KU747
Questions About A380 Landings.
Sat Sep 01, 2012 11:47 pm
I flew on A380 more than 10 times, and not even once I experienced a smooth landing.
All 10 flights were very hard landings!!!
It got me to a point that I don't look forward to enjoy flying on A380.
My questions are the following:
- Anyone experienced a smooth landing on A380 ??
- Doesn't the frequent hard landings cause a frame and metal fatigue which will shorten the life of the aircraft??
- I understand that it is a giant aircraft but is it possible to land it smoothly or it is designed for the hard landings only??
[Edited 2012-09-01 17:09:16]
707,727,73all,741,742,743,744,752,753,762,763,77all,300,310,319,320,321,332,333,343,346, L10,L15,DC10,MD11,SSC,VC10
Stitch
Sun Sep 02, 2012 12:02 am
Were they all on the same airline?
My A380 experience has been with SQ and they seem to be able to put her down without knocking luggage out of the bins.
col
Sun Sep 02, 2012 12:07 am
I guess we have not had a 380 bash for about a week, so one was due.
Sometimes hard landings are carried out due to conditions, but I find it hard to believe you would not look forward to flying on a 380 because of a bad landing or two.
Quoting KU747 (Thread starter):
- I understand that it is a giant aircraft but is it possible to land it smoothly or it is designed for the hard landings only ??
- SQ and EK have been great flights with great landings for me, many times now.
- I would think that your hard landings must have led to the airframe being taken out of service and inspected if you question frame/metal fatigue!!!
- I do not believe that you are asking this question. All aircraft are the same, they flare and land at similar rates, except when conditions dictate a firmer hit with the tarmac.
This is a strange topic!
EPA001
Sun Sep 02, 2012 12:20 am
Quoting Stitch (Reply 1):
Good question.
I only flew the A380 4 times. Three landings were extremely smooth, one was a normal landing. Overall a very good score imho.
UALWN
My A380 landings, with LH and SQ, have been totally normal.
AT7/111/146/Avro/CRJ/CR9/EMB/ERJ/E75/F50/100/L15/DC9/D10/M8X/717/727/737/747/757/767/777/787/AB6/310/32X/330/340/380
KU747
Sun Sep 02, 2012 12:22 am
All on EK DXB-LHR-DXB
I'm telling you 10 flights with 10 very hard landings with a big bang, at LHR and DXB, and most of the time the weather was nice.
I totally understand landing procedure and the flaring but it is very strange for me not to experience a smooth landing an A380 with 10 flights???
Quoting col (Reply 2):
No, I'm not saying that. What I'm saying that if the A380 always lands very hard, it will eventually leads to frame and body fatigue.
johnclipper
Sun Sep 02, 2012 12:24 am
same - I have had 6 A380 landings. My description would not be so much "HARD" as "FIRM". It does not land like a 747.
"Flown every aircraft since the Wright Flyer" (guys, if you take this literally, then you need to get a life...)
KU747
Sun Sep 02, 2012 12:25 am
I guess all my 10 flights on A380 are flown by junior pilots!!!
ulfinator
Sun Sep 02, 2012 12:30 am
I can't find the thread now but there was a discussion about a hard landing that damaged a plane (767 I think) and part of it was about how the main gear articulates. The gist of the discussion was that the main gear angles forward on the 767 and A380 and backwards on other aircraft and people thought that it might be harder to get a smooth landing with that configuration.
michaeljp
Sun Sep 02, 2012 12:40 am
Quoting ulfinator (Reply 8):
I believe your talking about the ANA B767 that landed back into Japan (Osaka) IIRC which due the the landing buckled the fuselage.
I'm not sure exactly what happened to the a/c afterwards.
If it was a Boeing I'd say that its a textbook landing as Boeing "recommends" a FIRM landing. Usually it also depends where your sat, if you are sat right above the bogey's for example your impression of the landing will differ to someone who sits on the upper deck at the front of the a/c or at the back.
Unless you or I were flying the plane its purely speculation, however....wind plays a part in it. It may be a nice day but their may be a crosswind, there although rare may be tailwind (this is unlikely though!).
Although I cannot speak from a crew POV with the A380 I have always tended to find the cushioning on the Airbus's to be somewhat less that smooth in general down the general gear structure.
All the best
KU747
Sun Sep 02, 2012 12:51 am
Quoting michaeljp (Reply 9):
I was on the upper deck in the front. I also felt the rebound, sort of a bounce but not a complete bounce!!
ktachiya
Sun Sep 02, 2012 12:53 am
I think you meant to say NRT?
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
tdscanuck
Sun Sep 02, 2012 1:01 am
Not really. "Hard landing" in the context you're talking about is "normal landing" the realm of fatigue analysis. "Hard landing" by the maintenance definition does require inspection but that's far more for static damage than fatigue damage.
