United Airline
If All Engines Fail....
Fri Aug 24, 2012 6:33 am
If all engines fail, is it possible for pilots to glide the plane down safely? How?
XFSUgimpLB41X
RE: If All Engines Fail....
Fri Aug 24, 2012 6:36 am
Yup! There have been a few examples in airliners, with this being the most recent:
http://en.wikipedia.org/wiki/US_Airways_Flight_1549
It's more common in light single engine airplanes... the result is typically non fatal.
Chicks dig winglets.
SCL767
Fri Aug 24, 2012 6:43 am
Quoting United Airline (Thread starter):
Yes, Air Transat Flight 236 is an example.
BreninTW
Yes, it is possible.
A BA 747 flying through an ash cloud over Indonesia lost all engines, and, of course the BA 777 a few years ago at LHR that lost both engines. The 747 was able to start its engines again, the 777 dug a ditch at the end of the runway, but nobody was killed.
Air Transat and AC both had aircraft that ran out of fuel and glided to safe landings.
I'm sure there are other instances.
Lift is created by the movement of the air over the wings -- so in the event that engines fail. the forward momentum will still allow the wings to generate lift and keep the aircraft airborne until such time as the forward momentum is insufficient to generate enough lift to keep the plane in the air.
Pilots will weigh in about glide slopes and all the information they have to consider, I'm sure.
Fri Aug 24, 2012 9:09 am
Most times airliners descend from cruise they are basically gliding on idle power. There's a "best glide speed" where the aircraft goes the furthest distance possible gliding.
Viscount724
Fri Aug 24, 2012 12:24 pm
I'm surprised there's anyone on A.net who hasn't heard of AC's 767-200 Gimli Glider that ran out of fuel on a flight from YOW to YEG on July 23, 1983 and glided to a safe emergency landing at a closed former air force base at Gimli, Manitoba.
News footage from 1983.
http://www.cbc.ca/archives/categorie...mli-glider-lands-without-fuel.html
And re the aircraft's final retirement flight to the desert on January 24, 2008.
http://www.cbc.ca/news/canada/manito...story/2008/01/24/gimli-glider.html
It did a low-level flypast at YUL on the retirement flight. The two pilots from the newsworthy 1983 flight were aboard.
http://www.youtube.com/watch?v=2MHy6yy3Z00
Interestingly, 29 years later the same AC143 flight number still operates YOW-YEG at about the same times as the Gimli Glider in 1983, but it's now an Embraer 190 and the routing today is YYT-YHZ-YOW-YEG. Until fairly recently, a year or so ago I think, it was even still operating the identical YUL-YOW-YEG routing as in 1983. It was an A319/320 for quite a while before the current E-190.
IAHFLYR
Fri Aug 24, 2012 2:16 pm
TACA B737-200 was a glider and landed on a levy near MSY back in the 80's, IIRC.
rfields5421
Fri Aug 24, 2012 2:32 pm
If all engines fail - the pilot is back to some of his/her earliest flight training.
As noted above - there have been several successful landings of airliners with all engines not working - some on airports, some on not. And there have been some which did not make it.
Wikipedia notes almost 40 such incidents where gliding was part of the flight - http://en.wikipedia.org/wiki/List_of...line_flights_that_required_gliding
Modern jetliners glide much better than most folks who don't know much about airplanes would expect. The same things which make a modern jetliner more fuel efficient help make it a better glider.
Kaiarahi
Fri Aug 24, 2012 7:32 pm
I had the good fortune to jump-seat LHR-YMX in 1990 with the same Gimli flight crew. Bob Pearson (the captain) was also a gliding flight instructor at a club based in Hawkesbury, Ontario (ex WW II training base). He "persuaded" me to take up gliding, which has been a thoroughly enjoyable pastime.
Empty vessels make the most noise.
Fri Aug 24, 2012 9:03 pm
Very Much possible to glide......Although a condition of such an Incident occuring is very rare in todays times.The BA 747 & Gimli glider are two very popular ones in the past.
But with a rise in the reliability of Engines.....Wont happen often.
The B777 fuel starvation at LHR is one too.
BoeingGuy
Sat Aug 25, 2012 6:01 pm
Quoting IAHFLYR (Reply 6):
Yep, both engines failed due to ice ingestion, I believe. It was a 737-300.
The Captain did an amazing job. What was more impressive is that he was only 26 years old and missing one eye, which was shot out in El Salvador, so he lacked some depth perception. It's refreshing to read about highly skilled pilot action like that, as opposed to tragic accidents with poor piloting (3407, for example). The only possible mistake he made was not landing at the closer Naval Air Station, in which he was given vectors to after the initial engine flameouts, but tried to continue to MSY after the engines re-lit the first time.
