Tupolev160
Steering The Main Landing Gear
Tue Sep 25, 2012 5:23 pm
I was surprised to notice that the main wheels on the AN-124 are actually capable of steering which is the first time to hear anything similar about a wide-body aircraft (or an aircraft in general). Has anyone among you got some other examples of aircrafts capable of steering the main landing gear in order to avoid excessive tire-friction? Is that an issue on the 777 for example which has a quite long landing gear as well? Besides that, do you know how are those wheels operated, automatically together with the front-ones or via a separate mechanism? If so, who is operating them, the flight engineer or also the pilots themselves? Furthermore, are they all capable of steering or only the 2 first and last rows? Thanks.
http://www.airliners.net/photo/Volga...d=4d58602287926fe8623abcefcec523b8
"In a time of universal deceit, telling the truth becomes a revolutionary act."
zanl188
RE: Steering The Main Landing Gear
Tue Sep 25, 2012 5:26 pm
747 body gears steer & I believe one axle on each 777 main gear steers as well.
Tue Sep 25, 2012 6:23 pm
Quoting ZANL188 (Reply 1):
Indeed. The rearmost axle on the 777 mains steers.
Quoting Tupolev160 (Thread starter):
It's automatic, as well as speed and deflection dependent. Transparent to the pilot. Besides on the 744 and the 777 there is no flight engineer.
vikkyvik
Tue Sep 25, 2012 8:39 pm
C-5 rear main gear bogeys are steerable. AN-225's rear 3 axles (I think) are steerable.
Quoting Starlionblue (Reply 2):
Don't they get locked out for takeoff or something like that?
Jetlagged
Tue Sep 25, 2012 8:52 pm
Quoting vikkyvik (Reply 3):
On the 747 the body gear is normally locked straight ahead. It will only unlock at low ground speed and with a large tiller input, so by default they are locked during takeoff and landing. In the 747-400 this is entirely automatic. The 747 Classic has a body gear steering disarm switch which is guarded (disarm position) and only set to arm during taxi. On the Classic ground speed isn't an input to the BGS control system, hence the need for manual disarm.
citationjet
Tue Sep 25, 2012 9:32 pm
B-52, although not a wide body.
A notable feature of the landing gear was the ability to pivot the main landing gear up to 20° from the aircraft centerline to increase safety during crosswind landings.
http://en.wikipedia.org/wiki/B-52_Stratofortress
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
tdscanuck
Wed Sep 26, 2012 3:13 am
On the 777, you have to taxi straight ahead at low speed for the rear axles to straighten and lock. If you try to advance the throttles without the MLG steering locked you'll get a takeoff warning.
Tom.
jumbojim747
Wed Sep 26, 2012 2:46 pm
Not meaning to plug my photos but here you can clearly see the 747 mlg at an angle in a turn
http://www.airliners.net/photo/Unite...d=89f13c83d25b6115db81a395c2a77dc4
On a wing and a prayer
vikkyvik
Wed Sep 26, 2012 3:25 pm
Quoting tdscanuck (Reply 6):
So in the case where they do a sharp turn onto the runway, then commence the takeoff roll from right there, do they ignore the warning?
freeze3192
Wed Sep 26, 2012 9:30 pm
Quoting vikkyvik (Reply 8):
Absolutely not. Takeoff warnings are not to be taken lightly. If the crew gets a takeoff warning light/horn, the automatic response is to abort the takeoff and figure it out later.
"A passenger bets his life that his pilot is a worthy heir to an ancient tradition of excellence and professionalism."
tdscanuck
Wed Sep 26, 2012 11:53 pm
No, you have to fix it. But it will come up as soon as you advance the throttles so you'll catch it before you gain any speed. Abort the takeoff (super low speed RTO), let the gear lock, takeoff.
Tom.
vikkyvik
Thu Sep 27, 2012 2:33 am
Quoting freeze3192 (Reply 9):
I'm not saying they are to be taken lightly. But having never been in an airliner cockpit during takeoff, I have no idea if there are different levels of warnings or whatever.
Quoting tdscanuck (Reply 10):
Does that mean they allow the gear to lock prior to entering the runway? Just curious, as there are plenty of places with relatively sharp 90-degree turns onto the runway....
Thanks.
tdscanuck
Thu Sep 27, 2012 3:40 am
Quoting vikkyvik (Reply 11):
There are different levels, but "warning" is a defined level:
Warning: Immediate crew action required
Caution: Immediate crew notification required, prompt (but not immediate) action may be required
Advisory: Crew notification required, crew action may be required as resources allow
Status: Crew notification not required after dispatch
Memo: Informational only (e.g. "APU", signifying that the APU is running)
A Warning (at least on a Boeing) means an aural, illumination of a red warning light directly in the pilots' field of vision, and a red message on EICAS. It may be accompanied by other red illuminations relevant to the situation (e.g. the fire handles will light up red for a fire warning).