Quoting KU747 (Reply 5):
All aircraft experience frame and body fatigue, all the time. In the scheme of the complete array of loads they're subjected to, landing isn't a particularly big problem for fatigue (it can be a big problem for static loading). Infrequent overloads can actually improve fatigue life (a process called autofrettage).
Tom.
yvphx
Sun Sep 02, 2012 1:02 am
Could this be possible because the A380 is still a relatively new aircraft, with only a comparable handful of pilots flying on, that pilots are still getting used to it?
I understand many of the pilots transitioned from the A340, I think? Perhaps the OP has experienced cross-winds which dictate a firmer landing than othertimes.
I havn't been on an A380 yet (darn) but regardless of what kind of landing I would get when I fly on one, any landing you walk away fom is a good landing!
KU747
Sun Sep 02, 2012 1:09 am
Quoting tdscanuck (Reply 12):
Thanks for the clarification. I read an article a while back about Southwest Airlines aircrafts can get frame and body fatigue sooner that other US carriers due to the frequent landings per day.
col
Sun Sep 02, 2012 1:18 am
Quoting KU747 (Reply 14):
That is cycles per day, with being pressurized. Landings are OK. Holes in roof and cracks found because of the cycles they do.
XT6Wagon
Sun Sep 02, 2012 1:45 am
Quoting col (Reply 15):
I'd assume that more frequent inspections and MX would still occur if you did high numbers of takeoffs and landings without pressuraztion cycles. Not likely to be a concern on a typical airliner, but we all know somewhere out there is the exception that proves the rule.
AngMoh
Sun Sep 02, 2012 2:15 am
I think for the A380 it depends a lot where you sit. I had one flight where I sat on the upper deck and a colleague sat on the lower deck. I experienced a smooth landing while my colleague complained about a very hard and uncomfortable landing.
The only time I experienced a "firm" landing on the A380 was when I was seated on the lower deck straight above the main landing gear. The sound of extending and retracting was also quite loud.
727 732 733 734 735 73G 738 739 739ER 742 743 744 752 762 772 773 77W A300 A310 A319 A320 A321 A332 A333 A343 A345 A346 A359 A388 DC-9 DC-10 MD11 MD81 MD82 MD87 F70 ERJ145 E175 E190 E195 ATR72 CRJ200 CRJ700 CRJ900 BAE146 RJ85
tdscanuck
Sun Sep 02, 2012 2:37 am
Quoting yvphx (Reply 13):
That shouldn't be the case; any pilot that's flying paying passengers has already been thoroughly trained and evaluated, including a lot of simulator time. And, unless the A380 is the one exception, landing in the sim is almost universally harder than landing in the real world because the visual and tactile cues (though good) aren't perfect.
Quoting XT6Wagon (Reply 16):
A cycle for maintenance purposes is a takeoff+landing. It doesn't matter if you pressurize or not, so it will not drive more frequent inspections. However, if you're not pressurizing then you'd expect to find less issues at the scheduled inspections.
Tom.
gr09
Sun Sep 02, 2012 3:30 am
I flew on A380 four times (2xLH, 2xSQ) and all landings were perfectly smooth.
CXfirst
Sun Sep 02, 2012 4:24 am
I've flown the A380 3 times (2x SQ, 1x QF). I have had two really smooth landings, and one hard, but the hard one was it bad weather, so expected (although it wasn't very hard).
-CXfirst
TWA772LR
Sun Sep 02, 2012 4:33 am
Quoting KU747 (Reply 7):
It usually all boils down to the pilots. I have flown on the rare Colgan Q400 flights where the landing couldnt even wake a sleeping baby, then I've been on one a couple weeks ago when I was actually in a little bit of fear for my life. Granted, most regional airlines have younger, less experienced pilots so it's understandable.
Every time I fly Colgan with my dad, he always jokes that the pilots must have been ex-Navy pilots.
And for my next miracle, I'm gonna turn water into funk!
captainstefan
Sun Sep 02, 2012 10:11 am
Quoting KU747 (Reply 10):
Quoting AngMoh (Reply 17):
Agreed. Though I'm not sure which thought process to follow. Is it:
a) The further you are from the landing gear/point of impact, the smoother your perceived touchdown will be because the fuselage dissipates the energy from the touchdown
OR
b) The further you are from the landing gear, the rougher the landing will seem due to flex in the fuselage and the moment/arm from the 'fulcrum' or MLG?
Long Live the Tulip!
my235
Effect Of Bogie Tilt On Landing (by WingedMigrator Aug 25 2012 in Tech Ops)
And yes I truly believe aircraft with back tilting bogies are *much* smoother on touch down. http://youtu.be/lowrM-780tg A330/340, 747, 757, 777, The 747 and A330/340 have the most tilt in the MLG.
lhrnue
Sun Sep 02, 2012 10:19 am
I had normal landings with the A380 in Sydney and Auckland. The landing in DXB was a hard one, but it was during a sand storm, so nothing to do with the aircraft.
