jtl11968
Why Do These Wings Have Weights?
Fri Aug 24, 2012 4:29 am
The reason is probably obvious to many but I'm an airplane geek without much manufacturing knowledge.
Why do the aircraft in the picture have the weights hanging from the wings?
http://www.airliners.net/photo/Air-I...eing-787-837-Dreamliner/2150597/M/
jetmatt777
Crew
RE: Why Do These Wings Have Weights?
Fri Aug 24, 2012 4:33 am
Just a guess, but those weights are where the engines would normally mount. I'm assuming the weights are there to prevent the wing from flexing near the wing root while there is no permanent weight hanging from the engine mounting areas.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
BreninTW
Fri Aug 24, 2012 4:38 am
I believe it's mostly to stop the aircraft tipping backwards -- the engines are typically mounted forward of the center of gravity of an aircraft, and they're heavy.
Without the engines, there's a very real risk of the aircraft tipping backwards, especially in windy conditions.
AR385
Fri Aug 24, 2012 4:47 am
I may be wrong, but extrapolating from the 747 history, that was a common sight early in the delivery schedule because although the frames were ready, the engines were behind schedule. Without those weights, the 747 tilted backwards.
I assume that is the case with these 787s.
blueflyer
Fri Aug 24, 2012 5:25 am
Put replies #1 and #2 together and you have the answer.
The 787 delays are notorious. No need to spend money to buy engines that are not (yet) needed.
Democracy 2016: 3 million California votes < 100,000 Midwest votes.
XFSUgimpLB41X
Fri Aug 24, 2012 5:40 am
Aren't those aircraft awaiting structural strengthening?
Chicks dig winglets.
FI642
Fri Aug 24, 2012 2:29 pm
Engines provide a lot of forward CG for the aircraft. I have seem weights attached to an aircraft awaiting an engine change.
737MAX, Cool Planes for the Worlds Coolest Airline.
INFINITI329
Fri Aug 24, 2012 2:35 pm
The weights I would assume is the average weight of engine and nacelle?
DualQual
Fri Aug 24, 2012 3:30 pm
Quoting XFSUgimpLB41X (Reply 5):
Training with those weights should build the strength
Sorry, couldn't resist!
There's no known cure for stupid
Stitch
Fri Aug 24, 2012 3:32 pm
Assuming they're early builds, they would be in need of change incorporation and re-work.
9lflyguy
Fri Aug 24, 2012 5:55 pm
Not to be off topic too much but since we're discussing the photo, what are the two WN jets doing at KPAE i(upper right hand corner)? Are these new deliveries or conversions from AirTran? Just want more information on those two birds.
319 320 321 722 732 733 734 735 737 738 739 752 753 763 772 CR2 CR7 CR9 DHA D8B D8C D95 145 170 175 190 M82 M88 M90 S340
Ronaldo747
Fri Aug 24, 2012 6:20 pm
Quoting 9lflyguy (Reply 10):
IIRC the 738 gets LifeTV or similar systems at PAE. All SWA 738 flies to PAE after delivery at first before entry intro service.
airplanenut
Fri Aug 24, 2012 6:52 pm
A good amount of maintenance is done at PAE. AS and SW both have 737s going in and out daily, and there are also some DL birds (mostly MD80s).
Quoting infiniti329 (Reply 7):
If memory serves correctly, those are marked around 15,000lbs each.
Why yes, in fact, I am a rocket scientist...
747-600X
Sat Aug 25, 2012 1:06 am
The risk of them tipping backwards seems to be relatively low, given that the nose gear strut appears tethered to the ground. (Although this raises the question of why there would be tie-downs in the middle of a runway...)
nomadd22
Sat Aug 25, 2012 1:39 am
Quoting 747-600X (Reply 13):
That doesn't really follow. You don't want to hold a plane down by the nose gear.
Anon
adam42185
Sat Aug 25, 2012 2:40 am
Quoting DualQual (Reply 8):
I lift things up and put them down!
vaus77w
Sat Aug 25, 2012 4:08 am
Quoting AR385 (Reply 3):
This video demonstrates this:
http://www.youtube.com/watch?v=cHhZwvdRR5c
QANTAS747-438
Sat Aug 25, 2012 4:34 am
I think they are new deliveries... N8319F and N8320J, -800s.
wjcandee
Sat Aug 25, 2012 5:09 am
Quoting adam42185 (Reply 15):
One of the greatest gym commercials ever. Almost joined just to reward them for that!
http://www.youtube.com/watch?v=eOSeOieLh7s
justplanesmart
Sun Aug 26, 2012 1:01 am
Quoting QANTAS747-438 (Reply 17):
Those two have not been delivered yet, having just made their first flights this week (August 23). Also, the aircraft toward the rear clearly has only one over-wing exit. It might be N7734H, formerly N300AT, which just flew overnight (August 25) from Paine to Sea-Tac for reentry into service.
"So many planes; so little time..."
