PRFlyer
What's That Streak On The Belly Of This A333
Wed Oct 03, 2012 6:12 am
I was spotting in Manila during my recent trip and happen to take a shot of this Cathay Pacific A333. What is that pinkish streak on the belly of this plane? Is that hydraulic oil? I forgot to follow-up if this bird went tech but it arrived around 4PM Local time.
http://members.dslextreme.com/users/junsan/CP330.jpg
Horstroad
RE: What's That Streak On The Belly Of This A333
Wed Oct 03, 2012 8:37 am
a hydraulic leak looks different. I guess it's coming from the drain mast right infront of the wing to body fairing, so it´s probably some waste from the galley that went through the sink
T prop
Wed Oct 03, 2012 8:39 am
Quoting horstroad (Reply 1):
Coffee....
Tod
Wed Oct 03, 2012 2:53 pm
Quoting T prop (Reply 2):
Coffee....
. . . .and red wine.
CCA
Thu Oct 04, 2012 4:18 am
Yep as T prop and Tod said.
P1 in A330, A340, A346, B742, B744, B748.
Francoflier
Thu Oct 04, 2012 9:03 pm
It's an aircraft skid mark... Happens when an aircraft drinks lots of coffee.
Sat Oct 06, 2012 7:04 pm
Galley drain mast liquid stains.....
Clydenairways
Wed Oct 10, 2012 2:07 pm
Quoting HAWK21M (Reply 7):
Are there any rules on what can be poured down there? It's left them a big job to clean that off now.
strfyr51
Wed Oct 10, 2012 5:09 pm
seeing as to how it starts under the Air Conditioning bay it's eithe roil or hydraulic fluid residue
strfyr51
Wed Oct 10, 2012 5:12 pm
Quoting strfyr51 (Reply 9):
BP 2197 turbine oil is dark Brown
Dalmd88
Wed Oct 10, 2012 8:34 pm
Take a closer look. It's coming from the drain mast just fwd of the body fairings. I doubt the A/c packs use any oil. Most newer packs the acms have air bearings. I bet it's from coffee. It and milk should not be poured down the galley drains, but they do it all the time. Then they wonder why the drain smells and gets clogged.
Tod
Wed Oct 10, 2012 8:53 pm
Quoting clydenairways (Reply 8):
Up to the airline, but its designed only for liquids.
I have had airlines request a placard for the forward galley saying NO COFFEE AFTER MAIN GEAR LOWERED.
747 are really bad for fouling the main gear.
It gets extra yucky when you pour milk and red wine at the same time.
When it passes through the heated drain mast just right, you get sticky pink cottage cheese.
[Edited 2012-10-10 13:53:52]
MSPNWA
Wed Oct 10, 2012 10:29 pm
Quoting tod (Reply 12):
I particularly notice the streaking on the bellies of 747s. I'd say it's the type with the most prominent staining.
I always wondered exactly what it was though. Now I know!
Thu Oct 11, 2012 9:35 am
Maintenance Informed Flt ops to circulate instructions to Cabin crew to refrain from pouring Tea powder/coffee powder/semisolid down the sink, as these used to clog the drains......
MD11Engineer
Thu Oct 11, 2012 12:11 pm
Defintely NOT milk, coffee filter content, tea leaves and orange juice together. The acid of the orange juice will make the milk coagulate and together with the coffee waste and tea leaves, it will clog the drain lines with a stinking mess.
Jan
Tod
Thu Oct 11, 2012 1:52 pm
Quoting HAWK21M (Reply 14):
While I was at Boeing we tested various 747 forward drain mast configurations and even tried one that was three feet long.
The airflow still sucked the liquids right up against the flat belly no matter what we tried.
AA737-823
Mon Oct 15, 2012 5:43 am
Quoting Dalmd88 (Reply 11):
Don't tell Boeing that; the most popular jet airliner in history is still rolling down the assembly line with oil in the ACM's...
yeelep
Mon Oct 15, 2012 5:52 am
If you are referring to the 737, it has ACM's with air bearings since the first NG.
DarkSnowyNight
Mon Oct 15, 2012 10:20 am
Yup. Also, it's way forward of the PACK bays. On 330s, those start right about three feet aft of the inlets, which here can be seen straddling the beacon. Looking close we see that this streak starts even forward of that point.
If it's galley juice, on the plus side it should wipe right off with a very mild solvent. At least it's not hyd residue from the overspill containers; that you need a for-real cleaning crew to get off once it dries (it gets wicked crusty and displaces a much wider patch than this streak).
Much like a GE90, I'm a huge fan of Big Twins...
Wed Oct 17, 2012 7:23 am
Quoting MD11Engineer (Reply 14):
It sure is a stinking mess,when it has to be reverse blown by nitrogen from the drain mast outlet
Tod
Wed Oct 17, 2012 5:35 pm
Quoting HAWK21M (Reply 19):
Why nitrogen and not just compressed air?
flyingturtle
Wed Oct 17, 2012 5:49 pm
Quoting Tod (Reply 20):
It is inert, i.e. it does not (easily) take part in chemical reactions.
http://en.wikipedia.org/wiki/Inert_gas
Apart from that... I don't know...
David
Fri Oct 19, 2012 7:44 am
Since We have bottles of N2 freely available at the Mx department, as most places for servicing use N2...hence....
True.............. Compressed Air can be used for blockage cleaning.
Users browsing this forum: TailDragging, Woodreau and 19 guests
