mhsieh
Wifi Antenna
Sat Oct 27, 2012 5:04 pm
Are there different types of Wifi Antennas for 737s?
On Southwest 737s, there are big dome structures while on Alaska 737s there are nothing visible.
Different types? Different capabilities?
Thanks.
tdscanuck
RE: Wifi Antenna
Sat Oct 27, 2012 5:32 pm
Quoting mhsieh (Thread starter):
Yes, assuming that you mean the offboard datalink and not the on-airplane WiFi antenna.
The Alaska 737's, I think, are using a blade antenna (looks like a VHF).
Tom.
DL_Mech
RE: Wifi Antenna
Sat Oct 27, 2012 7:55 pm
Here is a pic of one of the three WiFi antennas on a DL plane:
(Forward-most antenna shown inside the engine inlet )
Photo © Tong Xian
This plane is built to withstand anything... except a bad pilot.
Dalmd88
RE: Wifi Antenna
Sat Oct 27, 2012 8:37 pm
It depends on the type of system used. The GoGo system is currently all land based. They use a land phone system that connects up to the plane. While the system WN uses is sat based so they connect down to the plane. The sat based systems are the way forward. I think GoGo is moving to this system so international aircraft can have WiFi capabilities.
SKC
RE: Wifi Antenna
Sun Oct 28, 2012 1:36 am
Quoting Dalmd88 (Reply 3):
SWA uses Row 44 for their sat-based WiFi.
dlednicer
Crew
RE: Wifi Antenna
Sun Oct 28, 2012 4:48 am
Alaska Airlines originally was going to go with the Row44 satellite-based system:
Photo © Royal S King
They ended up switching to the GoGo ground-based system.
Southwest and Norwegian Air Shuttle use the Row44 system:
Photo © Mehmet Mustafa Celik
