LU9092
Headwinds On Approach And Landing
Sun Oct 28, 2012 7:59 pm
I know aircraft have a certified max crosswind component for landings and takeoff, but what about headwinds? My girlfriend should be departing RDU for JFK in a half hour or so, and another friend is enroute to LGA from DEN, and I'd been keeping an eye on whether winds had gotten strong enough to constrain LGA and JFK to using their 4's. Winds are forecast to be right down the centerlines the rest of the afternoon into this evening, which made me wonder how much headwind is too much? Are aircraft certified for a certain max, or is it something an airline would define in their SOP? I then wondered if the is a max certified crosswind for taxiing. I imagine a 70 Kt gust could swing the tail of a taxiing airliner.
tdscanuck
RE: Headwinds On Approach And Landing
Sun Oct 28, 2012 8:22 pm
Quoting LU9092 (Thread starter):
No, they don't. They usually have a maximum *demonstrated*, which the airlines then use as the basis for their SOP's (usually with some reduction), but they don't have a maximum certified.
Unless they're so high that flight operations are suspended, they're not really a problem.
Well, if the wind was above Vmcg then you couldn't takeoff but Vmcg is usually 100+ knots and that's well into hurricane territory, by which time flight operations would have long since ceased.
The latter.
Not explicitly. Above Vmcg you can't guarantee that the rudder will provide enough sideforce to keep you straight but that assumes that you don't have any nosewheel steering. The practical limit is somewhat above Vmcg but, as noted earlier, you'd have suspended flight operations long before then.
If the surface was slick, that is a possibility. The weathervane tendency would certainly be strong. You could battle it with differential thrust but, under those conditions, I'd call of the flight if I were PIC.
Tom.
Pihero
Sun Oct 28, 2012 8:58 pm
Quoting tdscanuck (Reply 1):
As a matter of fact, there are some limitations one could very well keep in mind : Wind limit for door operations and slide deployment limit . They vary from a model to another but ballpark figures would be 65 and 30 kt .
On the other hand, there are headwind component limits for autopilot Cat II and III approach, land and rollout : around 30 kt.
Contrail designer
tdscanuck
Sun Oct 28, 2012 11:22 pm
Quoting Pihero (Reply 2):
Absolutely true. As the headwind increases the flight path in the air has to change to keep the inertial flight path on the approach, which plays directly into how a bunch of the control laws inside the autopilot work. They don't have infinite envelopes so you have to go over to hand-flying at some point. In all likelyhood, the autopilot may be capable of more but it was just never demonstrated for more. When chasing winds for certification, you have to take what you can get.
Tom.
LU9092
Mon Oct 29, 2012 3:18 pm
I appreciate the info!
musang
Mon Oct 29, 2012 4:06 pm
And the 737 classic has a limitation of 65 knots wind for ground operations which, due to the need to taxi to the runway, would effectively become a take-off headwind limit.
Regards - musang
OldAeroGuy
Tue Oct 30, 2012 3:38 pm
You mean below Vmcg. if the airplane is above Vmcg, the rudder can be used to maintain directional control if an engine fails and is able to continue the takeoff.
Below Vmcg, an engine failure means the good engine must be cut and the takeoff must be be aborted.
tdscanuck
Wed Oct 31, 2012 1:28 am
Quoting OldAeroGuy (Reply 6):
Yes. Yes I do.
Tom.
Users browsing this forum: No registered users and 4 guests
