Poadrim
Flight Balance With One Wing Lost.
Thu Oct 25, 2012 6:57 pm
Hi guys and gals,
Did a search and found nada so there for this thread.
I watching NGC's Air Crash Investigation about Chalk's Ocean Airways Flight 101, and yeah, I know, you need both wings to fly (except the Israeli F-15 in '94?). But what happens when a wing breaks off? Does the wing, that is still attached, flip upward due to the increased lift on the side with the wing or down due to the increase weight?
//Poadrim
Good judgment comes from experience.
Good experience comes from someone else's bad judgment.
Ramp rat @ OSL
wingscrubber
RE: Flight Balance With One Wing Lost.
Thu Oct 25, 2012 8:18 pm
If a wing seperates, the remaining wing will have no opposing moment on the opposite side of the airplane, so it will roll up and over the top...
Resident TechOps Troll
roseflyer
Thu Oct 25, 2012 8:40 pm
Quoting Poadrim (Thread starter):
If you'd like to see a visual of this happening, take a look at the crash videos of the FedEx MD-11 in NRT or the United DC-10 in Sioux City. In both crashes, the landing gear failed, which caused the spar to break. This separated one wing from the airplane, which caused the rest of the airplane to roll over until the other wing contacted the ground and was upside down.
In this video you can clearly see what happens when the left main landing gear fails and the wing spar breaks. The other wing which is still achieving lifts causes the airplane to roll until it is upside down.
http://www.youtube.com/watch?v=V6cMK9LUnzI
Poadrim
Thu Oct 25, 2012 8:55 pm
Aight, thank you. But some how it's seams more logic that the weight of the remaining wing vs. the life momentum should in best case stay level(I know it don't, but still)
//Poadrim
Ramp rat @ OSL
mrocktor
Thu Oct 25, 2012 9:47 pm
Quoting Poadrim (Reply 3):
Maybe this will help you visualize it:
At the moment immediately prior to your wing separation, each wing is lifting its own weight, plus half the weight of the rest of the airplane (opposite wing excluded). When the wing separates, the opposite wing is now lifting its own weight, plus trying to lift the full weight of the rest of the airplane (minus the separated wing). Since the lift is horribly off center, the plane flips over.
roseflyer
Thu Oct 25, 2012 9:54 pm
If you remember free body diagrams from physics class, the wing is creating a net force up, while the fuselage is a net force down. So while the airplane as a whole would fall out of the sky and go down, relative to the fuselage, the intact wing is going to go up and roll the airplane over.
Poadrim
Thu Oct 25, 2012 10:42 pm
Well then, thank you guys! Much appreciated help
Ramp rat @ OSL
roseflyer
Thu Oct 25, 2012 11:02 pm
Quoting Poadrim (Reply 6):
No problem. Just think of the wing as a helium balloon.
Moose135
Fri Oct 26, 2012 1:08 am
Quoting Roseflyer (Reply 7):
On a conveyor belt...
 Big grin
[Edited 2012-10-25 18:08:35]
SAAFNAV
Fri Oct 26, 2012 3:30 am
If the weight of the wing would outweigh the lift, then there is really no point in having a wing?
larshjort
Fri Oct 26, 2012 6:22 am
Quoting moose135 (Reply 8):
Quoting Roseflyer (Reply 7):Just think of the wing as a helium balloon.
Quoting saafnav (Reply 9):
How fast would a helium balloon without wings have to move on a conveyor in order to takeoff
And what if it has one wing on the RH side
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
Poadrim
Fri Oct 26, 2012 12:07 pm
Point taken, I should have known that.
Big grin
Quoting Larshjort (Reply 10):
/Lars
I LOL'd, really. Thanks!
Ramp rat @ OSL
DocLightning
Sat Oct 27, 2012 7:10 am
http://www.youtube.com/watch?v=hedLTEbhjJ0
Evidently, it will flip up and then rapidly assume a negative AOA and then stall.
-Doc Lightning-
-Carl Sagan
Sat Oct 27, 2012 10:15 am
Flip up and over before gravity takes over.
