my235
Thrust Reverse Noise.
Fri Sep 07, 2012 4:43 am
Thrust reverse noise from modern high bypass turbofans is as loud as it is because the bypass air is no longer surrounding and muffling the hot center jet exhaust. Am I correct?
ak907
RE: Thrust Reverse Noise.
Fri Sep 07, 2012 5:16 am
My guess would be because instead of going straight out the back with little resistance, the air is now being rerouted vanes and going through vents, some of it eventually hitting the ground. All of this will cause turbulence.
tdscanuck
Fri Sep 07, 2012 2:27 pm
Quoting my235 (Thread starter):
Not really. The major contributor is the terribly turbulent flow coming through the cascade vanes...the air is being wrenched around fairly violently. You're also bypassing all the acoustic treatments in the aft nacelle that help shut up the fan flow in normal operation.
There is some increased noise from the core flow but reverse thrust isn't as high a core flow as full forward thrust and, since noise scales roughly by RPM to the 8th power, small drops in core flow cause big drops in noise.
Tom.
vikkyvik
Fri Sep 07, 2012 5:13 pm
Quoting tdscanuck (Reply 2):
Wow, really? Very interesting - I learned something today!
David L
Fri Sep 07, 2012 6:34 pm
Quoting vikkyvik (Reply 3):
Me too. I think it's the first time I've heard of the 8th power of something doing anything!
tdscanuck
Fri Sep 07, 2012 7:21 pm
It's a bit complicated by the fact that decibels are a log scale...technically, it's the noise power that scales with the 8th power of speed. Perceived noise is a whole different animal.
Quoting David L (Reply 4):
Me too. I first learned that back in undergrad when we were trying to design a quiet leaf blower.
Tom.
vikkyvik
Sat Sep 08, 2012 3:29 am
Seriously! This sounds like perfect trivia material.
Quoting tdscanuck (Reply 5):
Gotcha. Still very interesting. Thanks Tom.
tdscanuck
Sat Sep 08, 2012 4:37 am
Found a reference! Turns out it's called Lighthill's Eights Power Law:
http://en.wikipedia.org/wiki/James_Lighthill
The noise power from the jet jet scales with the 8th power of the jet speed. At the time I was working with it we were playing with a centrifugal fan, for which jet speed and RPM were basically linear so it also scaled with the 8th power of RPM. I'm not sure that relationship holds true for axial fans.
Tom.
C46
Sat Sep 08, 2012 8:50 am
You mean a rake?
Sat Sep 08, 2012 10:28 am
The blocking of Airflow & then deflecting it thru cascade vanes forward contribute to the noise.
jumbojim747
Wed Sep 19, 2012 7:14 pm
Does over use of the reverser's make for higher maintance.
I'm asking this as some companies tell pilots if they can do without useing then do so.
The Qantas 747 that overshot the runway never used reverse thrust
On a wing and a prayer
LH707330
Wed Sep 19, 2012 8:28 pm
Quoting JumboJim747 (Reply 10):
I think it's got more to do with brake cooling and wear than anything else, but I always find it annoying when they use reverse just because of the noise....
tb727
Thu Sep 20, 2012 1:25 am
Reverse thrust is more effective at higher airspeed than brakes and vice versa as you get slower, at least on what I fly. I will very rarely touch the brakes above 70 knots if I have a long enough runway. I have heard the 727's brakes aren't the easiest to change so I try my best and not abuse them. Plus I like the noise
tdscanuck
Thu Sep 20, 2012 2:48 am
Most modern thrust reversers are on-condition maintenance and have no set maintenance tasks tied to thrust reverser cycles (they've got tasks tied to aircraft cycles but that happens whether or not you use the reverser).
That said, the moving parts in the reverser wear, primarily, with cycles (mostly the actuators, actuator attach fittings, and hinges). So more reverser cycles will tend to drive you to on-condition replacement of the moving parts more often.
Whether that costs more or less than the increased brake wear depends a lot on the aircraft and the operations; with carbon brakes becoming more common the economic case for the reversers goes down because the carbon brakes wear by cycle, not by amount of energy absorbed (steel brakes are the opposite).
If you have a structure problem on the cascades (notorious on a few designs) that will also go with cycles but that's really a design problem.
Tom.
Thu Sep 20, 2012 6:25 am
The low bypass Turbofans like the JT8Ds used to reverse the entire airflow and were noisier.....
MQTmxguy
Thu Sep 20, 2012 9:51 am
My company has on occasion pressured our flight crews to keep T/R usage to a minimum on the ERJ fleet in the name of maintenance costs and reliablity so now...
...you guessed it, brakes are being changed at a record pace.
I hate bean counters
Well at least we can all take comfort in the fact that NW will never retire their DC-9s
okees
Thu Sep 20, 2012 1:54 pm
Quoting LH707330 (Reply 11):
I find it annoying when they do NOT use the reverse thrust.. because of the noise! I love it, it's the second best part about landing (first would be finally reaching your destination).
mobs jakis
jumbojim747
Thu Sep 20, 2012 2:17 pm
Quoting HAWK21M (Reply 14):
That was how they could reverse the aircraft from the gate although dangerous
Users browsing this forum: benbeny, longhauler, SaveFerris and 2 guests