Yes. The gear locks automatically when it centers and unlocks when steering angle exceeds some preset value. As soon as you line up on the runway it should lock.
Yes, the rear axles would normally be steering as you make the turn on. However, the normal lineup process should center and lock the gear. There is a gap beween "off-idle" and the throttle position to trigger takeoff configuration warnings, so the crew can start to bring the engines up as they're lining up and, as long as they don't go for takeoff thrust before they're lined up (which they're not supposed to do), it should work fine.
Tom.
737tdi
Thu Sep 27, 2012 3:55 am
Although not a widebody the DC8-61/71 had castoring bogies. The bogie on the inside of a sharp turn would unlock at high steering angles and would be hydraulically actuated.
vikkyvik
Thu Sep 27, 2012 4:29 pm
Quoting tdscanuck (Reply 12):
Thanks Tom, that's good to know.
Ahh, I gotcha. Makes sense. Thanks.
767eng
Fri Sep 28, 2012 9:17 pm
The A380 body gear also has steering on the rear axle each side. Very similar in operation to the 777
737tdi
Sat Sep 29, 2012 7:07 am
Quoting 737tdi (Reply 13):
Although not a wide body the DC8-61/71 had castoring bogies. The bogie on the inside of a sharp turn would unlock at high steering angles and would be hydraulically actuated.
Just to clarify this. The bogies are not "steerable". They are mechanically controlled through the tiller. Reach a certain steering angle they then break over and allow relief on the main landing gear. This is called castoring, it allows relief of torsional forces on the trunnion bearings.
jumbojim747
Fri Oct 12, 2012 6:07 pm
737tdi.
So the reason for the movement is more for bearing relief does it not assist with the turning of the aircraft.?
ThirtyEcho
Fri Oct 12, 2012 8:35 pm
Even the DC-3 had a lockable tailwheel that was free castoring until locked for takeoff. This was also on the B-17 and other large tailwheel airplanes.
737tdi
Fri Oct 12, 2012 11:12 pm
Quoting JumboJim747 (Reply 17):
737tdi.
Oh, it most definitely improves the turning radius. I don't have access to my old DC8 spec. manuals any longer but the turning radius was better on the 61/71 then the 63/73 (which does not have castoring bogies). I can remember (many moons ago) being asked if I could do a 180 on the runway at SAT, I was taxing a 71. I decided I could and put the tiller hard over and powered only the engines on the outside of the turn and she came around very nicely, I don't think I would have tried it in a 73.
vikkyvik
Fri Oct 12, 2012 11:25 pm
Well, as soon as you steer the main gear wheels (or allow them to turn), you are by default increasing your turning radius. But a major factor is to reduce tire scrubbing, and therefore, forces on the gear.
Quoting ThirtyEcho (Reply 18):
While that's true, the tail wheel was the steerable wheel on those airplanes (or was free castoring, as you said). It wasn't an additional steerable/castoring bogey.
737tdi
Sat Oct 13, 2012 3:13 am
Quoting vikkyvik (Reply 20):
To start, I don't know of any bogies that truly steer. There are aircraft that the whole bogey will crab during landing (747/C5). With most aircraft that have "steerable bogies" only the trailing two wheels will alter their track. They are not steerable per se. The trailing wheels (the rear two of six on the 777 or the rear two of four on the DC8) simply breakover to appx. 45 degrees to reduce stress on the gear but also improve turning radius.
You have it backwards if I read your response correctly. The turning radius is reduced once the bogey unlocks. By the way, only the bogey on the inside of the turn unlocks and castors, the other bogey remains locked. I don't recall exactly when the DC8 bogey unlocks, I think it was around 15 degrees of nose wheel input. Don't hold me to that, its been quite some years since I worked on one.
vikkyvik
Sat Oct 13, 2012 8:47 am
Quoting 737tdi (Reply 21):
The 747 and the C-5 both have bogies that fully turn. The 747's are steerable; I think the C-5's are too, but I'm not positive about that.
Can't comment on the DC-8, but on the 747 and 777, they don't just suddenly turn to one angle. Even if they did, it would be WAY less than 45 degrees. You'd scrub the crap out of the steered tires if you turned them that sharply. They're also not freely castoring; they're steered.
