JaggySnake
767-300ER Handling Implications Of Blended Winglet
Tue Oct 09, 2012 3:04 am
Hi guys,
I've only just bought a membership to this place, yet like many of my classmates, I could probably credit my degree to the help of these forums!!
Anyway I'm on an internship (for my final year thesis) at an MRO doing a study of blended winglets, in particular, the installation of the Aviation Partners' product onto the 767-300ER.
I am interested to hear some views from current Flight Crew on any effects the installation of winglets has on the handling characteristics of the plane.
I have already spoken to a UA test pilot who was recently performing the post-mod test flight on one of their a/c and he suggested that there is little noticeable difference to the way the a/c handles following winglet installation. He did however admit that he wasn't the best person for me to ask as he does not exclusively fly the 767s.
I'm thinking that by adding these devices - they're really quite substantial on the 767-300 - there could be an increase to the dihedral effect of the wing adding some extra roll damping. As the effective aspect ratio is increased, the Mean Aerodynamic Chord is perhaps shifted towards the tips slightly? Combining that with the presumed aftwards shift of the longitudinal centre of gravity due to the winglet's weight, are there any performance implications upon take-off/landing which are at all noticeable?
I ask here as I have so far been unable to find any evidence to back-up these ideas.
I'm expecting you guys to come back and say that any differences are negligible, and I'm perhaps being optimistic in that I'm looking for anything that will add depth to my report, but any help on this issue would be greatly appreciated.
Cheers, Fergus
tdscanuck
RE: 767-300ER Handling Implications Of Blended Winglet
Tue Oct 09, 2012 6:56 pm
Quoting JaggySnake (Thread starter):
One way to look at it is that, if the difference *weren't* negligable, the FAA et. al. would require either additional training or a new type rating. So far as I know, that hasn't happened.
Tom.
DocLightning
Tue Oct 09, 2012 7:39 pm
Quoting tdscanuck (Reply 1):
I thought that the winglets knocked a few Kt off the maximum allowable crosswind in a landing/takeoff.
-Doc Lightning-
-Carl Sagan
tdscanuck
Wed Oct 10, 2012 1:00 am
Quoting DocLightning (Reply 2):
If so, that's almost guaranteed to be due to available test data rather than an actual aerodynamic limitation...maximum allowable crosswind is just maximum demonstrated...the OEM's knock themselves out trying to find this highest crosswind you can while you've got an FAA-authorized test pilot onboard but you don't always get what you want. At some point, you give up being on wind watch because you've got a number that's good enough.
Tom.
Max Q
Wed Oct 10, 2012 7:41 am
Never noticed any difference on the 757 or 767.
Except a little more tendency to float on landing if you are fast.
N243NW
Thu Oct 11, 2012 1:27 am
My airline actually queried Aviation Partners Boeing about this (why the 30kt value for the 757 and 29kt value for the 767 remain unchanged), and the response was that APB was able to better the non-winglet Boeing figures with the wingleted aircraft during flight test (remember, they're demonstrated values, not limits!). For this reason, APB considered the effects of winglets negligible on crosswind behavior.
JaggySnake
Thu Oct 11, 2012 3:10 am
OK, thanks for the replies.
Quoting Max Q (Reply 4):
I would have thought, if anything, the ground effect would be reduced due to a lesser amount of induced velocity from reduced trailing vortices?
Max Q
Thu Oct 11, 2012 5:34 am
Quoting JaggySnake (Reply 6):
It's the overall drag being lower that makes the difference, you raise an interesting point though.
TWA772LR
Mon Oct 15, 2012 6:42 pm
What effect would winglets have on a crosswind landing/takeoff? Would they disrupt the aircraft in anyway? Didn't that used to be one of the theories of the CO DEN crash?
And for my next miracle, I'm gonna turn water into funk!
DocLightning
Wed Oct 17, 2012 12:27 am
Quoting N243NW (Reply 5):
Couldn't Boeing use these results to alter the maximum allowable crosswind for the 767 type?
-Doc Lightning-
-Carl Sagan
N243NW
Wed Oct 17, 2012 4:40 am
Quoting DocLightning (Reply 9):
There would likely be no real benefit, considering that these conditions are so rarely encountered. Also, Boeing probably wouldn't increase the aircraft's book values without doing the necessary testing themselves, for liability reasons.
tdscanuck
Wed Oct 17, 2012 1:42 pm
There is no maximum allowable crosswind, only max demonstrated. To count as "demonstrated" the OEM has to have done it with an FAA or AR pilot onboard and instrumentation to provide the data backup, and analysis to show that the with-winglet value is applicable to the without-winglet airplane. It's entirely possible that whatever APB did did not meet that threshold.
Tom.
Users browsing this forum: No registered users and 9 guests
GZIP: Off
