smartt1982
Landing Gear Placard Limit
Tue Oct 09, 2012 8:22 pm
On the landing Gear limit speed placard on our aircraft it says 270 -.82M. Would I need to be at a speed below both of these or just one. Thinking of a case if I was 285 knots indicated but only .69M etc.
Would I just whatever one I was using as a reference at that time?
Fabo
RE: Landing Gear Placard Limit
Tue Oct 09, 2012 8:53 pm
under both.
filler filler
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Wed Oct 17, 2012 7:32 am
That is the range.........Not to exceed BOTH.
bueb0g
Wed Oct 17, 2012 8:43 am
Quoting HAWK21M (Reply 2):
You mean not to exceed either?
Roger roger, what's our vector, victor?
barney captain
Wed Oct 17, 2012 9:16 am
So - you FLY the aircraft, yet don't understand the placard speed - is that correct?
Southeast Of Disorder
tb727
Wed Oct 17, 2012 4:10 pm
Well there is one thing you can count on, it's gonna be loud at high speed.
roseflyer
Wed Oct 17, 2012 4:23 pm
Usually you have 4 speeds for landing gear. A maximum speed for extension in Mach. A maximum speed for extension in Knots. A maximum gear extended speed in Mach. A maximum gear extended speed in Knots. Exceeding any limit requires a landing gear inspection.
I have been on an airplane exceeding the gear extended speed and the buffet is extreme. It is loud and the airplane is shaking violently (in buffet rather than turbulence).
PGNCS
Wed Oct 17, 2012 5:00 pm
Quoting barney captain (Reply 4):
I frankly find this beyond belief too.
Horstroad
did he say that? maybe he is a mechanic, FA, ramp agent or whatever
PGNCS
Wed Oct 17, 2012 5:05 pm
Quoting horstroad (Reply 8):
Not here but elsewhere, plus it's in his profile.
Barney captain has good reason to ask this question as this is an EXTREMELY basic piece of information for a pilot of any sort to know.
CosmicCruiser
Wed Oct 17, 2012 11:00 pm
Quoting Roseflyer (Reply 6):
And a max retraction speed.
tb727
Thu Oct 18, 2012 1:14 am
Quoting CosmicCruiser (Reply 10):
Which is the tricky one. It's significantly lower in the plane I fly, if you throw the gear for an emergency descent, you have to remember you are gonna have to slow it back up to put it up again if you so choose. Not a big deal really, just another step.
9VSIO
Thu Oct 18, 2012 2:06 am
Well, he's been asking quite a lot of pilot related questions, and said in one of the other threads that he also instructs in the 737 sim for the type rating. His profile has already been mentioned on here. His questions are normally interesting though
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
Max Q
Thu Oct 18, 2012 4:37 am
It's not really an issue, at low altitude, below say 27000 feet your Mach No is going to be so much lower than the KIAS limit for gear extension it's not a factor, and at high altitude your KIAS will be so much lower than the mach limit it's not a factor.
Most, if not all modern Boeings use just one Mach / Speed limit for extension/ extended these days keeping it simple.
270 / .82 Is the limit on the 757 / 767 and I suspect it's pretty close to that on all subsequent Boeing models.
tb727
Thu Oct 18, 2012 5:07 pm
Quoting Max Q (Reply 13):
Seems to be!
727 is 270/.83 to extend
200 to retract
VLE/MLE is 320/.83 and I am pretty sure you are gonna go deaf and/or chug through some fuel if you do that.
747 Classic
VLE/MLE 320/.82
VLO 270/.82
Gear retract can be 270/.82 or 250/.82 depending on plane.
citationjet
Thu Oct 18, 2012 9:04 pm
Cessna actually specifies six landing gear design speeds for some Citations. However many of the speeds are the same for a given aircraft.
Vlo (extending) - Mach
Vlo (extending) - knots
Vlo (retracting) - Mach
Vlo (retracting) - knots
Vle (extended) - Mach
Vle (extended) - knots
Ref: FAA TCDS A1WI, for model Citation 525B, page 15.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
Max Q
Fri Oct 19, 2012 4:16 am
Quoting tb727 (Reply 14):
Boy you have that right..
Fri Oct 19, 2012 7:42 am
Quoting bueb0g (Reply 3):
Thats correct.
ZBBYLW
Wed Oct 24, 2012 2:39 pm
Remember that during your ground school, the instructor is there for you. The airline or in the case of the UK sometimes, you are paying for that guy to teach you. I don't know what airplane you're on but it may be your first jet and some of the high speed/high altitude aerodynamics may be new. Make sure you get the airlines money out of your instructor!
