts. So your induced drag is 75% of the problem.
Now from that it is easy to understand how important those improved winglets are, every fraction you can drive that induced drag down is equal to better start distance or more TOW.
I am therefore not sure the driving force was the better cruise performance (though it counts of course) for the new winglets, it might have been to claw back some of that lost take-off capability that was the most pressing target. All the other stuff is then the icing of the cake   .
Users browsing this forum: OMP777X and 1 guest