I maybe want to ask the question about LHR little bit different. I am a frequent flyer into LHR with different airlines ... and my FEELING is that the average landing into Heathrow is harder than elsewhere. My theory is, that pilots (I am not one) are under some time pressure at LHR (the next aircraft is sitting right in their neck) and nobody wants to loose the slot and go around. I am not saying anything is outside of normal procedures or not safe, just the pressure to get the aircraft down is higher. ... now you can shot me.
Max Q
Sun Sep 02, 2012 10:28 am
Well I think it has a lot to do with the forward tilt on the main landing gear, whether it's a 767 or an A380 it is just an unforgiving design.
When you look at the superb design of the landing gear on the B747 you don't have to be an engineer to figure out how that configuration is very forgiving on landing for the Aircraft and it's passengers.
I know it sounds corny but there was a good reason why, since the Queen of the skies first flew the expression was 'you can't make a bad landing on a 747'
The landing gear has to take credit for part of that statement.
strangr
Sun Sep 02, 2012 11:32 am
I guess almost all flights in an A380 would be by junior pilots. After all the 747 has been around for 20+ years and the a380 has been around for what 4.
RE: Questions About A380 Landings.
Mon Sep 03, 2012 12:21 am
10 landings is not a big enough sample. The airlines you've flown with have already performed thousands of landings with the aircraft. How can you know they have all been firm?
Hardly. Experienced captains are perfectly capable of making less than smooth landings, intentionally or not.
This is the core of the poodle. You might call them hard but most likely all those landings were well within acceptable parameters.
Pilots may choose to plonk the aircraft down firmly if the runway is wet or not too long. You don't want to float and try to grease it if it might make you run out of runway or miss your turnoff. Comfort is important but safety is much more important.
The quality of the pilot can not be deduced from the softness of the landings.
mandala499
Mon Sep 03, 2012 5:05 am
Quoting Starlionblue (Reply 27):
But the quality of the passenger can be deduced from their reaction to the landing impact acceleration.
BA777
Mon Sep 03, 2012 11:37 am
Just because you had firm landings does not mean they were flown by junior pilots! Captains also make firm landings.
bond007
Mon Sep 03, 2012 1:17 pm
Quoting TWA772LR (Reply 21):
Making a good, safe landing comes down to pilot training and experience ...almost all landings, for all airlines, for all aircraft types, are good landings. Now on the other hand, making a touchdown that you can hardly feel, as opposed to one that is a little firm, is more a matter of luck, rather than judgement.
Jimbo
CamiloA380
Mon Sep 03, 2012 2:33 pm
I would rate my A380 landing in SIN, smooth- , so firm it was (and we aborted the first approach due to some unexpected showers, and came in for a second approach to land on a wet runway). My landing in FRA, was firm too. But whats the huge deal about it if its not a really bad landing? If it doesn't exceed a certain g value then it doesn't visit maintenance. (Was it 2.5gs?)
You seriously can't be that simplistic. Everything is not either black or white.
Any landing/take off or flight in general leads to long term frame and body fatigue (then it reaches a certain cycle, and things are checked). Correct me if I'm wrong.
So let's say that's the case. So what?
Quoting mandala499 (Reply 28):
Flying4Ever!
tdscanuck
Mon Sep 03, 2012 3:11 pm
Quoting CamiloA380 (Reply 31):
2.5g would certainly warrant an inspection. 2.5g is the in-air limit load.
Landing sink rate inspection triggers usually come off sink rate...anything over ~10 fps at touchdown typically drives an inspection.
Tom.
bueb0g
Fri Sep 07, 2012 5:52 pm
To be fair, the Q400 is a bitch to land 'nicely'
Quoting strangr (Reply 26):
This isn't relevant... inexperienced on type =/= junior... Most A380 flight crew are at the more experienced end of the spectrum for their roles. Plus new pilots can manage some beautiful landings, and experienced pilots can sure as hell execute firm ones.
Roger roger, what's our vector, victor?
Daleaholic
Fri Sep 07, 2012 6:11 pm
Let's be frank here... You're putting roughly three hundred and eighty six tons (MLW) onto a combined surface area (the tyres) about the size of a car... 22 wheels (think of how much actually comes into contact with the runway, not much). I'd say rough or smooth landing, that's a marvellous feat of engineering.
For those who are interested, a sum at max landing weight... 386k divided by 22 =17545.4545455
So that's 17.5 tons being supported on each wheel. Just think about that...
Religion is an illusion of childhood... Outgrown under proper education.