Sat Aug 25, 2012 7:11 pm
Quoting BoeingGuy (Reply 10):
Was that not a criteria for flying.....
bueb0g
Sat Aug 25, 2012 8:23 pm
Quoting HAWK21M (Reply 11):
Certainly is... Some lax medical standards maybe? Or an embellished story!
Roger roger, what's our vector, victor?
Sun Aug 26, 2012 12:16 am
SK751 is another famous example of an airliner that had to glide to a landing. http://en.wikipedia.org/wiki/Scandinavian_Airlines_Flight_751
71Zulu
Sun Aug 26, 2012 6:21 am
Here is a video on TACA 110, the deadstick landing at MSY.
http://youtu.be/IPn8G7enbF4
The aircraft landed on the grounds of the company that used to build the external liquid fuel tanks for the space shuttle.
10 years later in 1998, the Captain and FO were invited back and given keys to the city by the Mayor of New Orleans.
The engines failed due to massive water ingestion in a heavy thunderstorm.
The aircraft was a 737-300 and was only two months old at the time.
The aircraft ended up with America West, then Morris Air and was then absorbed into Southwest and still flies today as N697SW.
Clickable links only please!
Goldenshield
Sun Aug 26, 2012 9:29 am
Highly skilled? More like luck. The captain was attempting to ditch in the river when his first officer spotted the levee. And it's not like the levee was free of issues, either. On either side of the central "runway" were berms that could have caught a wing.
His ability to fly an aircraft while lacking depth perception due to losing an eye? Now THAT'S skill. (And this coming from a pilot who also lacks natural depth perception, but still has both eyes.)
[Edited 2012-08-26 02:33:33]
pilotpip
Sun Aug 26, 2012 3:27 pm
He flew into a thunderstorm with extreme precipitation. If he had the skill and presence of mind to AVOID this, which you should do, this would have never been an issue. There was nothing refreshing about his actions. His mistake nearly killed a plane full of people.
DMI
Sun Aug 26, 2012 3:55 pm
If an engine is no longer producing thrust due to combustion ceasing, normally the turbines still rotate due to the air windmilling through them.
This rotation is normally enough to still power the hydraulics which are needed to power the flight controls.
rfields5421
Sun Aug 26, 2012 4:30 pm
Quoting pilotpip (Reply 16):
The NTSB said they flew as directed by ATC and used their radar to avoid the heaviest cells.
Both this flight and Southern Airways 242 highlighted problems with the ability of the FAA ATC radar systems and on-board aircraft radar to give controllers and pilots accurate real-time data to avoid small intense cells within storm systems which appear to be well within aircraft flying limits. The systems are better today, but their are still not perfect.
Yes, he could have tried to fly around the thunderstorms that day. Though I have to wonder about the fuel capacity of a flight from Belize to divert from New Orleans to Tampa or Houston after arriving at their descent point for New Orleans. It was a very large weather system that day across the states of Texas, Louisiana, Mississippi, Alabama and Florida Gulf coasts.
Also
A CONTRIBUTING CAUSE OF THE INCIDENT WAS THE INADEQUATE DESIGN OF THE ENGINES AND THE FAA WATER INGESTION CERTIFICATION STANDARDS WHICH DID NOT REFLECT THE WATERFALL RATES THAT CAN BE EXPECTED IN MODERATE OR HIGHER INTENSITY THUNDERSTORMS.
FlyHossD
Mon Aug 27, 2012 4:54 am
Over the years, I had the opportunity to try it twice in simulators. Both times, I made the runway from further away and lower altitude than you'd probably expect. My glider experience probably helped.
In other words, it can be done (and has been done) with the right circumstances.
Mon Aug 27, 2012 11:05 am
Quoting bueb0g (Reply 12):
Exactly it should have been a desk job....
Goldenshield
Mon Aug 27, 2012 11:13 am
Quoting HAWK21M (Reply 20):
Apparently, he was a really good friend of the family who owned the airline. That said, he was flying scheduled flights in a Pilatus around the Guatemalan bush before and after his eye got shot out---including flying himself and his passengers to safety after getting the gunshot wound from a run-in with some drug runners.
[Edited 2012-08-27 04:34:05]
pilotpip
Mon Aug 27, 2012 3:12 pm
Quoting rfields5421 (Reply 18):
If they didn't have fuel reserves, they should not be dispatched.