On the IAF F15 story.....was the loss of wing imbalance countered by the skill of the pilot using thrust as a compensation....amazing feat.....
DocLightning
Sat Oct 27, 2012 4:06 pm
Quoting HAWK21M (Reply 13):
That and the fact that most of the aircraft was actually part of the lifting surface.
-Doc Lightning-
-Carl Sagan
tdscanuck
Sat Oct 27, 2012 5:35 pm
In addition to what DocLightning said (the aircraft was nowhere close to losing 50% of its lifting surfaces), the F-15 also has augmented stability in the flight controls. This helps to reject even very large disturbances, like significant asymmetric lift. At least annecdotally, the pilot in that case had no idea that the damage was as bad as it was until after he landed.
Tom.
DocLightning
Sat Oct 27, 2012 7:20 pm
Quoting tdscanuck (Reply 15):
That's what I heard. It wasn't until he got out of the cockpit that he saw what had happened.
-Doc Lightning-
-Carl Sagan
Sun Oct 28, 2012 9:41 am
Usully the case.....reminds me of a B732 lading back after a hydraulic failure only to realise on ground that the caue was a loss of a MW along with the brake, broken at the axle
HaveBlue
Sun Oct 28, 2012 10:48 am
And he wasn't able to counter the loss of a wing until he used afterburner.. an option no airliner (anymore) has. So it was partly the fact that the F-15's flat underbelly contributes a good amount of lift, partly that he used afterburner to power thru it, and partly that he wasn't aware the wing was gone. He has said that had he knew the extent of the damage, he would've bailed.
Here Here for Severe Clear!
Mon Oct 29, 2012 7:54 am
Quoting HaveBlue (Reply 18):
I'm sure such a situation would never have been simulated before too on the type ever.....
DocLightning
Tue Oct 30, 2012 12:14 am
Also an option that no airliner has...
Quoting HAWK21M (Reply 19):
I'm wondering how one would go about rendering such a simulation accurately.
-Doc Lightning-
-Carl Sagan
flyingturtle
Tue Oct 30, 2012 9:58 am
Quoting DocLightning (Reply 20):
Wind tunnel?
Perhaps it could work with a really slow aircraft (a glider?) and a ludicrous amount of sideslip...
Never mind maneuverability.
David
Fabo
Tue Oct 30, 2012 2:37 pm
Quoting flyingturtle (Reply 21):
I would not think so. You still have all weight on one side and all lift on the other. Sideslip wont help you with that.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
flyingturtle
Tue Oct 30, 2012 6:02 pm
Quoting Fabo (Reply 22):
Hm, and how about using full *upward* flaps deflection on the first few feet of the wing (measured from the glider's body), and normal downward deflection of the flaps on the rest of the wing? Though, you need to shift the pivot point into the wing, away from the fuselage...
...well, there has already been the Blohm & Voss 141...
David
mrocktor
Tue Oct 30, 2012 10:43 pm
Quoting DocLightning (Reply 14):
That and the fact that the missing wing exposed the ungodly huge elevator behind it to free airflow. Those things respond differentially to roll command (which would be at or near the stop...) - I'm sure he was getting a good bit of lift out of the elevator on the wingless side.
larshjort
Tue Oct 30, 2012 10:59 pm
Quoting flyingturtle (Reply 23):
If your ailerons were big enough it could probably work. But they would need to be big. The outboard wing would have to creat the same negative lift as the fuselage provides with the inboard wing section having to create twice the amount of lift normally produced by two whole wings.
And the Bv 141 still had a wing on each side of the fuselages.
/Lars
MD-90
Sun Nov 04, 2012 6:43 am
Well there were a few SSTs back in the day...
sprout5199
Mon Nov 05, 2012 9:43 pm
http://www.youtube.com/watch?v=dsQcdTBwgKU
Watch what happens to the Skyhawk. This shows what happens when you lose a wing.
Dan in Jupiter
Users browsing this forum: Apprentice and 2 guests