CPDC10-30
Sat Sep 08, 2012 8:49 pm
Not a scientific observation in any way. But the firmest landing I've ever experienced was on a SQ A388 JFK-FRA. I was on the upper deck at the rear, and other pax looked around in surprise at how hard the landing was.
I could tell it would be firm as the flare seemed too late. Conditions were very calm. Maybe just a coincidence.
Francoflier
Sun Sep 09, 2012 12:17 pm
Quoting Daleaholic (Reply 34):
And that's just at 1g. The vertical speed when touching down is still several feet per second. So the tires also absorb the energy needed to decelerate those 386 Tons from that vertical speed to 0.
tdscanuck
Sun Sep 09, 2012 1:16 pm
Quoting francoflier (Reply 36):
The tires are just force-transmission devices; they absorb relatively little of the total energy for that. Most of it ends up in the strut (as heat and compressed nitrogen).
Tom.
chuchoteur
Tue Sep 11, 2012 7:42 pm
Same on airbus... positive contact required to achieve predictable/shortest landing distances. Back in the old days japanese pilots flying the A300 had to be retrained as they worked hard to grease their landings, then couldn't figure out why they were consistently exceeding advertised landing distances.
Maybe it's company policy... if there's an EK pilot out there...
kazim786
Fri Jan 18, 2013 12:58 am
Ive flown on the A380 many times too. All in all i would say out of 13 flights- 3 were hard landings. And these were once with:
Emirates- landing at EGLL.
Qantas- landing at KLAX
Lufthana- landing at EDDF
Albeit the landings were due to rough and windy conditions on approach. Other than that the rest of the flights resulted in a smooth landing. So from experience, I'd say the A380 can without a doubt conduct a smooth touchdown.
Fri Jan 18, 2013 2:43 am
Quoting kazim786 (Reply 39):
13 flights is not a very big sample. If you've landed 80-100 times you can start making good statistics. And then you'd have to do the same on a lot of other types to compare.
Any plane can be landed smoothly. Some are harder than others. Rough and windy means you are more concerned with staying on centerline and in the touchdown zone than gently kissing the ground. Floating to a greaser means more time where the plane can drift to the side or be caught in windshear. Besides, as mentioned above greasers lead to longer landing distances.
And what do you mean by "hard landing"? Did the overhead bins open? Did people bite their tongues? Did anyone get whiplash? Positive contact with the ground is not a "hard landing". An actual hard landing (maintenance definition) might well lead to injuries. Serious G forces.
GlobalMoose
Fri Jan 18, 2013 11:40 am
I'd take a firm touchdown in the landing zone over a soft touchdown outside the zone anyday.
Without knowing too much about the TOLD considerations/assumptions of the A380, maybe the pilots had opted to put it down with 'authority' in order to meet computed landing distances (as stated in an earlier post).
A bit off topic but I was also told that a firm landing is always preferred in wet weather to help 'break through' any standing water on the runway and help get the gear on the pavement and all spun up. True or not, whenever I have a bit of a firm landing on clear days I can always claim that I'm practicing my wet wx landings
When it absolutely positively has to be there ... at some point.
m1m2
Fri Jan 18, 2013 1:52 pm
I've only been on one A380 flight. That landing I thought was rough. I figured it was just the massive size of the gear and all of those tires spinning up that sent the shudder through the plane. If you think about it, a fair amount of energy is needed to spin those main wheels up to the speed the airplane is traveling at when it touches down.
Having said that, I did enjoy the flight. It was EK from AKL to SYD.
RussianJet
Fri Jan 18, 2013 2:36 pm
Been on the A380 just once - landing was fine. Not a greaser but not noticeably hard either.
✈ Every strike of the hammer is a blow against the enemy. ✈
David L
Fri Jan 18, 2013 5:55 pm
Quoting m1m2 (Reply 42):
But countering that is a whole load of inertia on an aircraft with the mass of a 380. I wouldn't have thought the wheel spin-up issue would be much worse for a 380 than it is for a 747.
Sat Jan 19, 2013 9:14 am
Was the seat location the same.......or similiar each time....
gigneil
Sun Jan 20, 2013 7:09 am
I would think that given the huge size of the airplane and the monsterously large for its size wings, ground effect would require you to fly into the ground, as opposed to simply lose altitude onto the runway.
I have been under the impression the 747 was similar... am I mistaken?
NS
Sun Jan 20, 2013 10:58 am
Quoting gigneil (Reply 46):
It's a matter of proportion. A 767 or an MD-80 have much smaller wings, but on the other hand they weigh proportionately less. I think wing loading, planform and wing position along the fuselage have a big effect.
[Edited 2013-01-20 03:23:14]
Users browsing this forum: KrustyTheKlown, ucdtim17 and 1 guest