I picked this paragraph alone but while ATC can give good suggestions that isn't always the case. Their radar is still limited and they don't see the cells like we do (assuming we are in VMC). There have been more than a couple cases where ATC said "the last guy went through" and myself or the other person I'm flying with veto'd the idea because we weren't comfortable with what we saw on our radar or with our eyes.
Bottom line, a little patience and a little better decision making and we wouldn't be talking about a 737 that landed on a levee.
[Edited 2012-08-27 08:18:41]
DMI
barney captain
Tue Aug 28, 2012 4:43 am
Quoting pilotpip (Reply 22):
Agreed.
Southeast Of Disorder
aerotech777
Sun Sep 02, 2012 8:50 pm
Hi,
I think the problem with all engines failure is when this event happens at low altitudes. Your ability to glide is very limited. You are very limited to trade altitude for the speed and sometimes you can’t glide. It can lead to serious incident/accident (US Airways flight 1549) or even crash. BA 777 event (restricted fuel flow due to ice) is another example even though it seems engine(s) was operating at low thrust (I didn’t read the final report of the incident).
At high/relatively high altitudes you can trade altitude for the speed and you may land successfully as mentioned above after all engines failures.
25.671 FAR (d): The airplane must be designed so that it is controllable if all engines fail. Compliance with this requirement may be shown by analysis where that method has been shown to be reliable.
At low altitudes and after engine failures aircraft controllability is very limited since you don’t enough speed (potential power). This controllability may not lead to successful landing without enough speed (potential power).
Quoting zeke (Reply 17):
In windmilling engine the fan and the LP compressor drive the LP turbines and HP compressor drives the HP turbine (s) and the gearbox. The turbines drive the other mentioned engine components only when the engine is operating. So after engine failure (windmilling engine) HP compressor drives the gearbox (including the engine hydraulic pump) and the turbine. The engine hydraulic pump provides limited hydraulic power (flow) not enough to power the flight control and other components (flaps...etc). You may have 3000 PSI at the beginning, but this pressure will decrease to 0 PSI as soon as you start actuating the flight control.
Low bypass windmilling engine may provide enough hydraulic power compared to high or medium bypass engines. High bypass (medium bypass to lesser degree) windmilling engines don’t provide enough hydraulic power because the majority of airflow bypasses the core engine (HP compressor). So the gearbox (hydraulic pump) is not driven to sufficient speed to provide enough hydraulic power. I think that’s why the RAT provides hydraulic power (in addition to electricity). I believe for that reason the B747-8 is fitted with RAT.
I stand to be corrected.
Aesma
Thu Sep 13, 2012 10:00 pm
The one that really makes my day is the Air Transat one, since it happened in the middle of the Atlantic.
DarkSnowyNight
Fri Sep 14, 2012 5:16 am
Quoting HAWK21M (Reply 9):
And would have been even better if they weren't in full landing configuration at the time. I think those guys made the most of a tough gig.
Just out of curiosity, would you happen to know what a typical N speed is for the fan at say, Vref, in this situation?
ATC: "Aww common, you afraid that storm'll put too much hair on your chest?"
Seriously though, you make a good point.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
longhauler
Fri Sep 14, 2012 2:50 pm
This is a common simulator exercise we often practise.
First Officers are given the aircraft with engines out about 20 miles on final at 250 knots at around 5000' AGL in VMC conditions. Captains get the aircraft directly overhead the runway, IMC, 200 knots with flaps at 5 degrees, also at 5000' AGL.
While it may seem like a useless exercise, it does accomplish some good points. It shows the pilots it can be done, it is great practise in aircraft handling, and .... it is an excellent CRM exercise, as a successful outcome is always easier with the input and help from the pilot not flying.
ScarletHarlot
Fri Sep 14, 2012 3:12 pm
Dude! You asked this same question years ago!!
What Can Pilots Do If All Engines Fail? (by United Airline Apr 30 2006 in Tech Ops)
If all engines fail, anything pilots can do? Can they glid the plane to somewhere?
But that was when I ruled the world
litz
Fri Sep 14, 2012 6:47 pm
Quoting Aesma (Reply 25):
The number of things that went right for those guys to make that airfield is a pretty huge list.
Sheer dumb luck played a big part, too.
CM
Mon Sep 17, 2012 6:46 am
For the past generation of engines this was true. With newer engines and very high bypass ratios, the windmilling of the engine is not sufficient to drive the EDP, which is why the 748 has added a RAT.
Users browsing this forum: HBJZA, ooslc, xbgb2003 and 2 guests
