mayohoo
787 And A350 Engines And Electrical Systems
Tue Nov 06, 2012 8:22 pm
I noticed this article /n the Boeing Aero magazine. How will the a350 differ in both engine design (RR of ocurse) and electrical architecture?
http://www.boeing.com/commercial/aeromagazine/articles/2012_q3/2/
tdscanuck
RE: 787 And A350 Engines And Electrical Systems
Wed Nov 07, 2012 2:25 am
Quoting Mayohoo (Thread starter):
The engine architecture will be very similar; the only major difference is that the A350 will have a full bleed system on the engine.
The electrical system, on the other hand, will be quite different. Airbus elected to stick with a pneumatic system on the A350, which relieves the electrical system of considerable load requirements and takes a bunch of motors, power controllers, and power handling out of the system. In return, they have to keep the pneumatic ducts, valves, and overheat/leak detection systems. This also bleeds over to the APU; the A350 APU will need both generators and a load compressor (the 787 APU only has generators).
Tom.
Ruscoe
Sat Nov 10, 2012 7:57 am
I didn't see weight mentioned.
Do we know weight of 787 v 767 engines, with and without nacelles?
Also do we know how 787 engine weights compare with 350 engine weights?
Thanks if anyone knows these figures.
Ruscoe
Ruscoe
Sat Nov 10, 2012 11:48 am
I can partly answer my own question now
Dry weight Trent 1000 12,700 lbs
Dry weight Gen-x 12,800 lbs
Dry weight CF6 9000 lbs
No idea re nacelle weights
Ruscoe
tdscanuck
Sat Nov 10, 2012 1:53 pm
Quoting Ruscoe (Reply 2):
787 is much heavier, with or without nacelles, because it's a considerably larger engine and a much larger fan (the fan and case are a disproportional amount of the overall weight).
A350 is heavier, for the same reasons that the 787 is heavier than the 767. If they go to composite fan case they will recover some, but not all, of that weight.
Tom.
Users browsing this forum: Aircellist, bravogolf and 2 guests
