novice
Pressure Error
Wed Nov 07, 2012 8:40 pm
Can someone explain pressure error? in regard to one of the altimeter instrument errors
flyingturtle
RE: Pressure Error
Wed Nov 07, 2012 9:44 pm
Altimeters should be pretty reliable... except some wasps decide to occupy the static port.
Does your question relate to pressure altitude? Temperature differences can cause wrong altimeter indications. Or do you mean the difference between QNH (standardized altimeter setting to maintain vertical separation between aircraft) and QFE (the correct altimeter setting in regard to the ground)?
David
Jetlagged
RE: Pressure Error
Mon Nov 19, 2012 9:17 pm
Pressure error is the difference between sensed air pressure (static or pitot) and freestream pressure (static or total) . This occurs because the local airflow affects the pressure around the port. In relation to an altimeter it means that the sensed static pressure will give an incorrect altitude reading unless it is corrected. Air Data Computers have correction tables based on flight test data which apply a correction to the sensed pressure to give a corrected pressure, from which the indicated altitude is derived.
On some aircraft if you select alternate static source in flight you get an uncorrected pressure measurement (or perhaps a less sophisticated correction) which means the indicated altitude jumps to a new value.
Users browsing this forum: 77west and 1 guest