And I quote:
The aft axle steering system is hydraulically actuated and programmed to provide steering ratios proportionate to the nose gear steering angles.
http://www.boeing.com/commercial/airports/acaps/777rsec4.pdf
Same quote for the 747:
This body gear steering system is hydraulically actuated and is programmed electrically to provide steering ratios proportionate to the nose gear steering angles.
http://www.boeing.com/commercial/airports/acaps/7474sec4.pdf
The 747 document also has a nice diagram on page 95 (page 3 of the PDF) that shows how the gears turn. The body gear is limited to 13 degrees max, at a nose gear angle of 70 degrees.
The 777 document also has diagrams in the first few pages; these show that even at max nosewheel steering, the rear axle of the main gear would be nowhere near 45 degrees.
David L
Sat Oct 13, 2012 12:26 pm
A couple of crossed wires, I think...
I suspect that might have been a bit of a whoopsie and Vikkyvik meant that the tightness of the turn can be increased (with the radius being decreased). I keep making a similar mistake with cabin altitude versus cabin pressure.
Quoting vikkyvik (Reply 22):
Quoting 737tdi (Reply 21):The trailing wheels (the rear two of six on the 777 or the rear two of four on the DC8) simply breakover to appx. 45 degrees to reduce stress on the gear but also improve turning radius.
Can I suggest the following amendment?
The trailing wheels (the rear two of six on the 777 or the rear two of four on the DC8) simply breakover to up to appx. 45 degrees
Just a thought...
737tdi
Sat Oct 13, 2012 4:18 pm
Quoting David L (Reply 23):
Just a thought...
Yes!
I have never worked on a 777 or 747 so I can't tell you/answer/comment on how they steer on the ground. I just don't know.
I do know that the 777 does have castoring bogies. I did not know that they would vary their angle with steering angle input. A little more research on my part. Thanks.
CCA
Sat Oct 13, 2012 11:26 pm
Quoting 737tdi (Reply 24):
The 777 does NOT have castoring bogies, castoring wheels are undriven, the 777 has a steering actuator to move the axle in accordance with the nose steering angle.
P1 in A330, A340, A346, B742, B744, B748.
vikkyvik
Sat Oct 13, 2012 11:27 pm
Ahhhh, you are correct, thanks. I always do that.
Just a thought...
No, because I truly doubt they get anywhere near 45 degrees. There's just no possible scenario in which the rear axle is turned 45 degrees, and the middle and front axles are straight (on a 777). You'd either be scrubbing the hell out of the nosewheel or out of the rear axle. All you have to do is try drawing a turning circle tangent to all the gear with the rear axle at 45 degrees.
The same has to hold for the DC-8. You want all the gear basically tangent to the same turning circle, and given that axles on the main gear are MUCH closer together than the nose gear to main gear, the angle between them is going to be much smaller.
Well, you specifically commented on the 777 and DC-8 steering. And the 777 does not have castoring bogeys - they are steerable axles.
David L
Sun Oct 14, 2012 8:07 am
Quoting vikkyvik (Reply 26):
I left the "45 degrees" as is because I don't know how far they can turn. However, I didn't think 737tdi was saying that they toggle between zero and maximum but that they can be anywhere between zero and maximum as required.
vikkyvik
Sun Oct 14, 2012 8:17 am
Quoting David L (Reply 27):
Fair enough! That's certainly true - they steer proportionally based on nosewheel angle, at least on the 747 and 777.
I did a search, and found one article or something where it said the max deflection was 8 degrees on the rear axle. No idea if that's accurate.
Paging tdscanuck or roseflyer....
vikkyvik
Sun Oct 14, 2012 9:15 am
I just realized that this:
...was a terrible way to state what I was trying to state.
The gear aren't tangent to the SAME circle. But they're all tangent to different circles with the same centerpoint (the center of the turning circle).
tdscanuck
Sun Oct 14, 2012 2:05 pm
Quoting vikkyvik (Reply 28):
For a 777, the aft MLG axle is locked until the captain's steering tiller goes beyond 13 degrees. Then the steering law kicks in and moves the aft axle between 0 and 8 degrees as the NLG goes between 10 and 70 degrees (I'm not sure if it's linear or something more exotic). The aft MLG axle locks again when the captain's steering tiller goes below 9 degrees (i.e. there's a 4 degree hysteresis band for unlock/lock).
