flyingdoc787
Location Of Life Vest On FlyDubai 737-800?
Fri Nov 02, 2012 4:32 am
I just watched the safety video of FlyDubai for its 737-800, and was surprised to hear that the life vests are located "in a panel above your head", except for the first row, where it is located under the seat. Here's the link: http://www.youtube.com/watch?v=eLm1ccPrPiM
I checked out other airlines' safety videos for their 737-800's, and couldn't find any other airline with that location for the life vests. I've known life vests to be located under the seat, in between seats, or in a compartment in the armrest, but overhead? Anybody know if this is the case on any other airline/aircraft type?
Thanks.
Dogbreath
RE: Location Of Life Vest On FlyDubai 737-800?
Fri Nov 02, 2012 8:56 am
Yep. The majority of Ryanair aircraft have their life vests in a panel above each seat row.
I believe the main reasons for having them located in the overhead panel is:
1. Helps prevent passengers from stealing the lifevests. Yep! You'd be surprised what people will do. The underseat life vests are just sitting in a small pouch and easy for pax to remove and take away. The overhead location makes it more difficult for pax to access without drawing suspicion from other pax and cabin crew.
2. The old underseat pouch is also a safety problem. Easy for terrorists to place items in the pouch with the life vest. During the security checks (which a LCC may have to complete up to 8 times a day) the life vest must be removed and the pouch checked so that some asshole hasn't placed any rubbish, or at worst a device that might be of a security or safety issue.
3. The overhead location for the life vests makes it extremely easy for the cabin crew to inspect that the required life vests are installed. Just look above each seat row, and see the 3 red dots in the panel. Much easier than leaning down below each seat and inspecting each pouch (as mentioned above).
Truth, Honour, Loyalty
Fri Nov 02, 2012 8:57 am
The newer B737s out here utilize the Overhead panel location.
Fri Nov 02, 2012 10:05 am
Quoting Dogbreath (Reply 1):
Many installations now use a closed "pod" with a security seal to make inspection easier.
JAGflyer
Fri Nov 02, 2012 10:42 am
Sorry to go off-topic but what are the women in that video wearing on their face/mouth? It looks like a muzzle of some sort?!
Support the beer and soda can industry, your recycle old airplanes!
Vimanav
Fri Nov 02, 2012 4:42 pm
Its called a batoola. I its part of traditional wear for Arab women but used less frequently these days.
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
Fabo
Sat Nov 03, 2012 2:01 am
Wow. Never seen that before.
One would have thought it is some kind of face-protecting armor from Greek times...
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
aerdingus
Sat Nov 03, 2012 10:51 am
Quoting flyingdoc787 (Thread starter):
FR aircraft of a certain vintage (DAX - DCX) all have the lifejackets under the seats.
Newer aircraft have the lifejackets under the seats in row 1 & 2, & the rest of the cabin has them in the over head panel.
2016: BHX GLA KIR LCY LGW MUC VIE BA EI FR LH OS A320 A321 ATR 42 ATR 72 B738 E190 E195
Quokkas
Sat Nov 03, 2012 5:12 pm
Is there any advantage in the vest being in an overhead panel in the "unlikely event" of a water landing? Does it make it easier for passengers to access them and speed up an evacuation?
Quoting JAGflyer (Reply 4):
You can still see this being worn in the Gulf States, and is an alternative to the niq'ab or burqa. Some can be quite ornate, featuring gold and other decorative features. I imagine that they would be a bit cooler to wear than a complete face covering. They do have the benefit of helping to keep flies out of your mouth.
[Edited 2012-11-03 10:12:57]
Sun Nov 04, 2012 8:07 pm
Quoting Quokkas (Reply 8):
Overhead is def easily to access as visible unlike the underseat pouch which takes extra effort to view.
Markhkg
Sun Nov 04, 2012 8:26 pm
It can also be hard to physically reach the lifejacket when it is under the seat.
In the NTSB report for US Airways 1549, it states, "Overall, 19 passengers physically attempted to obtain a life vest from under a seat, and 10 of these passengers reported difficulties retrieving it. Of those 10 passengers, only 3 were persistent enough to eventually obtain the life vest; the other 7 either retrieved a flotation seat cushion or abandoned the idea of retrieving flotation equipment altogether."
http://www.ntsb.gov/doclib/reports/2010/AAR1003.pdf
aerdingus
Mon Nov 05, 2012 11:50 am
Quoting Markhkg (Reply 10):
Wow, that is really scary, I thought the underseat lifejackets were much easier to grab!
Kaiarahi
Mon Nov 05, 2012 5:21 pm
Quoting aerdingus (Reply 11):
Not if you're a "person of size".
Empty vessels make the most noise.
Wed Nov 21, 2012 8:13 am
Visually Inspecting the under seat location is tougher than the Overhead location.
Users browsing this forum: glen and 2 guests
