blueflyer
Letters In Call Signs
Sat Sep 15, 2012 4:52 am
I think I know (most of the time) why airlines use letters in their call signs when talking to ATC. What I am wondering is whether there is any logic in the "translation" between flight numbers and call signs. I know some British charter carriers use two letters, one each for inbound and outbound flights, but other carriers seem totally random.
For example, why does TAY161 become Quality 61 Golf instead of Quality 16 Golf, or Quality 61 Lima or another other option? I can't equally find any logic for Speedbird or Lufthansa, among others. Is there any or is it random?
Democracy 2016: 3 million California votes < 100,000 Midwest votes.
wilco737
RE: Letters In Call Signs
Sat Sep 15, 2012 6:07 am
Quoting blueflyer (Thread starter):
On LH short haul flights the numbers and letters are random. So you cannot see which flight number it actually is.
The callsigns remain the same everyday. So with some research you can find out which flight it is.
Wilco737
CosmicCruiser
Sat Sep 15, 2012 6:55 am
We sometimes must add a letter to a flight number if there's the same flight no. operating anywhere else at the same 24hr period.
skyhawkmatthew
Sat Sep 15, 2012 8:54 am
QantasLink and Virgin Australia append letters to identify aircraft with vastly different performance.
The A in 'Virgin 123 Alpha' is appended to identify an ATR, which is obviously much slower than the rest of the Virgin (jet) fleet. Equally, QantasLink appends a D, as in 'Qlink 123 Delta' to identify Q400s (ICAO DH8D), which have much better performance than the other Dash 8 series aircraft.
Qantas - The Spirit of Australia.
Fabo
Sat Sep 15, 2012 9:24 am
Aside from identifying characters as in Virgin Australia and Qantaslink examples, most of the airlines changed to alphanumerics because it was too common to mistake your callsign to a similar callsign of your own, or even other carrier.
For example, if there was a Speedbird 602 inbound and Speedcat 602 outbound, or if you flew Airline 952 and there was another Airline 592 flight... Airlines moved do alphanumerics so that there is less chance of confusion. Some tried to use alphanumerics based on destination, but of course then you ended with all flights of non-based carriers being, for example, nBP (EZY2BP, AUA3BP, AFR4BP) on frequency in Budapest, so these combinations must be random. Some airlines will then alter them if a similar callsign is reported to be met on frequency regularly.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
blueflyer
Sun Sep 16, 2012 9:21 pm
So sometimes it is random, sometimes not, very interesting.
Quoting skyhawkmatthew (Reply 3):
I'm guessing ATC has been made aware of the reason behind the use of the letters then?
skyhawkmatthew
Mon Sep 17, 2012 2:55 am
Quoting blueflyer (Reply 5):
I expect ATC sequencing is the whole reason behind the use of the letters: they're not used in any public-facing communication.
AJ
Mon Sep 17, 2012 3:32 am
Additionally, Qantas (mainline) uses a D for a delayed service, as it is quite possible to have two flights airborne with the same flight number otherwise.
Goldenshield
Mon Sep 17, 2012 11:11 am
Quoting skyhawkmatthew (Reply 6):
Seems a bit redundant to me. The aircraft type is already part of the flight plan.
skyhawkmatthew
Mon Sep 17, 2012 11:29 am
Quoting Goldenshield (Reply 8):
Yes, but if you're busy dealing with large amounts of traffic (and a lot of 'Qlink' aircraft about: QantasLink makes up around 40% of Qantas group flights), it's a more obvious cue that that aircraft is much faster than the rest. IIRC the Q400 is in a heavier wake turbulence class as well.
Goldenshield
Mon Sep 17, 2012 12:52 pm
Quoting skyhawkmatthew (Reply 9):
In the enroute portion, I guess it'd make sense, but in the terminal environment, it's not going to be as obvious; everyone's going the same speeds. (At least, here in the States they are. I don't know about Oz.)
I'll go ask Los Angeles Center how they feel about something like this.
Viscount724
Mon Sep 17, 2012 10:48 pm
KLM has 2 daily flights AMS-YYZ. They're booked as KL691 and KL695. For operational purposes KL691 uses the callsign KLM31. The other flight retains its actual flight number and operates as KLM695.
fxra
Tue Sep 18, 2012 4:53 am
Back a while back, FDX used to use a lot of letters on int'l flights for traffic rights and regauging of aircraft. FOr example (I'm pulling these numbers out of the air) There used to be a FX19 that was IND-ANC-NRT on say an MD-11, then an A300 would operate 19K NRT-ICN and and noather airbus would operate 19M NRT-HKG. I asked once why the letters and was told that often is was due to traffic rigths requirements.
Visualize Whirled Peas
Users browsing this forum: gloom, Google Adsense [Bot], kurtverbose and 1 guest
