LY777
Why Don't 757s Have The Same Nose As 737/727/707s?
Sat Sep 15, 2012 8:54 pm
All Boeing narrowbodies (707/727/737) have the same nose, except the 757, why?
[Edited 2012-09-15 13:56:22]
IMissPiedmont
RE: Why Don't 757s Have The Same Nose As 737/727/707s?
Sat Sep 15, 2012 8:58 pm
Boeing went with a common cockpit and type rating of the 757 and 767
The day you stop learning is the day you should die.
PHX787
Sat Sep 15, 2012 9:20 pm
Quoting IMissPiedmont (Reply 1):
Apparently as well, the 767 and the 777 share very similar cockpit components. (IIRC, isn't the 767 section 41 the same as the 777?)
Viscount724
Sat Sep 15, 2012 9:54 pm
Quoting PHX787 (Reply 2):
According to Reply 16 in this 2010 thread, the only part of section 41 that's the same is the frame around the cockpit windows and the radome.
777 "Neck"? (by Aerdingus Jan 14 2010 in Civil Aviation)#1
BoeingGuy
Sun Sep 16, 2012 6:58 pm
That has nothing to do with the OP's question. The shape of the nose itself has no relation to whether the flight deck instruments are identical enough to achieve a common type rating.
The 767-400 and 777 have a few similarities in the flight deck (a relatively few actually) but again nothing to do with the OP's question.
To be honest I don't know the answer to the OP's real question but perhaps a long time Boeing person who worked on the 757 program can?
Sun Sep 16, 2012 7:26 pm
Quoting BoeingGuy (Reply 4):
If memory serves, the 757 had to have the cockpit seats at a certain height above the ground to share the rating with the 767. And that's why the 757 nose shape has a lot to do with the type rating.
OldAeroGuy
Sun Sep 16, 2012 8:15 pm
Quoting IMissPiedmont (Reply 1):Boeing went with a common cockpit and type rating of the 757 and 767
Actually. the shape of the 757 nose was dictated by the 767 flight deck arrangement. The 757 nose had to widened and the flight deck floor had to be slanted down to accommodate the 767 flight deck displays. In addition, the flight deck floor had to be lowered, so you step down to enter the 757 flight deck, but step up to enter on the 767's.
The distinct 757 nose was created by these modifications.
Quoting Starlionblue (Reply 5):
The ground height was not important, but forward view was. The 757 and 767 have a similar forward view on approach. This is another reason why the 757 flight deck floor slopes down.
tdscanuck
Mon Sep 17, 2012 12:15 am
It's not just about instruments. The view has to be comparable; there was just no way to get the same visual field in a 737-style cockpit to be close enough to the 767 for common rating.
Tom.
bikerthai
Tue Sep 18, 2012 6:38 pm
Quoting OldAeroGuy (Reply 6):
So is the following statement an urban myth:
The nose of the 757and 767 are also structurally the same for production purposes? I thought I heard somewhere that from cockpit window forward, the 767 and 757 have the same nose shape.
bt
HaveBlue
Tue Sep 18, 2012 6:59 pm
Very interesting, never ever heard of that. And that's why I love these forums!
Here Here for Severe Clear!
DocLightning
Tue Sep 18, 2012 10:23 pm
Quoting bikerthai (Reply 8):
No, that is absolutely false. One need only look at both aircraft to see that it's not true. The parts of the nose visible from the cockpit need to be the same shape, yes, but the entire nose is markedly different.
As for the 707, 727, and 737, recall that Boeing decided to use the same nose for all three to simplify design and construction. Pilots really don't like the 737 nose and there are issues with visibility and ergonomics. When it came time to design the 757, Boeing designed an entirely new narrowbody nose for the reasons outlined in this thread.
It turned out that the 737 would outlive the 757 (something I don't think Boeing forsaw at the time). Boeing can't change the nose of the 737 to match the 757 (although it would make pilots happier) because it would basically make the aircraft into an entire new type and mean that pilots would not be able to move from the 737-classics to the 73G/73MAX series.
You will notice that the A320 and the DC-9 series have similar noses with a "droopy" profile, much like the 757. I am given to understand that pilots like that sort of profile a lot more.
-Doc Lightning-
-Carl Sagan
Viscount724
Wed Sep 19, 2012 1:39 am
Quoting DocLightning (Reply 10):
The forward fuselage section of the 707 is not identical to the 727 and 737, and I don't even think the 727 and 737 sections are completely identical. The 707 in particular has a deeper fuselage from top to bottom than the 727/737.
bikerthai
Wed Sep 19, 2012 1:18 pm
As with most urban myth, there is a sliver of truth.
I found this"
http://seattletimes.com/news/business/757/part03/
"And hanging on Condit's office wall, framed and signed, is one of White's original renderings of how he thought the 767 cab could be fitted to the 757. "
I guess this is where it started. The article is an interesting read.
bt
kanban
Wed Sep 19, 2012 3:56 pm
actually they got tired of A.netters complaining about 50 year old designs...
AAR90
Wed Sep 19, 2012 5:42 pm
Quoting LY777 (Thread starter):
707 is late 1950's design.
727/737 are early 1960's designs.
757 is late 1970's design.
The 727 & 737 followed the original 707 fairly quickly (in time) so their designs were essentially modifications to the original 707 aircraft. There was a significant gap in time before the 757 was developed and there was significant improvement in aerodynamics (and other areas) during that time.
Different era = different designs.
Thu Sep 20, 2012 6:31 am
Cockpit commonality between the B757 AND B767 determined this.
Agreed.....
PurdueAv2003
Thu Sep 20, 2012 7:44 am
Quoting Viscount724 (Reply 11):
I don't think the new cockpit would have changed the type. Look at the changes in wing and pylon structure between the classics and NG. In fact, I had heard a rumor once that Boeing had originally considered the 757 Forward Nose section for the NG, but someone at WN didn't like the look of the design, so they reverted back to the older design.
Ptu = Ftu X Anet (not to be confused with a.net)
tdscanuck
Thu Sep 20, 2012 4:18 pm
Quoting PurdueAv2003 (Reply 16):
The wing/pylon structure doesn't have any impact on crew commonality...the flight deck design has huge impacts. For the same reasons that the 757 and 767 needed very similar flight decks to have a common crew rating, the 737 can't change noses.
Tom.
DocLightning
Thu Sep 20, 2012 5:33 pm
Not at all. As TDSCanuck says, a change in the cockpit changes the type rating for the crew. WN cares not one whit about the look. They care that every single last pilot on their payroll can fly every single last plane in their fleet.
-Doc Lightning-
-Carl Sagan
Users browsing this forum: RohanDXB and 1 guest
