Bird Hit Chances At SOF/LBSF
Mon Oct 08, 2012 11:29 am
Considering the number of birds and the location,Shouldn't ops be restricted in such times,Is this common out at this airfield.....
jumbojim747
RE: Bird Hit Chances At SOF/LBSF
Fri Oct 12, 2012 5:56 pm
Wow that's a lot of birds MEL.
One thing that's always plays on my mind is why cant engine manufacturers come up with a design to the front intake that would keep birds out.
Now i know the airflow would be restricted.
But can it be done.
On a wing and a prayer
Fri Oct 12, 2012 9:19 pm
Quoting JumboJim747 (Reply 1):
But can it be done.
Interesting as a thought experiment. You'd need some way to "filter out" the bird before it reaches the blades.
However in the case of props you don't want them to hit the prop anyway so while a bird filter would help the turbine or reciprocating engine it wouldn't help the prop blades.
fr8mech
Sat Oct 13, 2012 1:02 am
I don't think airflow is a big a problem as yuou may think....until the ice starts to form on whatever media you use to filter the birds. You can anti-ice, but you are starting to add complexity, weight and cost.
dandaire
Sun Oct 14, 2012 9:44 am
Some turboprop aircraft already do have such a design. The Saab 340 intake does have a "bird-catcher" design. Any birds or other debris is routed away from the engine into the bird catcher and down into the bottom of the nacelle away from the engine inlet.
Old age and treachery will triumph over youth and skill.
AF1624
Mon Oct 15, 2012 1:09 pm
Didn't old(er) 707 and 727 engines have some kind of fairing in front of the main fan?
It looked like a fan itself but was fixed.
flyingturtle
Mon Oct 15, 2012 3:42 pm
Quoting AF1624 (Reply 5):
These might be stator vanes - they stabilize the airstream before it hits the fan. Normaly, stator vanes are behind the fan.
See here:
Photo © Marc Riedel
David
AF1624
Tue Oct 16, 2012 8:44 am
Quoting flyingturtle (Reply 6):
Thanks David.
These being in the front, would that be strong enough to prevent a bird ingestion? Or at least to slow the bird down enough so that the blades don't get damaged?
Unless the bird actually gets stuck there. Hum.
flyingturtle
Tue Oct 16, 2012 10:29 am
Quoting AF1624 (Reply 7):
No, at takeoff speed these stator blades will slice through the bird like a knife through hot butter.
Add to that the suction of the fan behind.
However, your idea (or sort of) was accidentally tested in the real world... http://www.youtube.com/watch?v=5jxcSY1AwrM , and the guy has survived to tell his tale:
Sailor Sucked Into An A6 Engine (by A5XX May 4 2005 in Military Aviation & Space Flight)
David
Wed Oct 17, 2012 7:29 am
as long as its not at a compromise to performance , finally its about $$$.
the Bird strike to a low bypass turbofan can be more expensive as the bird can damage multiple layers beyond....On a High bypass Turbofan the chances are less & 1st stage fan blades can be replaced on line.
PHX787
Thu Oct 18, 2012 8:54 pm
Quoting HAWK21M (Reply 9):
I've heard of some people designing some type of cover that keeps debris from entering the intake of the fan....but wouldn't that just restrict airflow too? I recall an older model of the Learjet or Cessna Citation that had something similar to that but I'm not 100%.
Also: don't airports use noises that only birds can hear to keep them away?
larshjort
Thu Oct 18, 2012 10:17 pm
Quoting PHX787 (Reply 10):
Some probably do. in SGD and ODE they use shoot with blanks from a shotgun before aircrafts arrives and departs.
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
Fri Oct 19, 2012 7:46 am
The Fireworks guy lighting fire crackers at fixed intervals are common at most places....The better Airports use Noise generating Vehicles that roam the runways producing sound waves that affect birds.....
Dufo
Sun Oct 21, 2012 8:23 pm
I was based in Sofia for a few months in 2010 and don't remember any special problems with birds.
Ducks in Marseille were much more problematic and unpredictable
I seriously think I just creamed my pants without any influence from any outside variables.
pilotpip
Mon Oct 22, 2012 5:03 am
Why not make a puncture-proof tire? Tires fail. Planes hit birds. The results are seldom any worse than mx cleaning guts off the airframe.
Bird strikes happen quite often. Looking back through my logbook I average 2 per year over 12 years. My personal high was 7 when I was instructing in 2007. Biggest was a red-tailed hawk. That left a mark.
DMI
Mon Oct 22, 2012 7:24 am
Quoting pilotpip (Reply 14):
Weight penalty.......& the concern of bird hits is not tire damage but rather bird strike or worse bird ingestion.
Airports should have a residential cleared area of 1-2 km ideal to curb birds.
pilotpip
Sat Oct 27, 2012 5:24 am
I think you missed my point, Mel. It's not a new problem. Bird strikes happen. They happen all the time as I'm sure you know. There have been only maybe a handfull of flights in 100 years of aviation where bird strikes caused a threat to the safety of passengers. If it were a greater issue it would have been addressed decades ago but it hasn't because it's cost prohibitive and quite honestly, one of the smaller risks to the safety of flight.
DMI
Sat Oct 27, 2012 10:19 am
Quoting pilotpip (Reply 16):
Agreed bird strike leading to a disaster is rare,but in todays times the impact on the financial strength of the airline is a concern too.
flanker
Thu Nov 08, 2012 10:30 pm
Seems like a bunch of Swallows... I don't ever recall there being problems with birds at SOF.
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an unlicensed pharmacist
