novice
Primary Radar
Wed Sep 19, 2012 12:03 am
Primary Radar;
Wavelength of 30-50cm
Pulse length 4 microseconds (us)
Horizontal beamwidth 1.7 degrees
Aerial rotation 5 RPM
Can anyone explain what the difference the between wavelength and pulse length of a primary radar?
Fabo
RE: Primary Radar
Wed Sep 19, 2012 12:27 am
wavelength is the distance where the wave pattern is repeating (eg. pattern is up, down, down back up to zero, and then again - like a sinusoide), as in, the distance that the signal will make in about the pulselength.
Pulse length is time in which one wave pattern is emmited from the antenna, and frequency is how manny patterns are emmited in one second. 4 microseconds is therefore about 250Hz if I calculate correctly.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
9VSIO
RE: Primary Radar
Wed Sep 19, 2012 2:43 am
Pulse length is also known as period, right?
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
HaveBlue
RE: Primary Radar
Wed Sep 19, 2012 3:54 am
Quoting 9VSIO (Reply 2):
If that's true, then I hate being around my girlfriend when she's on her 'pulse length'...
Here Here for Severe Clear!
SAAFNAV
RE: Primary Radar
Wed Sep 19, 2012 4:26 am
Quoting HaveBlue (Reply 3):
OWM.... Nearly chocked on my coffee! Hate those damn Pulse Lenghts...
David L
RE: Primary Radar
Wed Sep 19, 2012 8:40 am
Radar doesn't transmit continuously, otherwise it would be difficult to tell which part of the signal is being reflected. Instead, it sends a short pulse, stops to listen for a return from that pulse then repeats. The pulse is a short transmission of a signal at a certain wavelength. The pulse length is the length of time each pulse is actively transmitted.
In the example in the OP, each pulse is a signal with a wavelength of 30-50cm which is transmitted for 4 microseconds at a time.
See the diagram here: http://meteorologytraining.tpub.com/14271/css/14271_58.htm
The period is the inverse of the frequency. Since frequency is measured in Hertz, or cycles per second, the period is seconds per cycle - i.e. how long it takes the wave to go from one peak to the next.
Jetlagged
RE: Primary Radar
Wed Sep 19, 2012 6:34 pm
It's the wavelength which is also known as the period.
novice
RE: Primary Radar
Wed Sep 19, 2012 8:01 pm
Thanks for that explanation David L
speedbird128
RE: Primary Radar
Sun Sep 30, 2012 1:27 pm
Quoting David L (Reply 5):
= PRF.
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
