rw774477
B-1 Flight Vs C-1 Flight
Fri Aug 24, 2012 12:00 pm
Why the different designations ?
is b-1 first flight -what about delivery flights ?
rw774477
RobK
RE: B-1 Flight Vs C-1 Flight
Fri Aug 24, 2012 12:02 pm
B = Boeing. C = Customer. Delivery would be a 'C' flight obviously.
cargolex
Fri Aug 24, 2012 1:38 pm
B1 is the first flight.
C1 is the first customer acceptance flight.
Delivery flights are operated by the airline after they have taken possession of the aircraft - almost always under a special flight number for the ferry flight. For example ANA9397 is a number used commonly on the delivery flight of ANA wide bodies. Technically it isn't a "delivery" so much as the customer coming to collect the aircraft and fly it to their base of operations with their own crew.
It's a little more confusing for BBJ's and military aircraft as those don't go through the same process, but this is how it goes for Airlines.
Aircellist
Fri Aug 24, 2012 2:00 pm
Who pays for the fuel on a C flight?
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
roseflyer
Fri Aug 24, 2012 2:38 pm
Quoting aircellist (Reply 3):
Boeing. The C-1 flights are still operating under Boeing's Production Certificate and not the airlines' operating certificate. The flight is conducted according to Boeing rules, with Boeing pilots on board in addition to pilots (sometimes) from the airline. Some airlines designate Boeing to conduct the C-1 flight without them.
RobK
Fri Aug 24, 2012 2:41 pm
Quoting cargolex (Reply 2):
Not necessarily. Some airlines use an aircraft delivery contractor to get the plane home. Up until a few years ago all the HNA Group aircraft were ferried to China by Global Aircraft Delivery at Seattle. I think HNA use their own crews now, though.
Ronaldo747
Sat Aug 25, 2012 6:56 pm
What means "EWA" flight, read it somestimes on Matt Cawby's blog. It that kind of "troubleshooting" during flight? Thanks for clarification.
tdscanuck
Sun Aug 26, 2012 3:51 am
Quoting RobK (Reply 1):
Generally not. Delivery flights take place after delivery...so they're not Boeing flights anymore.
Quoting Ronaldo747 (Reply 6):
It means they're doing a flight test beyond the production checkout. They come up really commonly whenever a new cabin configuration or IFE upgrade comes out.
No. Troubleshooting a problem with a specific airplane falls within the B-x and C-x flights (that's what they're for). An EWA flight is a pre-planned flight test for some purpose beyond the production flights and squawk resolution.
Tom.
RobK
Sun Aug 26, 2012 9:56 am
Quoting tdscanuck (Reply 7):
Umm, isn't that what I said...
Stitch
Sun Aug 26, 2012 1:52 pm
A customer delivery flight would be operating under the airline's Operating Certificate, not Boeing's, correct? So per Roseflyer, it would not be a "C" flight.
tdscanuck
Mon Aug 27, 2012 3:36 am
Quoting RobK (Reply 8):
You said delivery was a C flight:
A C-x flight is operated by Boeing under Boeing procedures before delivery. A delivery flight is not counted as a C-x flight.
Tom.
roseflyer
Mon Aug 27, 2012 5:39 pm
Quoting Stitch (Reply 9):
Yes Stitch you are correct. Delivery flight is not under the Boeing Production Certificate. In general, Boeing can't fly an airplane after the ticket has been transferred from Production to Operating without temporary registration.
C flights are Boeing flights under the production certificate. The production certificate allows customer airline pilots to fly the airplane. The term customer flight is a bit of a misnomer. The airline's operating certificate typically does not allow Boeing pilots to be in command of the plane without special approval. Tom can probably correct me.
tdscanuck
Tue Aug 28, 2012 3:55 am
Quoting Roseflyer (Reply 11):
Nothing to correct...I'm not aware of any ops spec that would allow a Boeing pilot to be PIC when operating under the airline's operating certificate.
That said, being the PIC of record and being the functional pilot in command aren't really the same thing...there is nothing to stop an airline putting up a flight under their Ops Spec with an OEM pilot actually doing the flying. This is pretty normal for post-delivery flight testing.
Tom.
Users browsing this forum: Baidu [Spider] and 24 guests