For the DC-8, when the NLG goes past 40 +/- 6 degrees, the trailing wheels on the inside of the turn are unlocked and can swivel freely (damped by the trim actuator). They're not powered into a particular position like the 777. When the NLG goes below 18 +/- 8 degrees, the lock arms and the inside trailing wheels will lock the next time they go through center. Since only the wheels on the inside of the turn get unlocked, they only swivel to the outside of the gear centerline. The unlocked trailing wheels can go up to 40 degrees outside of centerline.
Tom.
737tdi
Tue Oct 16, 2012 5:15 am
Wow, what an interesting conversation.
Guys, I am not guessing here on the DC8 gear. Once you do a full turn with a DC8/71 the inside bogie will acutate to 45 degrees and stay there until the extreme turn is completed.
Quoting tdscanuck (Reply 30):
My 45 degrees was a guess, we never had to measure it. As far as being freely, that is completely wrong. It is either full over or straight. It would relieve in the turn but that was a function of the actuator not the steering input. So it is not steerable.
Dang, I worked on these things in heavy checks for years. Drive the tiller left, BAM, left bogie rear set is driven over, Drive the tiller right, BAM, right bogie rear set is driven over. It is driven to full deflection. Dang, I can't believe I am getting crap from guys who have never even seen a DC8. I've rigged the Ailerons, Flaps, Gear and (DOORS), elevators, dump system (for over 20 years) . Ok tell me how it works?????? When was the last time you had to rig the Elevator PCU's on a DC8, dang they are tough?
If you have to ask about rigging? Ask a DC8 guy. Even the Outflow valve was cable operated. If you ask me a DC8 question. Trust me here. You are getting the truth.
I now work 737's and have become a bit soft. If you knew the DC8 you could rig anything.
[Edited 2012-10-15 22:21:48]
[Edited 2012-10-15 22:24:09]
vikkyvik
Tue Oct 16, 2012 6:23 am
Quoting 737tdi (Reply 31):
I've truly found it so.
Relax - no one is out to get you, least of all me.
I gave references for the 777 and 747, and Tom added the info I couldn't. I said I don't know about the DC-8, but I truly doubted it just went straight to 45 degrees. But if I'm wrong, I'm wrong. Wouldn't be the first time, certainly won't be the last.
One more question though; how does this:
Jive with this:
Are you guessing or not?
JETPILOT
Tue Oct 16, 2012 9:18 am
All operators that I know of did away with the castoring bogey mechanism on the DC-8 and just dealt with the tire scrubbing and reduced tire life. I flew for an airline that had DC-8's from many operators and the bogies were all locked to reduce maintenance costs. Boeing Electric Inc. Vs. Douglas Cable & Wire Co. Remember the cash register? LoL!
tdscanuck
Tue Oct 16, 2012 2:32 pm
The steering input unlocks the swivel. It then tracks to wherever the actuator pressure and tire sideforce balance. We agree that it's not steerable. We disagree on whether it immediately goes hardover to full deflection.
If it goes hardover to 40 degrees, then the Douglas DC-8 AMM is wrong in about a dozen places.
Tom.
737tdi
Tue Oct 16, 2012 6:41 pm
Quoting vikkyvik (Reply 32):
There was no requirement for checking the amount of breakover, only that it did breakover so yes, it was a informed guess. The only way to ops check this system is with the airplane on jacks. When we ops checked it, you would turn the tiller and verify that the bogie unlocked and actuated "fully" to the ?40degree? position. It would actually shake the aircraft and was quite loud when the bogie was actuated.
Tom, I lived in that AMM for years and the only thing it said about ops. checking the bogie unlock and actuation was as I have explained. With the aircraft on jacks and the tiller over the bogie actuates to one position, full over. The only time I had the tiller full over and not rolling or on jacks was to change the nose tires and the bogie did not break over, too much weight sitting on it. Now I know I'm gonna get questions on the nose tire change. Trying to get out of a crap hole as quick as possible.......you do what you have too.
tdscanuck
Wed Oct 17, 2012 2:41 am
Quoting 737tdi (Reply 35):
That's kind of a key detail that you didn't bring up until now. On jacks, the tire has no friction. Of course it's going to spring over to the side (the actuator isn't perfectly balanced). On the other hand, when it's actually on the ground, it will not do that.
Straight from the AMM:
"When the nosewheel is turned 40 degrees or more in either direction from the straight forward position, the bogie swivel unlock mechanism is hydraulically actuated to permit the aft wheels on the inside of the turn to swivel and prevent the tires from scrubbing" DC-8 AMM 32-1-8, emphasis added
Tom.
David L
Wed Oct 17, 2012 11:23 am
Quoting tdscanuck (Reply 36):
   I think it was a reasonable assumption that the rest of us were discussing the gear behaviour while taxying/rolling.