Keep the shinny side up!
smartt1982
Sun Nov 04, 2012 10:18 am
Quoting zbbylw (Reply 18):
Quoting PGNCS (Reply 9):
I would just like to clarify something here if I could, this is a forum for finding out technical issues. As has been pointed earlier in this forum thread, yes I am a current 737 line pilot and a sim instructor. I have had very good experiences with the airliners forum in the past with clarifying issues in the past, up until this point!
I would like to add that I did expect that you have to obey both speed limit placards but I had heard from some students that they only had to obey one by another instructor. This puzzled me but I could not actually find in the Boeing manuals a definite AND clear answer. Too often in aviation you are told things both technical and operational and the person cannot point or refer to where this info has come from, hence the resson why I took the time to ASK the question on this forum.
Some of the replies posted here appear to be very negative and more casting an opinion on the person posng the question.
Think of me however you wish but I thought this forum was for finding out tech questions that could not be clearly answered else were
Thank you
Fabo
Sun Nov 04, 2012 5:08 pm
I suspect there is a "whichever is lower" or similar in the AFM, but cannot confirm right now.
tdscanuck
Sun Nov 04, 2012 5:28 pm
Quoting Fabo (Reply 20):
Nope. The words out of the 737-800 AFM are:
"LANDING GEAR PLACARD SPEEDS - KNOTS IAS, INDICATED MACH
RETRACT V_LO(RET) = 235
EXTEND V_LO(EXT) = 270, M_LO(EXT) = 0.82
EXTENDED V_LE = 320, M_LE = 0.82"
There is no need for a "whichever is lower" because they're independent, not coupled, limits. If you're over M0.82 it doesn't matter what your IAS is, you can't extend the gear. If you're over 235 knots it doesn't matter what your Mach is, you can't extend the gear.
Because of the way the Mach and IAS lines work out, IAS is more limiting at low altitude and Mach is more limiting at high altitude but both limits are in force all the time.
Tom.
Fabo
Sun Nov 04, 2012 5:36 pm
Quoting tdscanuck (Reply 21):
Which is in effect the same thing. But you are the one with the AFM, not me, so there is that.
SKC
Sun Nov 04, 2012 6:35 pm
Quoting smartt1982 (Reply 19):
So, what did the other sim instructors or your chief pilot(s) say when you asked them this question? Did they all have different answers? Has to be listed in a company manual somewhere.
While this may be a technical forum, and the given info may be correct, I'd be careful about taking perfomance data from a group of anonymous internet people. There's no background check to register here.
CosmicCruiser
Sun Nov 04, 2012 7:31 pm
You beat me to it but yeah. just think though at high alt. mach is the only concern, you may not even be able to slow to the IAS speed.
smartt1982
Sun Nov 04, 2012 11:32 pm
Quoting SKC (Reply 23):
A very valid point indeed. Your very true in what you say and I do whenever I can speak to as many different people as possible but the great thing about the airliners forum is that there is a lot of very experienced people from all different aspects of aviation. So even though it may not be 100% official their info can help explain the reasons why something operates or works the way it does or point you in the right direction
Jetlagged
Mon Nov 05, 2012 1:02 am
I think it's more likely a case of the students not understanding what the other instructor has said correctly. You will either reach the 270 knot limit or the 0.82 Mach limit first. So in a sense only one limit applies, but in fact you must observe both.
If you think about it, the placard limit could only mean either
270 knots or Mach 0.82
or
270 knots and Mach 0.82
The "and" interpretation makes no sense at all in aviation terms, so "or" is the only logical interpretation.
That's because there's a history of people on this forum claiming to be what they aren't. The answer to this question seems so obvious that people are bound to wonder why you asked it. You already knew the answer, but couldn't find anything to prove it in the manuals. If you'd asked that question in the first place no one would have doubted you.
Mir
Mon Nov 05, 2012 5:54 pm
Quoting Jetlagged (Reply 26):
or
Actually, it's the other way around. You've got a VLO (in knots) and an MLO (in Mach). Both limits apply at all times. It's not one or the other.
And, to be perfectly honest, certain other questions that have been asked as well.
-Mir
smartt1982
Mon Nov 05, 2012 7:50 pm
Quoting Mir (Reply 27):
Mir, are you referring to my previous questions?
[Edited 2012-11-05 12:30:08]
Jetlagged
Tue Nov 06, 2012 12:05 pm
Logically it's still an OR (which means both limits apply, lowest one first). If it was 270 and 0.82 then you wouldn't reach the limit until both conditions were satisfied.
Users browsing this forum: GoSharks and 1 guest
