seven3seven
European Airlines And Full IRS Alignment
Wed Oct 31, 2012 6:02 pm
In all the pics of European airliner Boeings at the gate I notice what looks like a full inertial navigation system alignment everytime. At my airline we just do a quick align of the system between flights during the day. It takes just a few seconds as compared to up to 7 minutes with a full alignment, and we have GPS anyway.
Can anyone provide a justification for a full IRS alignment after every flight?
My views are mine alone and are not that of any of my fellow employees, officers, or directors at my company
airbuster
RE: European Airlines And Full IRS Alignment
Wed Oct 31, 2012 9:06 pm
Hey,
We do exactly the same as you. Full alignment from cold and dark and on e.g. a turnaround just a quick align. This is on a F70/100.
FLY FOKKER JET LINE!
Fabo
Wed Oct 31, 2012 10:45 pm
About all pilots I talked to did full alignment, on the 737 at least. It really makes little difference, it is not like other things are finished before 10 minutes after shutdown pass.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
CosmicCruiser
Thu Nov 01, 2012 12:14 am
We do a full alignment on every thru stop.
seven3seven
Thu Nov 01, 2012 5:42 am
Quoting Fabo (Reply 2):
We are famous for 20 minute turns and often have everything done and ready to go in the cockpit in 5 minutes. Again, can anyone provide justification for a full alignment over a quick align?
[Edited 2012-10-31 22:42:55]
strfyr51
Thu Nov 01, 2012 9:26 am
a full alignment clears any errors that might have built up over time. Since Drift and radial position error are all monitored in the Maintenance manual with limits it just makes good sense to do a full alignment if that's what you need. . Since 2 alignments reported bad might cause the replacement of a $300,000 part needlessly? It makes darn good sense financially to take the extra 3-5 minutes. .
KAUSpilot
Thu Nov 01, 2012 9:54 am
Obviously I'm not European but: We do a full alignment every time; granted our average leg length is about 8 hours and the fastest turn I've ever done is 45 minutes. Going from memory, the 744 can go no longer than 18 hours of flying time between full alignments.
Reasons we turn them off after the flight and usually do a full alignment prior to the next flight:
1. After a flight, we don't know how long the airplane will sit there between the time we leave and the time the next crew shows up (and the plane almost always stays powered up with APU or external). If there was a power interruption and the plane went into standby power while it was sitting there, the IRU's could overheat if there wasn't a mechanic or someone else around to notice (normally someone should be monitoring the aircraft all the time while the APU is on, of course). The airplane is rarely powered completely down between flights.
2. We have no real way of knowing how long the previous crew went before a full alignment. Fast alignment is still an option that can be used at the crew's discretion, but SOP is a full alignment before every flight. So it's possible that the aircraft might be close to it's 18 hour limit.....there's no way to know for sure without asking the previous crew, who we usually don't see.
3. True it doesn't matter very much given GPS, but IRU accuracy is tracked by the company at the end of each flight....we have to send IRU error out as part of the ACARS post flight report. Also much of Europen airspace is RNP 5 which is easy enough to maintain on IRU's alone, so it's nice to know you can maintain RNP even if GPS is lost for some strange reason. There is no such RNP requirement in the USA's domestic enroute airspace structure, to my knowledge, so it would make sense not to worry about it as much there.
AA737-823
Thu Nov 01, 2012 10:24 am
The catch is, if you're in WINDY conditions, the 737NG is notorious for refusing to align. For this reason, a lot of carriers won't do a full align if there's much wind at all. If you can feel the tail shaking, it's usually a bad idea, in my experience, to realign.
CosmicCruiser
Thu Nov 01, 2012 12:32 pm
Quoting AA737-823 (Reply 7):
I thought that was a trait of older IRSs. Wind shake doesn't seem to be an issue at least in the -11 and we see wind as well as the airplane moving when loading the freight. never had a problem.
DashTrash
Thu Nov 01, 2012 2:30 pm
Good Lord. We would fly multiple legs in a 10 or so hour day with the Citation X and never do a quick or full align other than when powering up.
Most days it would take care of itself as we shut the aircraft down during longer turns, but not always.
seven3seven
Thu Nov 01, 2012 4:41 pm
Thank you KAUSpilot (Eric) for a very nice response. An aircraft sitting unattended for long periods of time is certainly a good reason. As well as the long flight times on your aircraft.
And the RNP 5 requirement in Europe might be the simplest explanation.
BA777
Thu Nov 01, 2012 5:48 pm
One full alignment at the start of duty (737NG) and only do a realign if we get the message on the CDU to do so.
sandrozrh
Wed Nov 14, 2012 12:01 am
We do quick alignments during turnarounds if the residual groundspeed is less than five knots and if we're staying on the same aircraft for the next sector. In all other cases we will do full alignments. Also, the IRS positions need to be within 5NM from the airports reference position after realignment, or a new, and in this case full, alignment is necessary. This is our procedure on the A32S, A330 and A340 and is Airbus procedure, so im not sure why other European airlines would do otherwise.
Users browsing this forum: achutchison, joelliot, sunrisevalley and 1 guest
